1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pdbbase usage and scope
To: "'[email protected]'" <[email protected]>
Date: Wed, 23 Apr 2003 14:28:44 -0600
I am a new user of EPICS (3.14.1) on a win32(Win2K) platform.  I have
several client applications developed within the MSVC(6.0) IDE framework
that communicate using a similar framework.  I am in the early stages of
converting these applications to use EPICS Channel Access.  I have also
folded the example IOC program into an MFC application and hope to
incorporate some of the configuration and diagnostic tools that we have.  I
am able to initialize the IOC and access the data using channel access
clients.
As a learning exercise/proof of concept I want to duplicate part of the
iocsh call "dbl".  I am using the code in \base\src\db\dbtest.c as an
example.  I am having difficulty learning the scope and proper usage of
pdbbase.  I intend to do something along the lines of:
DBENTRY *pdbentry;
pdbentry=dbAllocEntry(pdbbase);
dbFirstRecordType(dbentry);
dbGetRecordName(dbentry);
dbFreeEntry(pdbentry);
My test program compiles, links, and serves channel access clients but I
have not been able to resolve the scope of pdbbase to another file within
the project
using:  extern DBBASE *pdbbase; results in the warning:  "inconsistent dll
linkage. dllexport assumed" with unresolved external symbol _pdbbase errors.
How should I handle this scope and what is proper usage of pdbbase?
What is:  "#define epicsExportSharedSymbols"?
Should I be using some sort of "#define epicsImportSharedSymbols"?  Is there
such a thing?
Any snippets of code that I could use as an example?
Thank you for your time.
Randy Wells
15425, Missile and Flight Systems
Sandia National Labs
Ph:  (505) 284-4849
Fax:  (505)  844-1168
e-mail:  [email protected]
Prev: IOC memory leak? Proper shutdown? Wells, Randall
Next: Re: CAMAC problems Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: portable channel access server John Sinclair
