1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux and EPICS threads
Cc: [email protected]
Date: Wed, 30 Jul 2003 12:49:13 -0500
Mark Rivers wrote:
Andrew Johnson wrote:
You will need to worry about more than one thread - each different scan period has its own thread, so it just takes the user
changing
the SCAN field of the record for your code to have to call iopl(3) yet
again, and if it's set to Process Passive then there are several other
tasks that might be used depending on how the processing is initiated.
Actually, it's not that bad in my case.  All of the actual I/O is done
by an MPF server task.  Device support just sends messages to the MPF
server, so the tasks that process the record do not need iopl()
privilege.
I've got it working by calling iopl() in the MPF server task
initialization.  It's not as clean as I'd like, because it requires some
#ifdef linux code, but it's OK.
I'd recommend calling ioperm() rather than iopl() since ioperm opens only a specified window into the inp/outp space so you can't accidentally tromp on some other (critical) port.
-- Eric Norum [email protected] Advanced Photon Source Phone: (630) 252-4793 Argonne National Laboratory
RE: Linux and EPICS threads John Quintana
RE: Linux and EPICS threads Mark Rivers
Prev: RE: Linux and EPICS threads Mark Rivers
Next: RE: Linux and EPICS threads John Quintana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
