1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Watcher V2.0
To: "EPICS Tech Talk (E-mail)" <[email protected]>
Date: Fri, 15 Nov 2002 16:11:04 -0800
Some of our IOCs have several hundred channels monitored by CW.  When one
channel changes the IOC only needs to send that one channel's worth of data
to the Channel Watcher instead of tieing up the IOC to write the whole s/r
file over the network.
Mike
-----Original Message-----
Sent: Friday, November 15, 2002 3:23 PM
To: EPICS Tech Talk (E-mail)
Cc: 'Kay-Uwe Kasemir'
Subject: Re: Channel Watcher V2.0
Kay-Uwe Kasemir wrote:
> I just think that writing files via NFS must be lame compared to
> ChannelAccess: NFS performs round-trip requests to "open", "write",
> "write", "write", ..  then "close".
Keep in mind that NFS writes in much larger pieces than CA does, so there
won't be that many "writes".
An example from one of our IOCs:
SR: 118 channels + header -> NFS file = 2853 bytes = 2 data packets
With the protocol overhead included, the difference in network load is
probably much less than you imply.
( Difficult to be quantitative about CA without that protocol spec.... )
- brian
Prev: Re: Channel Watcher V2.0 Brian McAllister
Next: how about using a new IOC host OS? M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: alarms and autodialers Peregrine M. McGehee
