1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: EPICS exmaple application problem
To: "'M.C.Shao'" <[email protected]>, "'Eric Norum'" <[email protected]>
Cc: "'Tech-talk'" <[email protected]>
Date: Thu, 16 Jan 2003 08:57:22 -0700
> Thu Jan 16 21:47:10 CST 2003
> medmCAExceptionHandlerCb: Channel Access Exception:
>   Channel Name: Unavailable
>   Native Type: Unavailable
>   Native Count: 0
>   Access: Unavailable
>   IOC: Unavailable
>   Message: Virtual circuit disconnect
>   Context: 166.111.32.240:5064
>   Requested Type: TYPENOTCONN
>   Requested Count: 0
>   Source File: ../cac.cpp
>   Line number: 1532
> "166.111.32.240" is the ip address of the ioc.
>  What's the reason?any suggestions are appreciated. Thanks in
> advance.
You might see this message in ordinary situations where the medm program
has lost communication with the IOC such as when the IOC powers down,
reboots, or its network cable is removed. This message might also occur
if there are software problems but it is difficult to speculate further
with this information.
What version of EPICS are you running?
Here are some steps you can follow to find the cause of the problem.
1) Use the ping command from the medm workstation to verify that there
is network connectivity to your IOC.
2) Verify that there is not a CPU saturation problem on your RTEMS IOC
where 100% of the CPU is consumed.
3) Did the medm screen only disconnect briefly and then reconnect on its
own? Temporary disconnect problems existed in one of the early beta
releases of R3.14.
4) If not, does another program such as caEventRate connect to the IOC
in this situation?
Jeff
EPICS exmaple application problem M.C.Shao
Prev: Re: EPICS exmaple application problem Eric Norum
Next: Re: EPICS exmaple application problem M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
