1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarms and autodialers
To: "Peregrine M. McGehee" <[email protected]>
Cc: [email protected]
Date: Mon, 18 Nov 2002 08:02:32 -1000
Peregrine M. McGehee wrote:
> Dear all,
> We are looking for an autodialer solution that would
> allow our EPICS system to notify key individuals when
> critical system errors occurred.
> At first pass, our requirements are:
> 1. receives a notification by ethernet with several possible conditions
> 2. dials several numbers
> 3. passes the appropriate voice message to each dialed number
> The first requirement is only due to the need to have non-EPICS
> systems the ability to send their own alarms. This could
> be replaced with suitable use of the CA client library.
We use the EPICS alarm handler to send email.
Of course it can be set up to do just about anything else.
One of our temperature alarm files looks like this:
$STATCOMMAND HIGH echo "IRCAM temperature exceeds 34K" | /usr/ucb/mail
-s "IRCAM temp. exceeds 34K" maren-ircam
$STATCOMMAND HIHI echo "IRCAM temperature exceeds 35K" | /usr/ucb/mail
-s "IRCAM temp. exceeds 35K" maren-ircam
where of course you can replace the "/usr/ucb/mail" command by
whatever you need.
Aloha,
Maren
alarms and autodialers Peregrine M. McGehee
Prev: Re: alarms and autodialers Tim Mooney
Next: Re: building R3.14 problem for RTEMS Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: how about using a new IOC host OS? anj
