1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with building epics base on redhat 9.0
To: Rok Sabjan <[email protected]>
Cc: [email protected]
Date: Mon, 19 May 2003 10:40:23 +0200
Hi Rok,
I had a problem (I think the same) on RH9, It was a perl problem, as a workaround I had to modify the file: configure/tools/mkmf.pl and comment out the lines:
#   while ( length $line > 78 ) {
#      write ;
which occur twice in the file.
This is a workaround not a fix, the code is ok, so it might be a problem with perl on a unpatched redhat install.
Steve
Rok Sabjan wrote:
Hi all,
I'm trying to build EPICS base 3.14.1 on Redhat 9.0 and I have encountered a strange problem. The build stops (not exists, however) at the following step:
Installing generic include file ../../../include/os/Linux/osdTime.h
Installing generic include file ../../../include/osiSigPipeIgnore.h
Installing os dependent include file ..../../../include/os/Linux/osdSigPipeIgnore.h
Installing generic include file ../../../include/osiProcess.h
Installing generic include file ../../../include/os/Linux/osiUnistd.h
Installing os dependent include file ..../../../include/os/Linux/osiWireFormat.h
Installing generic include file ../../../include/taskwd.h
Installing generic include file ../../../include/epicsTimer.h
Installing generic include file ../../../include/tsDefs.h
Here the build process just waits (for eternity). I know that people have succeeded in building epics under rh9, but has anyone encountered this problem before?
Rok
Re: Problems with building epics base on redhat 9.0 Ernest L. Williams Jr.
Problems with building epics base on redhat 9.0 Rok Sabjan
Prev: Problems with building epics base on redhat 9.0 Rok Sabjan
Next: Re: Problems with building epics base on redhat 9.0 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
