1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: select record versus dbpr() versus SPARC (at least)
To: [email protected]
Date: Sun, 8 Dec 2002 21:54:11 -1000 (HST)
Aloha,
Consider a select record with SELM == "Specified" (SELECTED in the code).
The select record initializes non-constant inputs to 1e+30 .  Then on
processing, only the selected input is fetched (contrary to the
documentation).  That leaves non-selected links as 1e+30 .  Then if one
tries a dbpr on that record, on a SPARC at least, one gets a floating point
exception in dbStatic/dbStaticRun.c:realToString at intval=value; .  Since
that may happen on other architectures too, it seems like a check against
MAXINT is warranted around the easy integer case?
Jim
Re: select record versus dbpr() versus SPARC (at least) Marty Kraimer
Re: select record versus dbpr() versus SPARC (at least) Benjamin Franksen
Prev: Work in sunny California Chestnut, Ronald P.
Next: Re: select record versus dbpr() versus SPARC (at least) Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
