1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access/Linux/R3.13.7
To: "Hammonds, John" <[email protected]>
Cc: "'EPICS Tech-Talk'" <[email protected]>
Date: Mon, 02 Dec 2002 16:06:16 -0600
Hammonds, John wrote:
We are in the process of upgrading from EPICS 3.13.5 and R3.13.7.
Everything works fine on solaris but on Linux I do not get any channel
communication from IOCs unless I specify EPICS_CA_ADDR_LIST.  This did work
on R3.13.5 without this specification.  My 3.13.5 distribution came from a
tar.gz file from APS.  My 3.13.7 came directly from APS CVS.  Is there a
difference in settings in config files that can cause this.
John,
When you say you got 3.13.7 from the CVS repository, do you mean you did a cvs checkout or export giving the R3-13-7 release tag? If so that should be correct - I'm just checking the obvious thing here to start with.
In general I would always recommend using a packaged distribution unless you're a developer and going to want to commit changes back in - you can then be certain that you're getting the right version.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Channel Access/Linux/R3.13.7 Hammonds, John
Prev: Re: Channel Access/Linux/R3.13.7 Garrett D. Rinehart
Next: Re: VDCT groups Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Access/Linux/R3.13.7 Hammonds, John
Next: Re: Channel Access/Linux/R3.13.7 Garrett D. Rinehart
