1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Can't build the CMLOG under Tornado 2.0 for mv162, ppc etc. (fwd)
To: Jie Chen <[email protected]>
Cc: <[email protected]>
Date: Thu, 30 Jan 2003 18:12:11 +0100 (MET)
On Thu, 30 Jan 2003, Jie Chen wrote:
> Vladis Korobov wrote:
> >---------- Forwarded message ----------
> >Date: Wed, 29 Jan 2003 15:39:35 +0100 (MET)
> >From: Vladis Korobov <[email protected]>
> >To: [email protected]
> >Subject: Can't build the CMLOG under Tornado 2.0 for mv162, ppc etc.
> >Hi all,
> >I have problem to compile CMLOG stuff (namely, cmlogClientD) under Tornado 2.0. for
> >any targets: mv162, ppc, etc.
> >Although, under Tornado I it was built OK.
> >Under Tonado I compilation looks like:
> >/usr/wind/host/sun4-solaris2/bin/c++68k -I. -O -I/usr/wind/target.68k/h -DCPU=MC68040
> >-DCPU_FAMILY=MC680X0 -fstrength-reduce -fforce-mem -finline-functions -fno-builtin
> >-nostdinc -ansi -pipe -Dvxworks -fno-for-scope -I. -I../data -I../Thread -I../Common
> >-I../Network -I/u/mks/slava/EpicsR3.13.1/extensions/CMLOG-2_1_B1/C++/SACE-4.0
> >-c cmlogClientD.cc -o .obj/mv162/cmlogClientD.o
> >cmlogClientD.cc: In function `int cmlogClientD(int, int)':
> >cmlogClientD.cc:104: warning: ANSI C++ prohibits conversion from `(class cpThreadManager *)'
> >to `(...)'
> >rm -f cmlogClientD
> >/usr/wind/host/sun4-solaris2/bin/ld68k -r -o cmlogClientD .obj/mv162/cmlogMsg.o
> >.obj/mv162/cmlogUtil.o .obj/mv162/cmlogNetUtil.o .obj/mv162/cmlogSlist.o
> >.obj/mv162/cmlogSvcLocaterRep.o .obj/mv162/cmlogServerLocater.o
> >.obj/mv162/cmlogClntCxt.o .obj/mv162/cmlogUpIO.o .obj/mv162/cmlogServerHB.o
> >.obj/mv162/cmlogUxToServer.o .obj/mv162/cmlogClntDSigHandler.o
> >.obj/mv162/cmlogClientD.o -L../lib/mv162 -ldata
> >-L/u/mks/slava/EpicsR3.13.1/extensions/CMLOG-2_1_B1/C++/SACE-4.0/lib/mv162 -lSACE
> >if test ! -d ../bin/mv162; then mkdir -p ../bin/mv162; else echo; fi
> >mv cmlogClientD ../bin/mv162
> >gmake[2]: Leaving directory `/import/epicsf2/group/mks/slava/EpicsR3.13.1/
> >extensions/CMLOG-2_1_B1/ClientD'
> >gmake[1]: Leaving directory `/import/epicsf2/group/mks/slava/EpicsR3.13.1/
> >gmake[1]: Entering directory `/import/epicsf2/group/mks/slava/EpicsR3.13.1/
> >extensions/CMLOG-2_1_B1/Client'
> >Under Tornado 2.0 it looks like:
> >/import/epicsf2/u2/tornado_2.0/host/sun4-solaris2/bin/c++68k -I. -O
> >-I/import/epicsf2/u2/tornado_2.0/target.m68k/h -DCPU=MC68040 -DCPU_FAMILY=MC680X0
> >-fstrength-reduce -fforce-mem -finline-functions -fno-builtin -nostdinc -ansi -pipe
> >-Dvxworks -fno-for-scope -I. -I../data -I../Thread -I../Common -I../Network
> >-I/u/mks/slava/EpicsR3.13.7/extensions/CMLOG-2_1_B1/C++/SACE-4.0 -c cmlogClientD.cc
> >cmlogClientD.cc: In function `cmlogClientD':
> >to `(...)'
> >cmlogClientD.cc: In function `realCmlogClientD':
> >cmlogClientD.cc:277: no matching function for call to `cpThread::add_cleanup_handler (void ()(ACE_Reactor *), void *)'
> >../Thread/cpThread.h:350: candidates are: cpThread::add_cleanup_handler(void (*)(void *), void *)
> >gmake[2]: *** [.obj/mv162/cmlogClientD.o] Error 1
> >gmake[2]: Leaving directory `/import/epicsf2/group/mks/slava/EpicsR3.13.7/
> >gmake[1]: *** [mv162] Error 2
> >gmake[1]: Leaving directory `/import/epicsf2/group/mks/slava/EpicsR3.13.7/
> >gmake[1]: Entering directory `/import/epicsf2/group/mks/slava/EpicsR3.13.7/
> >If anybody knows where is the problem, please, help me. Thank you in advance.
> >Regards,
> >V.Korobov.
> Hi, Mr. Korobov:
>     The Tornado 2.0 has new version of gcc which requires strict
> function prototype. In order to make the cmlogClientD.cc to compile, you
> only need to change
> static void
> cmlogClientDCleanup (ACE_Reactor* reactor)
>  reactor->close ();
> to the following
> static void
> cmlogClientDCleanup (void* reactor)
>  ((ACE_Reactor *)reactor)->close ();
I've done this change and the problem was solved. Thank You.
> The newer version of cmlog has this fixed. The new version of cmlog can
> be obtained at
> http://www.jlab.org/cdev/cmlog.html
We'll get the newer version of CMLOG from this site.
V:Korobov
> Jie Chen
> Thomas Jefferson National Accelerator Facility
> 12000, Jefferson Ave.
> Newport News, VA 23606
> (757)269-5046 (office) (757)269-6248 (fax)
> [email protected]
Prev: Re: Running iocsh in the background Dirk Zimoch
Next: Bug in 3.13.6, 3.13.7, and 3.14 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building VxWorks Boot Rom on Linux Singleton, SJ (Stephen)
