1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: channel access disconnects
To: "'Geoff Savage'" <[email protected]>, <[email protected]>
Date: Mon, 2 Jun 2003 10:20:52 -0600
Geoff,
What are the symptoms of your put failure? I need to know whether it was a "CA
disconnect" related issue as your subject line mentions or a "write failure" as
your message text mentioned. If the circuit was already disconnected when you
initiated the put request then you would receive immediate failure status
indicating that the channel was not connected. Are you making ordinary put
requests or put notify requests? If it was a put notify request, was your
callback handler called with failure status? Otherwise, was a disconnect
callback handler called? Or perhaps an exception handler associated with an
ordinary put request failure was called? Does this application call
ca_pend_xxx() or ca_flush_io() after issuing the last put request? If it was a
write failure then please send any specific status codes or messages that you
see.
o What version of EPICS is in your IOC
o What version of EPICS is in your CA client
Jeff
> -----Original Message-----
> From: Geoff Savage [mailto:[email protected]]
> Sent: Monday, June 02, 2003 10:00 AM
> To: '[email protected]'
> Subject: channel access disconnects
> Hi,
> I'm trying to understand the cause of sporadic but consistent CA write
> failures.  The records in question are typically written every few hours
> and are spread across 12 IOCs.  I have not been able to identify a
> pattern with the with failures in terms of one write failing
> consistently.
> About a month ago I did discover that the client that writes to these
> records was not calling CA poll at least every 15 seconds as specified
> in the CA manual.  For the last month the client calls CA poll once a
> second and the problems persist.
> Any suggestions on where to look?
> Thanks
> Geoff
channel access disconnects Geoff Savage
Prev: Re: multicast storms, or how do WRS SPRs work Andrew Johnson
Next: RE: bug in VxWorks memPartInfoGet (used by VxStats) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: channel access disconnects Geoff Savage
Next: VxWorks on x86 John Sinclair
