1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question]
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Fri, 29 Aug 2003 06:52:49 -0500
An additional comments on Jeff's second suggestion:
Fix 2:
There is a new field called AVAL (for asynchronous value) which is initialized at the start of processing to what
is in the VAL field. When processing completes the AVAL field is used to determine if monitors will be sent instead
of VAL.
This does seem like it should be easy to implement.
General Rule: Record support that allows asynchronous processing must do this for any field for which it checks for value change before issuing monitors.
Marty Kraimer
Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Brian Bevins
[Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Prev: Re: Changes to records during asynch processing Marty Kraimer
Next: Re: Changes to records during asynch processing Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Next: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Brian Bevins
