1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: my base download account cann't use
To: "M.C.Shao" <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Wed, 18 Dec 2002 09:52:07 -0600
M.C.Shao wrote:
> For now, I'm using base 3.14.0beta2. My ioc is based on the RTEMS-pc386
> architecture, when I booting the example EPICS application, I found
> that the target hardware address was "0xFFFFFF".That's very strange, so
> the target  couldn't boot. And I know that Eric([email protected])
> has boot the example application on i386 with base 3.14.0beta1
> successfully. I has been in trouble with this booting problem for
> several weeks. So I decide to try with base 3.14.0beta1. And I suspect
> that this might be a bug in 3.14.0beta2.
This doesn't sound like it could be solved by using a different release of Base. I'm not an RTEMS user, but I would suspect a problem with your RTEMS build system or the way in which you are creating the final binary to be booted. Have you tested booting a very simple "Hello world" type of program, i.e. one that just does printf("Hello\n"); ?
> So would you please send the source of base 3.14.0beta1 to me? whether
> or not, thank you very much. Any suggestions about this booting problem
> are appriciated.
Sorry, we can't make that available to anybody who was not a member of the original EPICS collaboration because it doesn't have all the license and copyright information in it, and as I said above I don't think that will help you anyway. Base R3.14.1 should be released later this week, and you could try that if you really want to see if a different version will fix the problem.
- Andrew
A: No, see http://www.netmeister.org/news/learn2quote.html
Q: Should I include quotations after my reply ?
Building 3.13Extensions with 3.14 base Problem. Edwin du
Re: Building 3.13Extensions with 3.14 base Problem. Andrew Johnson
Re: my base download account cann't use M.C.Shao
Prev: Re: my base download account cann't use M.C.Shao
Next: some JOImint for xmas Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Xwindow print from Linux Garrett D. Rinehart
