1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Datum (Bancomm) GPS glitches
To: [email protected]
Date: Mon, 28 Jul 2003 15:06:39 -1000
We are using a Datum TymServ(tm) 2100 Network Time Server with GPS
receiver option to provide our observatory with stratum one NTP.
In our IOC we have a Datum bc635VME Time and Frequency Processor.  This
is basically the same board which some other observatories use, only
most have GPS receiver options and ours gets the time from the 2100
by means of an IRIG connection.
We use the receiver to directly read time from the internal registers
via the VME buss, using direct calls.  This is done from inside a
genSub record, and is the basic timing for our whole system.  We do not
use any "real" drivers, and do not use the timing capabilities of the
board.  We just read the time -- NOW.
The problem is that we have seen some timing glitches of 1 second and
10 seconds.  Last night there were four 1 second glitches.  The time
seems to be 1 second fast on one read, and then OK 0.050 seconds later.
This happens very rarely, and so far hasn't caused any real problems,
but the capability seems to be there.
Has anyone else encountered any such glitches in reading time from a
Datum GPS?  If so, have you developed a solution?
Thanks for any help,
Bill
William L. Cruise                             [email protected]
Electronics System Supervisor                   FAX:    808 885-7288
Canada-France-Hawaii Telescope                  Voice:  808 885-3121
65-1238 Mamalahoa Highway         http://www.cfht.hawaii.edu/~cruise
Kamuela, HI   96743
RE: Datum (Bancomm) GPS glitches Jeff Hill
Prev: Re: edm Noboru Yamamoto
Next: RE: Datum (Bancomm) GPS glitches Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE : edm GOURNAY Jean-François DAPNIA
