1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS 3.14.2 Under Windows
To: "EPICS Tech-Talk (E-mail)" <[email protected]>
Date: Thu, 10 Jul 2003 16:00:00 +0100
Upgrading GNU make from v3.76.1 to v3.78.1 has fixed the problem.  Although
I had to run the vcvars32.bat file from the VC++ bin directory to build GNU
make 3.78.1, so maybe this cured the problem??!?
I can now build EPICS 3.14.2 successfully under Windows.
Graham.
-----Original Message-----
Sent: 10 July 2003 11:21
To: EPICS Tech-Talk (E-mail)
Subject: EPICS 3.14.2 Under Windows
I am having problems building 3.14.2 under Windows.  I have WinNT4 with
Perl, gnumake and VC++ 6.0 installed.  When make encounters the first cl
command it returns the following errors:
make[4]: Entering directory
`E:/Development/EPICS/base-3.14.2/src/toolsComm/antelope/O.win32-x86'
cl -c              /nologo /D__STDC__=0  /Ox /GL   /W1    -D_NO_PROTO   /MD
Command line warning D4002 : ignoring unknown option '/GL'
Command line error D2003 : missing source filename
make[4]: *** [closure.obj] Error 2
make[4]: Leaving directory
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory
`E:/Development/EPICS/base-3.14.2/src/toolsComm/antelope'
make[2]: *** [antelope.install] Error 2
make[2]: Leaving directory `E:/Development/EPICS/base-3.14.2/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `E:/Development/EPICS/base-3.14.2/src'
make: *** [src.install] Error 2
make: Leaving directory `E:/Development/EPICS/base-3.14.2'
Error executing make.
has anyone else encountered this problem?
Thanks
Graham.
Prev: RE: the command formats in RS232 Porter, Rodney R.
Next: RE: the command formats in RS232 Geng, Xiaosong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS 3.14.2 Under Windows Cox, G (Graham)
Next: Specifications for the JLab archiver machine Matt Bickley
