1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: an error about building cdev server
To: zhaozhuo <[email protected]>
Cc: [email protected]
Date: Mon, 05 May 2003 11:17:03 -0400
zhaozhuo wrote:
> i have built cdev_1.7.5,now i want to build cdev extensions,so i start
> to build cdevGenericServer,but it shows an error:
> => Building utility programs
>    => Building [solaris] in Name Server Query Application
>       => CC -c dumpServer.cc -o dumpServer.o
>       => CC -c dumpServer.o -o dumpServer
> ld: fatal: library -lcdev: not found
> ld: fatal: File processing errors. No output written to
> /home1/local/epics/epics3.13.8/extensions/src/cdev/cdev_1.7.5//bin/solaris/dumpServer
> gmake[1]: ***
> [/home1/local/epics/epics3.13.8/extensions/src/cdev/cdev_1.7.5//bin/solaris/dumpServer]
> Error 1
> gmake: *** [utils] Error 2
> please tell me how to solve this problem,thanks a lot!
You need to make sure that the environment variable $CDEVLIB is defined
correctly so that make can find libcdev.so (or libcdev.a) . It should
have a value like $CDEV/lib/solaris, which in your case would probably
be
"/home1/local/epics/epics3.13.8/extensions/src/cdev/cdev_1.7.5/lib/solaris"
Hope that helps.
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
an error about building cdev server zhaozhuo
Prev: EPICS meeting in June (For DOE labs) Bob Dalesio
Next: RE: multithread client Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: an error about building cdev server zhaozhuo
Next: EPICS meeting in June (For DOE labs) Bob Dalesio
