1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access Errors
To: <[email protected]>, <[email protected]>
Date: Tue, 26 Aug 2003 15:50:36 -0600
> CAS: bad message type=11
> CAS ? on ? at xxxxxx.yyyyyy.lanl.gov:5064: cmd=11 cid=4294967295 typ=0
> cnt=0 psz=40 avail=8e
The cause was discovered to be a windows system with EPICS_CA_ADDR_LIST set to include the IP address and port
number of a CA gateway. This was necessary for CA clients on that host. However, when a CA server was also started
on that same host it used the same EPICS_CA_ADDR_LIST to configure the CA server's beacon address list, and a
beacon message was sent to a CA server. The normal recipients for CA beacon messages are CA clients (indirectly
through the CA repeater). The solution was to start this CA server with an empty EPICS_CA_ADDR_LIST.
In EPICS R3.14 there is an independent variable, the EPICS_CAS_BEACON_ADDR_LIST, which can be used to configure the
CA server's beacon address list. To remain backwards compatible, the R3.14 code still defaults to using the
EPICS_CA_ADDR_LIST if EPICS_CAS_BEACON_ADDR_LIST isn't specified. Perhaps that will be a source of confusion. Open
to suggestions.
Jeff
> -----Original Message-----
> From: Gary P Carr (by way of Gary P Carr <[email protected]>)
> [mailto:[email protected]]
> Sent: Monday, August 25, 2003 3:21 PM
> To: [email protected]
> Subject: Channel Access Errors
> Sorry, really mean EPICS 3.13.2, not 3.12.
> We've been getting these errors on our Channel Access Proxy Gateway for
> the
> last couple of days. We are using the version of the gateway built
> against
> patched EPICS 3.12. Use the gateway to provide access to the controls
> subnet from outside the control system. Only see these errors for two
> outside hosts. Other channel access through the gateway seems to work
> fine.
> I finally blocked access for the two hosts at our firewall. Had more
> than a
> Gig of log messages just like the following:
> Internal failure - unexpected error processing stateless protocol
> Can't find a match to any of the strings in the errors in the gateway
> code
> itself. Anyone have an idea about what they mean?
Channel Access Errors Gary P Carr
Prev: Re: Channel Access Errors Brian McAllister
Next: RE: Channel Access Errors Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Access Errors Gary P Carr
Next: Does DISP work for DB OUT links? Benjamin Franksen
