1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Symb loadable object
To: Geoff Savage <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 12 Sep 2003 07:15:55 -0500
Geoff Savage wrote:
The reason I went down this path is that I can't figure out how to incorporate the libSymb.a file into an R3.13 build.
Please don't try to use a 3.14 support in a 3.13 application. It is not supported.
For 3.14.3 the old config as well as the configure rules are still supported but the old config rules only work for vxWorks IOCs.
Starting with 3.15, and perhaps sooner, the old config rules will no longer be supported.
One of my tests for 3.14 is for a test stand that has many of the VME devices supported in the 3.13 releases. I unbundled the hardware support from base and until recently I built the support with the old config rules. This made the application more difficult to understand because it was a strange combination of old and new rules. Starting with 3.14.3 I am building all the hardware support using the latest 3.14.3 build rules.
I am responsible for the allenBradley 6008 scanner based support. I must support it on both 3.13 and 3.14. In the CVS repository I created a branch for the 3.13 version and maintain the 3.14 version on the main branch. This is easier than trying to maintain the 3.13 and 3.14 versions in the same tree like I did previously.
Bottom line. Don't build with a combination of 3.13 and 3.15 components. It will cause more problems then it solves.
Marty Kraimer
Symb loadable object Geoff Savage
Prev: Symb loadable object Geoff Savage
Next: JCA2.0 is now released !!! Eric Boucher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
