You should give a fullpath name to VX_DIR in your RELEASE.solaris-sparc
file. The configure/os/CONFIG.Common.vxWorksCommon file contains the
line WIND_BASE=$(VX_DIR).
If you want to set VX_DIR=$(WIND_BASE) in the RELEASE.solaris-sparc file
you must override the WIND_BASE=$(VX_DIR) definition by placing the full
path name definition of WIND_BASE in a config file that is included after
os/CONFIG.Common.vxWorksCommon e.g. os/CONFIG_SITE.Common.vxWorksCommon
Janet
Geoff Savage wrote:
I created a RELEASE.solaris-sparc file to override the VX_DIR location.
VX_DIR = $(WIND_BASE)
Before executing gmake I setup WIND_BASE to point to the base location
of the Tornado 2.0.2 installation. Now I execute gmake and get:
gmake[2]: Entering directory
`/usr/products/devel/savage/epics/base-3.14.1/config/O.vxWorks-ppc603_long'
.../../configure/RULES_BUILD:294: *** Recursive variable `VX_DIR'
references itself (eventually). Stop.
gmake[2]: Leaving directory
gmake[1]: *** [install.vxWorks-ppc603_long] Error 2
gmake[1]: Leaving directory
`/usr/products/devel/savage/epics/base-3.14.1/config'
gmake: *** [config.install] Error 2
When I use a hard coded directory for VX_DIR as in configure/RELEASE
everything compiles as expected.
What did I miss? Thanks
Geoff
- vxworks location Geoff Savage
stringIn record monitors Bill Cruise
<2003>
<2003>
