1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: EPICS R3.14.0beta2
To: Kevin Tsubota <[email protected]>, "tech-talk (E-mail)" <[email protected]>
Date: Tue, 28 Jan 2003 18:14:49 -1000
Ooops never mind, I found it.
I have EPICS_CA_ADDR_LIST defined but the host IP specified did not have
a caRepeater running.  I started caRepeater on it and my ioc is happy again.
Thank you.
Kevin
> -----Original Message-----
> From: Kevin Tsubota
> Sent: Tuesday, January 28, 2003 6:00 PM
> To: tech-talk (E-mail)
> Subject: EPICS R3.14.0beta2
> Hi,
> I've been running EPICS R3.14.0beta2 on a solaris-sparc-gnu
> host and have
> just
> started getting the following message:
> ..../online_notify.c: CA beacon routing (connect to
> "128.171.96.255:5065")
> error was "Connection refused"
> I didn't change any of the code or database that I've been running,
> but we did experience a power outage last night so machines had to
> be rebooted.  I've tried it on two different hosts with the
> same results.
> caget/caput work fine so I don't think this is a problem, but it is a
> nuisance.
> I've run casw but it didn't show anything.
> Here's an output of the ifconfig command:
> mahaiula:dev> ifconfig -a
> lo0: flags=1000849<UP,LOOPBACK,RUNNING,MULTICAST,IPv4> mtu
> 8232 index 1
>         inet 127.0.0.1 netmask ff000000
> eri0: flags=1000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4> mtu
> 1500 index 2
>         inet 128.171.96.175 netmask ffffff00 broadcast 128.171.96.255
> Thanks in advance.
> Kevin Tsubota
> California Association for Research in Astronomy
> W.M. Keck Observatory
> 65-1120 Mamalahoa Hwy.
> Kamuela, HI  96743
> tel: (808) 885-7887
Prev: EPICS R3.14.0beta2 Kevin Tsubota
Next: Can't build the CMLOG under Tornado 2.0 for mv162, ppc etc. Vladis Korobov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
