1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: OMS 58 and auxiliary outputs
To: Rok Sabjan <[email protected]>
Cc: [email protected]
Date: Wed, 15 Jan 2003 07:03:57 -0600
Rok Sabjan wrote:
Hello!
I'm dealing with some stepper motor control and would like to use auxiliary outputs of the OMS 58 motor controller card for setting the stepper driver to all windings off mode. Has this been attempted before? I have looked into motor record, but was unable to find any implementation of that functionality.
Do you think this is possible?
br
Rok
I've been using the VME8-8 instead of the OMS 58 but I use this feature
for boosting the drive current to the motors. I'm using version 4.41 of the motor record and there is one gotcha as far as I know .... see below. Note that the pre-move command has a space as part of the command. I found that this was required to get the pre-move to work properly. So, you should check that your signals work with your database.
record(motor,"Moto1r") {
        field(DESC,"US motor")
        field(DTYP,"OMS VME8/44")
        field(PREM," AF1")
        field(POST,"AN1")
Marty Smith
Argonne National Lab.
APS - Controls Group
OMS 58 and auxiliary outputs Rok Sabjan
Prev: Re: OMS 58 and auxiliary outputs David Maden
Next: Has anyone ever written a tool... Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: CA Put Logging bug fixing. Vladis Korobov
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
