Hi Florent,
from within the EPICS State Notation Compiler / Sequencer (which is a
widely used tool to write state machines that integrate into an EPICS
system) you can access the status of a CA connection using the builtin
functions pvConnected() and pvConnectCount().
http://www.aps.anl.gov/epics/modules/base/R3-14/1.php
contains a link to the sequencer documentation,
http://www.aps.anl.gov/epics/modules/base/R3-14/1-docs/CAref.html#Connection
is the paragraph in the CA documentation that Jeff is referring to.
Of course, all this will only tell you about the state of a channel
access network connection for a particular channel or IOC. If you really
want to know if the IOC is running (and not just a network connector has
been pulled, a network switch is down etc.) you will have to have an
independent hardware (probably VME) based monitoring solution that uses
a separate network.
Ralph
>>>>> "Jeff" == Jeff Hill <[email protected]> writes:
> The connection state callback handler can be used to keep your
> application responsive to the state of health of the IOC.
> Alternatively, you can create a process variable that
> periodically toggles its state, and then connect a monitor
> subscription to this process variable so that the monitor update
> callbacks provide verification of the communication link.
> Jeff
>> -----Original Message-----
>> From: LANGLOIS Florent [mailto:florent.langlois@synchrotron-
>> soleil.fr]
>> Sent: Wednesday, March 12, 2003 6:15 AM
>> To: [email protected]
>> Subject: How can I know the Status of an IOC (running or
> not...)
>> Hi all,
>> is there a way to know the status of an IOC ?
>> i mean without waiting the return of a CA call.
>> is there for example a status register or something?
>> so that i can manage a state machine in my CA client.
>> thanks
>> Florent Langlois
>> _______________________
>> Division Informatique
>> Synchrotron SOLEIL
>> L'Orme des Merisiers
>> St-Aubin - BP 48
>> 91192 GIF-sur-YVETTE
>> Tél : 01.69.35.93.31
>> [email protected]
>> www.synchrotron-soleil.fr
- How can I know the Status of an IOC (running or not...) LANGLOIS Florent
- RE: How can I know the Status of an IOC (running or not...) Jeff Hill
resume vijay patel
<2003>
2025
resume vijay patel
<2003>
2025
