1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM and Red Hat Linux 8.0
From: "Singleton, SJ (Stephen)" <[email protected]>
To: "John Sinclair (E-mail)" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Thu, 13 Mar 2003 15:15:20 -0000
Hello John,
I have recently been attempting to run EDM under Red Hat Linux 8.0.  When I
attempt to put a widget on my screen, the panel from which I input data for
the widget comes up with the x co-ordinate field blank, and a series of
error messages are put out on the window from which I ran edm, saying
Name:
Class: XmTextField
Character '\67' not supported in font.  Discarded.
The y co-ordinate, width and height fields are displayed correctly
This is not serious, but if I configure the widget and close the
configuration panel, if I then try to edit it again, the panel comes up with
more error messages of a similar nature and loses the contents of all the PV
fields so I have to re-enter those as well.
If I revert to my old Red Hat Linux 7.3 machine the problem goes away.  A
certain amount of investigation suggests that a default font is being picked
up from somewhere that is different between the two systems, but I have
copied the fonts config file from the RH 7.3 machine to the RH 8, and run
xlsfonts on both machines - the results are identical.  Before I investigate
further, have you any suggestions, or do you know of anyone else who has run
EDM on RH 8.0?
Thanks
Steve
Prev: resume vijay patel
Next: calcPerform Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EDM and Red Hat Linux 8.0 Steven . Banks
