1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: jdct run-time error
To: "Tech-talk" <[email protected]>
Date: Tue, 10 Dec 2002 16:44:22 +0800
hi,all
I have built jdct on RedHat linux sucessfully,but when I try to run it,the following error is encountered:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /usr/local/epics/extensions/lib/linux-x86/libdbStatic.so: /usr/local/epics/extensions/lib/linux-x86/libdbStatic.so: undefined symbol: dbDumpFldDes
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1480)
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1404)
        at java.lang.Runtime.loadLibrary0(Runtime.java:772)
        at java.lang.System.loadLibrary(System.java:832)
        at dbStatic.DbBase.<clinit>(DbBase.java:71)
        at jdct.JdctMenu.<init>(JdctMenu.java:28)
        at jdct.JdctFrame.<init>(JdctFrame.java:43)
        at jdct.Jdct.main(Jdct.java:19)
I have installed java sdk 1.4.0_01, and set the eviroment variable PATH and LD_LIBRARY_PATH properly. what's the proble now?
any suggestions are appreciated.
Shao Mingchao
Tsinghua University
Beijing 100084
P.R.China
Re: jdct run-time error Ernest L. Williams Jr.
Re: jdct run-time error Marty Kraimer
Prev: Re: select record versus dbpr() versus SPARC (at least) Marty Kraimer
Next: Re: jdct run-time error Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
