1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question on waveform monitoring
To: "Chestnut, Ronald P." <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 06 Jun 2003 09:09:56 -0500
Ron, re...,
> We have a special record to deal with digitizers, where the waveforms associated with each channel have fields with imaginative names like .ARY1, .ARY2 etc. These waveforms hold the past few pulses of Low-level RF data, and are meant to be picked up by the archiver when a trip occurs and new data are available. These internal arrays (ARY1, ARY2, etc.) are only read from the hardware (SIS or Joerger digitizers) upon a trip.
> > It seems that these fields are not being successfully monitored. Two stray waveforms have appeared in the archiver, but hundreds of others have not.
In calls to db_post_events(), is the second argument a pointer to the field whose value you're posting,
e.g., 'prec->ary2' or to the buffer that contains the actual data array?  It should be the buffer.
I can't find the place where this is documented, but if you look closely at the waveform-record code, you'll see that it
posts 'pwf->bptr' when the .VAL field has changed.
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
Question on waveform monitoring Chestnut, Ronald P.
Re: Question on waveform monitoring Marty Kraimer
Prev: Re: Question on waveform monitoring Marty Kraimer
Next: Re: Question on waveform monitoring Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
