1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Preemptive callback required
To: "'Chris Mayer'" <[email protected]>, <[email protected]>
Date: Thu, 12 Jun 2003 13:01:55 -0600
> dbServiceIO: preemptive callback required for
> direct memory interfacing
A minor clarification:
The message says "direct in memory interfacing" and not "direct memory
interfacing". There should probably have been a hyphen in "in-memory". I fixed
that for R3.15.
> I looked at where the message was coming from but am not really
> any the wiser as to what it is trying to tell me.
In R3.13 the vxWorks version of the ca client library was implemented with
preemptive calls to user registered callback methods, but this was not allowed
or implemented on any other OS.
In R3.14 preemptive callback is implemented on all OS, but this is optional, and
the default is non-preemptive callback for backwards compatibility to the widest
range of applications that do not run on vxWorks.
Within the iocCore execution environment there is an efficient direct in-memory
path between client requests and the database calls that implement them, and all
socket related overhead is eliminated. In R3.14 this feature is currently
requiring the preemptive callback execution environment, and it is not possible
to create a channel unless you have preemptive callback mode enabled. I must
admit that I don't clearly remember why I coded in this restriction so if its
important, I could look into this further and see if it is still required.
However, given that Williams's application was probably running before under
vxWorks in the R3.13 vxWorks ca client callback environment, then I assume that
the simple solution will be to just enable preemptive callbacks when starting up
a ca client context in the pvload utility. This is assuming of course that the
pvload code was prepared to receive preemptive callbacks when it ran in the
vxWorks preemptive callback environment provided under R3.13.
Jeff
> -----Original Message-----
> From: Chris Mayer [mailto:[email protected]]
> Sent: Monday, June 09, 2003 1:49 PM
> To: [email protected]
> Subject: Preemptive callback required
>  I have just built William Lupton's pvload utility under 3.14.2 so that
> I
> can call it from iocsh on a Linux box. I ran it with a test file and the
> records got set correctly at startup however, I got the following
> message
> dbServiceIO: preemptive callback required for direct memory interfacing
> of CA channels to the DB.
>  I looked at where the message was coming from but am not really any the
> wiser as to what it is trying to tell me. Before I start looking at the
> pvload code can someone explain what circumstances would trigger this
> message.
>   Regards
>    Chris Mayer
> _______________________________________________________________________
> Observatory Sciences Ltd.          Email: [email protected]
> William James House                Tel: 44 - (0)1223 - 508257
> Cowley Road,                       Fax: 44 - (0)1223 - 508258
> Cambridge, CB4 0WX, UK             http://www.observatorysciences.co.uk
Re: Preemptive callback required Chris Mayer
Prev: Re: fd_caMotif build can't find Xm includes Eric Williams
Next: R3.14.2 linker options for building on linux Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Preemptive callback required Chris Mayer
Next: Re: Preemptive callback required Chris Mayer
