Hi Paul,
You could add it to "/etc/init.d/inetinit".
This script contains a lot of "ndd" configurations under Solaris 8.
Cheers,
Andy
On Fri, 17 Jan 2003, Woods, PD (Paul) wrote:
> Hi,
> Some months ago this thread allowed us to solve this same problem at our
> site. However due to a hardware fault our Unix boot server was lost. One new
> harddisk, OS upgrade (to Solaris 9) and data recovery from tape later our
> very long IOC boot problem has now returned! We have also forgotten which
> startup script we put this line in, anyone any suggestions?
> Thanks
> Paul Woods
> Diamond Project UK
> -----Original Message-----
> From: Rozelle Wright [mailto:[email protected]]
> Sent: 21 November 2001 20:58
> To: [email protected]
> Cc: [email protected]
> Subject: Re: Fwd: RE: PowerPC woes
> Now that I'm retired, I don't check my e-mail as often as I used to, so Nick
> has probably solved his problem, but since there were so many different
> solutions, I thought I would tell you what I know. This problem has the
> same
> symptoms as we have had here at Los Alamos with slow booting of the baja60
> IOCs
> from Solaris machines. We removed the passwords from those IOCs inside the
> firewall, so that they would use tftp to boot and that solved the problem
> there. For those baja60s outside the firewall where allowing tftp on the
> Solaris machines was not an option we arranged for them to boot from Suns
> running Solaris 7 or later and made a change to the ndd parameter on the
> Suns.
> Our particular magic line in a startup files for the suns is
> /usr/sbin/ndd -set /dev/tcp tcp_time_wait_interval 5000.
> (Note: /usr/sbin/ndd doesn't have tcp_time_wait_interval as a valid
> parameter
> on Solaris 6 or earlier Solaris.)
> We decided that the problem was caused by an attempt to use the same TCP
> port
> too soon.
> In order to solve this problem using either of these two solutions you need
> to
> be or get help from someone who is super user on the Sun from which the iocs
> are booting.
> Both of the suggestions above were suggested in previous e-mails, but
> referred
> to different types of IOCs. I suspect the problem is a generic problem
> with
> vxWorks.
> Rozelle Wright
> [email protected]
> "Dale L. Brewe" wrote:
> > >Another possible cause of this problem could be that
> > >a boot was interrupted while in progress. If the IOC
> > >comes up and tries to reuse the same TCP port the
> > >Solaris server sometimes waits a very long time before
> > >it times out the old TCP circuit and begins communicating
> > >with the IOC which is presenting TCP sequence numbers
> > >that are invalid in the Solaris FTP server's perspective.
> > I haven't been following this too closely, but this suggestion reminds me
> > of the problems we started having after we upgraded to solaris 2.7 from
> > 2.5.1. The problem went away after issuing the command "/usr/sbin/ndd -set
> > /dev/tcp tcp_time_wait_interval 10000" . I think the default was 240000.
> > This doesn't survive a reboot, so I put this is a startup script. I
> believe
> > notes on this are somewhere in the EPICS listserver archives.
> > dale Brewe
> > > > We had a similar problem when booting our MV2304's where it would
> > > > take an extremely long time to boot. After messing with the ethernet
> > > > settings we finally settled on changing from using rsh to tftp when
> > > > booting our crates:
> > > > ftp password = blank
> > > > flags = 0x88
> > > > Of course this means you need to have your host setup to support tftp.
> > > > In our case our hosts are Solaris workstations.
> > > > Kevin Tsubota
> > > > > From: Nick Rees [mailto:[email protected]]
> > > > > Sent: Friday, November 16, 2001 10:39 AM
> > > > > To: Mark Rivers
> > > > > Cc: '[email protected] '
> > > > > Subject: RE: PowerPC woes
> > > > > On Fri, 16 Nov 2001, Mark Rivers wrote:
> > > > > > I have a different suggestion from Andrew's. I have seen a
> > > > > very similar
> > > > > > problem to the on Nick describes on the MVME2700. The
> > > > > problem is actually
> > > > > > with the Ethernet 10/100 autonegotiation. If I plug the
> > > > > Ethernet into a
> > > > > > 10/100 Hub it works fine. If I plug it into certain types
> > > > > of Ethernet
> > > > > > switches (e.g. Cisco 2924 I think) it takes several
> > > > > minutes, and it does it
> > > > > > twice as Nick observed. Try using a different physical
> > > > > device and see if it
> > > > > > improves.
> > > > > I have tried four configurations:
> > > > > 1. An autoconfiguring 10/100 switch (Allied Telesyn),
> > > > > 2. An autoconfiguring 10/100 hub (SMC)
> > > > > 3. A fixed 10 base T switch (Allied Telesyn)
> > > > > 4. A fixed 100 base TX hub (Allied Telesyn).
> > > > > All with no result. Sob. Sob.
> > > > > I have also tried changing the address translation stuff as
> > > > > per Andrew's
> > > > > suggestions, but to no avail. However, I may have got it
> > > > > wrong, so I will
> > > > > continue to think about it.
> > > > > Cheers,
> > > > > Nick Rees
> > > > > Joint Astronomy Centre Ph: +1 (808) 961-3756
> > > > > 660 N. Aohoku Place Fax: +1 (808) 961-6516
> > > > > Hilo, HI. 96720 Internet:
> [email protected]
> > Dale L. Brewe PNC-CAT/U. of Washington
> > ph: 630 252 0582 fax: 630 252 0580
> > Mail:
> > Argonne National Laboratory
> > Bldg 435E sector 20
> > 9700 S. Cass Ave.
> > Argonne, IL 60439
Observatory Sciences Limited Email: [email protected]
William James House Tel: 44 - (0)1223 - 508259
Cowley Road Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- RE: PowerPC woes Woods, PD (Paul)
GSOctal 232 reboot problem Woods, PD (Paul)
Re: GSOctal 232 reboot problem Bob Dalesio
<2003>
<2003>
