1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building 3.14.1 under cygwin environment
To: [email protected]
Date: Fri, 25 Apr 2003 17:31:19 +0100
 I have been trying to build Epics 3.14.1 under the cygwin environment
on a win98 machine using gcc. The EPICS_HOST_ARCH is win32-x86-cygwin
 Everything goes well until trying to compile fdmgr.cpp when I get the
set of messages below. Has anyone else seen this (and hopefully solved
it) ?
     Chris Mayer
In file included from ../../../src/libCom/osi/osiSock.h:107,
                 from ../../../src/libCom/fdmgr/fdManager.h:28,
                 from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
.../../../include/os/cygwin32/osdSock.h:58:1: warning: "SIOCGIFADDR"
redefined
In file included from /usr/include/cygwin/socket.h:23,
                 from /usr/include/sys/socket.h:15,
                 from /usr/include/cygwin/if.h:19,
                 from /usr/include/net/if.h:14,
                 from ../../../include/os/cygwin32/osdSock.h:30,
/usr/include/asm/socket.h:38:1: warning: this is the location of the
previous definition
.../../../include/os/cygwin32/osdSock.h:61:1: warning: "SIOCGIFBRDADDR"
redefined
/usr/include/asm/socket.h:39:1: warning: this is the location of the
previous definition
In file included from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
.../../../src/libCom/fdmgr/fdManager.h:93: parse error before `[' token
make[3]: *** [fdmgr.o] Error 1
make[2]: *** [install.win32-x86-cygwin] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
_______________________________________________________________________
Observatory Sciences Ltd.          Email: [email protected]
William James House                Tel: 44 - (0)1223 - 508257
Cowley Road,                       Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK             http://www.observatorysciences.co.uk
Re: Building 3.14.1 under cygwin environment Eric Norum
Prev: Re: a question about building AR Andrew Johnson
Next: Re: Building 3.14.1 under cygwin environment Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
