1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OMS motor card JOG mode problems
Cc: [email protected]
Date: Thu, 07 Aug 2003 16:40:26 +0200
Dear all,
I observed something like a 'direction bit flip' when using the OMS motor card in JOG mode. The motor starts moving and then at full speed (!!!) reverts the direction. The limit switch it is now heading to is ignored, probably because it is believing to move in the opposite direction. Let me add, that the motor setup is a simple 0-360 deg rotation with 2 limit switches. One of the switches is used to set the motor counter to a certain value (motor initialization), so the motor counter never runs out of certain values between its limit switches.
Anybody observed similar behaviour, is the JOG mode somehow deprecated?
                         _____
      Swiss             /    /        [email protected]
     _/_/_/  _/   _/_/_/    /____    Experimental Division
    _/      _/   _/   Source    /   Paul Scherrer Institute
     _/_/  _/     _/_/     ____/  CH-5232 Villigen-PSI
        _/_/Light    _/   /      Tel: ++41 56 310 5131
 _/_/_/_/_/_/_/ _/_/_/___/      Fax: ++41 56 310 3151
Re: OMS motor card JOG mode problems Kay-Uwe Kasemir
RE: Problem with static build on Linux Mark Rivers
Prev: compilering the crossgcc on RedHat linux9.0 zhaozhuo
Next: Re: OMS motor card JOG mode problems Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with static build on Linux Mark Rivers
