1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbbo record behavior changes
To: [email protected]
Date: Wed, 01 Oct 2003 18:41:03 -1000
I'm finally getting back to my 3.13B11 to 3.13.8 upgrade and tackling
all the interesting little problems introduced therein.  This one is
a bit more perplexing, so I'd like to ask about it before throwing
a fix at it.  I'll also present a simplified case, rather than the
convoluted one in my system.
The test case database is simply this:
an mbbi VAL is connected to a stringIn INP
an mbbo VAL is connected to a stringOut DOL
Both the mbbi and mbbo have a few enum strings defined.
In 3.13B11 I get strings in the string records in either case.
In 3.13.8 I get strings with the mbbi, but get the corresponding
numerals in the stringOut record with the mbbo. You can imagine what
this does to downstream processing that expects strings!  If I use
dbgf or caget, I do get strings right out of the mbbo.
I guess the first question is whether there has been a change in how
these record interconnections are supposed to work.  If so, I'll just
have to switch all my mbbo's to mbbi's in cases like this.
And, the second, most obvious, question is what am I doing wrong!
This is also, by far, the most likely case.
Thanks for any help on this one.
Bill
William L. Cruise                             [email protected]
Electronics System Supervisor                   FAX:    808 885-7288
Canada-France-Hawaii Telescope                  Voice:  808 885-3121
65-1238 Mamalahoa Highway         http://www.cfht.hawaii.edu/~cruise
Kamuela, HI   96743
Re: mbbo record behavior changes Marty Kraimer
Prev: Network monitoring Bob Dalesio
Next: Re: mbbo record behavior changes Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
