1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Ascii SIO and alarms questions
To: "'LYNCH, Damien'" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Wed, 15 Oct 2003 11:38:53 +0100
> -----Original Message-----
> From: LYNCH, Damien [mailto:[email protected]]
> Sent: 15 October 2003 01:11
> To: '[email protected]'
> Subject: Ascii SIO and alarms questions
> I am using Ascii SIO to handle the serial comms with a magnet
> power supply. There are 8 commands that I send to the power
> supply which expect a response.
> Originally I had set up my database so that a different
> command was being sent (via stringin records) every second.
> It turns out that the power supply can't be tusted to reply
> within one second. Occasionally a response from the power
> supply was arriving
> late resulting in synchronisation being lost between the IOC
> and the power supply. So what I need to do is be able to
> recognise when I am in a late response situation.
Are you sure that it is the power supply that is taking so
long to reply? I recently had a saw similar symptoms, but
it turned out that the problem was with my low level serial
device driver buffering input.
In any case, there should be no need to send the commands
one at a time. devAscii should queue the commands if another
record is already using the line. (If it doesn't then that
would be yet another reason to prefer streamDevice for
serial IO)
The sychronisation does get lost if you set the timeout too
short (then one record gives up the line, the next record sends
it's command and parses the first record's reply). You should be
able to put all your records on a 10 second scan without the need
for any sequencing.
Also, you are not limited to using stringin records. devAscii
can parse your response for and ai, bi etc record if that response
returning a value.
Pete.
Prev: Ascii SIO and alarms questions LYNCH, Damien
Next: ChannelArchiver build problem with g++ 2.9.5 on Linux Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Ascii SIO and alarms questions Porter, Rodney R.
