1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: the length of channel name
To: Lifang Zheng <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 19 Mar 2003 09:00:33 -0600
Lifang Zheng wrote:
> Dear all,
> Could somebody explain about the restriction of  naming channels from
> the history of EPICS developing? I learned from APS web site, the total
> length of channel name should be less than 28 characters. Do EPICS base
> & CA library support different length of channel names? Is there any
> modification in EPICS new versions for the limits?
> Is there any limit in the character length between two delimiters(:)
> among channel name?
> Any information is welcome.
> Regards,
> Lifang
For R3.13 the name must be <= 28 characters.
For R3.14 the name must be <= 60 characters
I believe that CA has no limits on channel names. Jeff can verify.
Warning:
If you use 3.14 and have channel names longer than 28 characters some Channel
Access clients may break. Also you may not be able to dynamically modify soft links.
Marty Kraimer
RE: the length of channel name Jeff Hill
the length of channel name Lifang Zheng
Prev: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Next: RE: the length of channel name Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: the length of channel name Lifang Zheng
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
