1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re:
To: "Hammonds, John" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Wed, 04 Dec 2002 09:32:25 -0600
You need the -mlongcall switch on the command line. This is only a problem if you have 64MB or more on the PPC board.
Geoff
Hammonds, John wrote:
I have been working with a transition between R3.13.5 and 3.13.7. I finally got through problems with connecting with Channel Access with the help of Jeff and Janet. Yesterday I tried to boot a crate with an MV2304 board and find that I cannot load iocCore. This does work with the MV167 and MV172. Errors are shown below. I am using Tornado 2.02 on Solaris 7 to compile everything. This does work if I drop back to 3.13.5 with everything else the same. Any suggestions?
John Hammonds
Intense Pulsed Neutron Source
Argonne National Laboratory
cd appbin
value = 0 = 0x0
ld < iocCore
Relocation value does not fit in 24 bits.
Re
[no subject] Hammonds, John
Prev: Problems with 3.13.7 and PPC604/MV2304 Hammonds, John
Next: Re: Problems with 3.13.7 and PPC604/MV2304 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [no subject] Hammonds, John
Next: Problems with 3.13.7 and PPC604/MV2304 Hammonds, John
