Ralph Lange wrote:
> locate libreadline
> it is showing that two packages installed at,
> /usr/lib/libreadline.so.4
> /usr/lib/libreadline.so.4.2
this readline library should be sufficient.
Vijayram,
I suspect it's looking for the static libreadline.a file, which is in a
different RPM on Red Hat at least and is present on our systems here, but
evidently not on yours (from your locate output above). If you can
install the .a version you'll fix the problem sooner, but we need to fix
the EPICS build system too as it's obviously *not* trying to use shared
libraries here when it really should be (assuming you haven't changed the
SHARED_LIBRARIES setting in configure/os/CONFIG_SITE.linux-x86.Common)
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
- Re: EPICS R3.14 problem Ralph Lange
RE: Extending MBBO? Mark Rivers
<2002>
2025
<2002>
2025
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
