1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Booting RTEMS IOC problem
To: Edwin <[email protected]>
Cc: [email protected]
Date: Thu, 12 Dec 2002 09:33:11 -0600
On Thursday, December 12, 2002, at 02:44 AM, Edwin wrote:
Dear all:
	I have finished building RTEMS boot images with EPICS 3.14 on
Linux, Host and client are both pc386.
	While when I am trying to boot the IOC through BOOTP, my IOC
stuck when loading the boot image "example.bt".
	I wrote the /etc/bootptab file as follows:
	client1:hd=/epics/client1/bin:\
		:vm=auto:ip=166.111.32.246:td=/tftpboot:\
		:ht=ethernet:ha=0000ECD01FC7:\
         :bf=example.bt:rp=/boot/client1/root
	I download a bootstrap PROM image from www.rom-o-matic.net,
which find my boopd service on my host pc successfully
and start to download the boot image 'example.bt'. Screen prints:
	.Me: 166.111.32.246, Server: 166.111.32.244
	Loading 166.111.32.244:/epics/client1/bin/example.bt ...(NBI)...
I believe that the 'NBI' means 'non-bootable image'. From this error message I'm guessing that you copied the executable EPICS application (bin/RTEMS-pc386/example) to the TFTP server (....../bin/example.bt). The rom-o-matic network boot ROMS however require a short 16-biit startup section of code to be prepended to the EPICS application.
Here's the script which I use to do this. I called it makeBootImage and run it as
makeBootImage bin/RTEMS-pc386/example
to produce example.bt which can be copied to the TFTP server.
#!/bin/sh
set -ex
case "$#" in
        1)      ;;
        *)      echo "Usage: $0 file[.exe]" >&2 ; exit 1 ;;
esac
n=`basename "$1" .exe`
code=2
trap 'rm -f /tmp/jnk$$.bin ; exit $code' 0 1 2 3
i386-rtems-objcopy --output-target=binary "$1" /tmp/jnk$$.bin
/opt/rtems/i386-rtems/pc386/build-tools/bin2boot "$n.bt" 0x00097E00 /opt/rtems/i386-rtems/pc386/lib/start16.bin 0x00097C00 0 /tmp/jnk$$.bin 0x00100000 0
code=0
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Re: Booting RTEMS IOC problem Till Straumann
Booting RTEMS IOC problem Edwin
Prev: Booting RTEMS IOC problem Edwin
Next: Re: Booting RTEMS IOC problem Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
