1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: including external libraries in EPICS R3.14.2 builds
To: Geoff Savage <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 26 Jun 2003 10:23:33 +0200
Hi Geoff,
I guess you are looking for "Specifying libraries to be linked when
creating the product", which is the title of section 4.6.19.4 in the
Application Developer's Guide. ;-)
Nevertheless - the following two definitions should do the job:
<prodname>_LIBS += <library-name>
    Libraries to be used for linking the named product.
<library-name>_DIR = <path-to-that-library>
    Location of external library (if not system library or in BASE).
    For libraries from a <module> mentioned in the RELEASE file you
    should use <module>_LIB to specify the location.
Hope this helps,
Ralph
>>>>> "Geoff" == Geoff Savage <[email protected]> writes:
  > Hi,
  > To include the python library in a build of a support module I added
  > camodule_LDFLAGS and camodule_SYS_PRODS to my Makefile.  Are these the
  > most appropriate definitions to use?  When I used USR_LIBS and PROD_LIBS
  > it tried to find a rule to build the specified libraries.  Of course no
  > rule exists since the library is prebuilt.
  > Thanks for any advice.
  > Geoff
including external libraries in EPICS R3.14.2 builds Geoff Savage
Prev: Re: EPICS collaboration meeting presentations Till Straumann
Next: Re: R3.14 and registerRecordDeviceDriver Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: including external libraries in EPICS R3.14.2 builds Geoff Savage
Next: Serial I/O for Linux Eric Williams
