1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem loading iocCore (R3.13.9)
Date: Thu, 21 Aug 2003 15:13:48 -0500
My responses are below.
Those symbols are from various files in dbStaticLib, and *should* be present - did you have any problems at all when building?
I did not have any errors while building EPICS base. I did, however, get 1123 warning messages of various types.
Try going into src/dbStatic and doing a 'gnumake rebuild' there, a 'gnumake' in the src/iocCore directory, and then a 'gnumake' from the top of your IOC application.
I tried it and I am still getting the same error. I also tried to go back to the version of base that I was using previously (3.13.7)
and I see the same error, which is strange since I don't believe I changed anything in the 3.13.7 version of base. I may have
rebuilt it to compare the warning messages to those of 3.13.9.
So now I've succeeded at completely killing my ioc.
Kevin Peterson
UNICAT
[email protected]
RE: problem loading iocCore (R3.13.9) Jeff Hill
problem loading iocCore (R3.13.9) Kevin M. Peterson
Re: problem loading iocCore (R3.13.9) Andrew Johnson
Prev: Re: problem loading iocCore (R3.13.9) Andrew Johnson
Next: RE: problem loading iocCore (R3.13.9) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
