1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building capfast with EPICS R3.14.0beta2
To: Kevin Tsubota <[email protected]>
Cc: "tech-talk (E-mail)" <[email protected]>
Date: Wed, 04 Dec 2002 09:04:03 -1000
Hi Kevin,
you should find an edb.def somewhere in epics extension/edif
then look at your CONFIG_SITE for definition of E2DB and such.
this is how it looks like here at Gemini (be carefull that's a 3.13 setup, but it probably adapts to 3.14)
E2DB = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/e2db
E2DB_SYSFLAGS = -ate -d $(EPICS_EXTENSIONS)/src/edif/lib/edb.def
cheers,
Matthieu
Kevin Tsubota wrote:
I'm having problems building capfast .sch files into .db files.
I'm using the DB rule and specify the .db I want built based on the
schematic name, in this case I want tnet.sch built and install as tnet.db.
However when I do this I get the following error:
mahaiula:tnetDev> gmake
perl /usr/local/epics/r3.14.0beta2/base/configure/tools/makeMakefile.pl
O.solaris-sparc-gnu ../../..
mkdir O.Common
gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../..
T_A=solaris-sparc-gnu install
gmake[1]: Entering directory
`/home/ktsubota/kroot/kss/epcom/unixIoc/dev/tnetDev/O.solaris-sparc-gnu'
gmake[1]: *** No rule to make target `../O.Common/tnet.substitutions',
needed by `../O.Common/tnet.db'. Stop.
gmake[1]: Leaving directory
gmake: *** [install.solaris-sparc-gnu] Error 2
mahaiula:tnetDev>
I've tried specifying "DB += tnet.edf" and this generates the .edf file
based on tnet.sch but also goes ahead installs it into $(INSTALL_DB), it didn't convert the .edf to
.db.
I also specified both "DB += tnet.edf tnet.db" but that gives an error
saying it can't fine /edb.def.
Am I using the wrong rule? How do I tell the makefile to take a .sch file
and make and install a .db file?
Thank you.
Kevin Tsubota
California Association for Research in Astronomy
W.M. Keck Observatory
65-1120 Mamalahoa Hwy.
Kamuela, HI  96743
tel: (808) 885-7887
Matthieu Bec              Gemini Observatory
Tel: +1 808 9742557       670 N. A'ohoku Place
Fax: +1 808 9359235       Hilo, Hawaii 96720, USA
building capfast with EPICS R3.14.0beta2 Kevin Tsubota
Prev: building capfast with EPICS R3.14.0beta2 Kevin Tsubota
Next: libezca and EPICS-3.14 Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
