1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ChannelArchiver build problem with g++ 2.9.5 on Linux
To: Andy Foster <[email protected]>
Cc: Epics Questions <[email protected]>, [email protected]
Date: Fri, 17 Oct 2003 13:30:34 -0600
On 2003.10.17 08:17, Andy Foster wrote:
So, I'm assuming that, at the moment we cannot build the
ChannelArchiver against 3.14.4.
Is this correct?
Hi:
Sorta.
R3.14 is fundamentally different in every aspect that
pertains to the archiver:
Channel Access, Time Stamps, OSI support for threads.
(actually quite interesting:
The basic C tsStamp still works, but the C++ osiTime
class that was supposed to shield us from all the changes
in the intrinsics changed into a just-different-enough
epicsTime so that almost every time-stamp related line of
code in the archiver needed to be rewritten)
I did spend a little time to make it _compile_ again, but:
The result isn't fully tested, and then the different
releases of R3.14.x are again different enough that
so far I can barely keep up with getting them set up,
let alone have time to really check the archiver against them.
You can get a snapshot of this misery at
http://ics-web1.sns.ornl.gov/~kasemir/archiver/index.html
Hope is in sight, we are actually working on a better "index"
to replace the current "directory" files, one that will
also serve as a "master" index for multiple sub-archives.
The x in R3.14.x is also changing more slowly now, so
I hope we will get a better archiver which compiles under the
then current R3.14 within the next 6 month.
-Kay
Re: ChannelArchiver build problem with g++ 2.9.5 on Linux Andy Foster
Prev: Re: ChannelArchiver build problem with g++ 2.9.5 on Linux Andy Foster
Next: CA block sem corrupted error and S_errno_ENOBUFS Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Ascii SIO and late response/synchronization faults Allan Honey
