1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: stringIn record monitors
To: Marty Kraimer <[email protected]>, Tim Mooney <[email protected]>, Brian McAllister <[email protected]>
Cc: [email protected]
Date: Fri, 04 Apr 2003 16:12:01 -0600
I have added two DBF_MENU fields to the stringin and stringout record types. APST and MPST will control whether CA monitors are fired if the new VAL field string is identical to the old one. The default (zero) menu value is "On Change" with behaviour identical to before, set to "Always" if you want a record to fire monitors every time the record is processed (analagous to setting ADEL/MDEL=-1 for numeric record types).
These changes will appear in the forthcoming R3.14.2 release.
Marty, please add the above to the release notes.
LANL: If there's anyone there actually working on the record reference manual, the above information needs to be added to the relevent record type descriptions.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
Prev: problems switching ioc's ip address Dale L. Brewe
Next: file read and EPICS interaction problem Erik Johansson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: stringIn record monitors Mark Rivers
Next: caRepeater R3.13 vs. R3.14 Geoff Savage
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
