1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: convertRelease.pl
To: "'Ralph Lange'" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 27 May 2003 12:35:18 +0200
Hi Ralph,
Yes, yes and yes  .....   as well as speeding up, building a release we need
to much better manage the dependencies.  Particularly we need to track
version numbers that make up a release, and make sure we can reproduce any
of our standard configurations.  As you say, we are now able to control and
track what is moved into production (but are not yet doing so for all
systems), and what core release (VxWorks/Epics and Libraries) are used by an
ioc. We have plans to take this further, more on what we have done at the
epics meeting ....
But on this particular issue (use the environment or not), we should be
consistent, the build of base allows environment variables to be used, and
so should building "Apps" such as the client ioc shell.
Some people don't drive safely, should we limit all cars to 40km/hr ?
Thanks Earnest for the patches to the old version, I will wait a day or two,
in the hope that someone who understands perl will incorporate the changes
into the new version, or perhaps I can just run this code as is for 3.14.1?
Cheers
Steve
-----Original Message-----
Sent: Tuesday, May 27, 2003 10:42 AM
To: Steve Hunt
Cc: EPICS Tech-Talk
Subject: Re: convertRelease.pl
Hi Steve,
just be careful: you might be throwing some air bags and security belts
out of your car to make it run faster. Which works, of course.
Some details:
Usually IOC applications are based on a combination of different support
modules: EPICS base being one, downloaded or locally developed record,
device and driver supports and other IOC applications being others. The
number of these modules in an installation usually increases over the
years: BESSY started with a few, currently we have 20.
The combination of these support modules and their release numbers is
crucial. Some will depend on each other, many will depend on base. There
is no obvious clean way to express these dependencies under a structure
that uses a hierarchical make.
The problem is: If you just change and recompile one of the modules, you
are not guaranteed that any of your IOC applications will still work.
Some of them will, sure. Some will crash immediately, fine. Some others
look like they would work, but they will just kill some IOCs under some
circumstances some days later late at night on a weekend. (If I remember
correctly, the JLab people have had some experience with that kind of
problems.)
So: To help keeping things configurable _and_ stable, the complete set
of module locations (which usually include the release numbers, at least
with the standard directory name structure) is kept in one place: the
RELEASE file(s) in the configure directory of a module.
This ensures that changes to the set of modules that an application is
compiled against are made intentionally. It also ensures that any given
application will be compiled against the same set of modules from the
same locations, no matter who is running the "make" command or how many
years have gone. (As long as you don't throw away the outdated versions
of your modules.)
If you change this behaviour to be environment-controlled, you might
very easily get into a situation where you are screwing up things with
no way to get back to the working version.
Scenario:
You have a shared location for your module tree. Everything is in sync
and fine. You keep your "standard" base release in an environment
variable that is set by a global shell login script. Then - after your
"standard" has been moved on three minor steps, since your installation
procedures are so incredibly fast - one developer is changing one file
in one of the modules and recompiles. The environment sets the new base
location for that module, everything compiles fine, he/she doesn't get
any warnings. Still: your complete set of modules is inconsistent now.
So two weeks later one of your IOC hangs.
Since the paths for the modules (at least: base) are taken from the
environment, you can look in the RELEASE files but these won't tell you
which version of base the single modules where compiled against. Damn.
You think: Must be some inconsistency. Better "make clean" and rebuild
to get things straight. Right on. Suddenly (remember: your standard base
release has changed) three other modules are just dumping error messages
and don't compile anymore. Obviously they have never been compiled
against the new standard base. Oops. You don't want to start getting
into this, as you are not sure what to do and you have some pressure to
get the IOC up again. So better get everything back to what it was
before. But: Ouch - you don't know which release of base the other
modules were compiled against before - this was taken from someone's
environment and your own "make clean" just threw away all information
who compiled the former versions and when.
Guess my point is clear ...
This is a worst case scenario, sure. But this is actually not too far
from what happened to us some time ago. Setting everything from the
environment you can easily manage to get yourself into a situation where
you have to rely on the tape backup to get back to a running version.
I'm not trying to scare anyone here - just trying to say that not
setting all stuff from the environment was intentionally.
I know that the SLS is well aware of all this. I am sure that you have
some other ways to keep the information which release number
combinations are valid and tested and to keep track of your system
progress: i.e. when what versions of which module combinations were
moved to production by whom. Btw: I was always dreaming of a small mySQL
database for this.
So actually the RELEASE file mechanism was more or less intended as an
interface that complex installations could plug some database into where
smaller projects could happily stay with the set of files.
Bottom line: I would be reluctant to make enviroment control the default
behaviour as this would encourage people (I'm mainly thinking of smaller
installations) to use only environment variables to save time and work
and get themselves in trouble.
Sorry that this got lengthy ...
Cheers,
Ralph
>>>>> "Steve" == Steve Hunt <[email protected]> writes:
  > Hi all,
  > In 3.14.1,  the script base/configure/tools/convertRelease.pl  seems to
  > expand configuration files (like configue/RELEASE), to create files to
  > be included in make for a particular application and architecture.
  > Unfortunately it does not take account of any environment variables, so
  > if you set EPICS_BASE in your environment it will be ignorred and the
  > value from your configuration files will be taken, or the build will
  > fail if they are not defined.
  > This is causing us a problem, as we don't want to manualy edit these
  > files every time we build epics in a different location (we are trying
  > to speed up, and generalize our  installation and build procedures).
  > Should this perl script be modified ? ( I can't do this as I can't even
  > spell pearl!).
  > Thanks in advance
  > Steve Hunt
RE: convertRelease.pl Ernest L. Williams Jr.
Prev: Re: convertRelease.pl Ralph Lange
Next: RE: convertRelease.pl Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: convertRelease.pl Ernest L. Williams Jr.
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
