1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Channel Access Errors
To: [email protected]
Cc: [email protected]
Date: Mon, 25 Aug 2003 15:09:04 -0600
We've been getting these errors on our Channel Access Proxy Gateway for the last couple of days. We are using the version of the gateway built against patched EPICS 3.12. Use the gateway to provide access to the controls subnet from outside the control system. Only see these errors for two outside hosts. Other channel access through the gateway seems to work fine. I finally blocked access for the two hosts at our firewall. Had more than a Gig of log messages just like the following:
CAS: bad message type=11
CAS ? on ? at xxxxxx.yyyyyy.lanl.gov:5064: cmd=11 cid=4294967295 typ=0 cnt=0 psz=40 avail=8e
Internal failure - unexpected error processing stateless protocol
Can't find a match to any of the strings in the errors in the gateway code itself. Anyone have an idea about what they mean?
RE: Channel Access Errors Jeff Hill
Prev: ACU-RITE Linear Encoder with OMS VME58-4E Problem Porter, Rodney R.
Next: Channel Access Errors Gary P Carr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Channel Access Errors Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
