1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Dealing with Granularity in Output Records
To: [email protected]
Date: Fri, 09 May 2003 16:44:43 -0400
We have a situation where analog output records have a built in granularity. If a user attempts to change the value using his/her favorite EPICS program (probe, edm, etc.), The value that actually is sent to the device may be slightly different from the value typed into the program interface due to the granularity of the underlying device.
Here's the question. What is the normal practice for display programs such as an edm screen? Do they show the value entered regardless of the actual value that is sent or should the interface show an adjusted value based on the nearest acceptable value after granularity has been accounted?
Advanced Applications Engineer
Collider-Accelerator Department
Brookhaven National Laboratory
Upton, NY 11973-5000
Tel: (631)344-5595
Fax: (631)344-5443
Re: Dealing with Granularity in Output Records Kay-Uwe Kasemir
Prev: a little news from KEKB Noboru Yamamoto
Next: How to initialize waveform record Rod
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Dealing with Granularity in Output Records Kay-Uwe Kasemir
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
