1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VDCT groups
To: tech-talk <[email protected]>
Date: Tue, 26 Nov 2002 16:45:41 -0600
We are drawing up requirements for future versions of VDCT.
Based on discussions with a number of people it appears the the grouping
facility is not used but is often a source of confusion.
So the question is, should we remove grouping from VDCT? If we don't
remove it then it will certainly be turned off by default.
Note that groups are different from the hierarchy scheme that is now
being implemented. See the user manual at
http://www.cosylab.com/visualdct/builds/VisualDCT/2.3.1238/doc/MAN-VisualDCT_Users_Manual.html
if you need more information on groups or hierarchies.
If no one objects we'll remove grouping.
John Maclean.
Re: VDCT groups Luedeke Andreas
Re: VDCT groups Matthias Clausen
Prev: Channel Access/Linux/R3.13.7 Hammonds, John
Next: Re: VDCT groups Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Channel Access/Linux/R3.13.7 Garrett D. Rinehart
