1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS periodic scan and sysClkRateSet()
To: "'Steven Hartman'" <[email protected]>, "'EPICS tech-talk'" <[email protected]>
Date: Mon, 17 Nov 2003 09:36:55 -0700
> (3.13.7) where I have found taskDelay() using a constant include:
> 	ca/vxWorks_depen.c
The constant taskDelay() in "ca/vxWorks_depen.c" is in a code fragmented
that is commented out. Therefore, the CA client library should not be
impacted by changes in the vxWorks tick rate.
> 	db/dbCa.c
> 	rec/recWaitCa.c
I didn't write these codes so I will let their respective authors respond.
Jeff
Re: EPICS periodic scan and sysClkRateSet() Steven Hartman
Prev: Re: EPICS periodic scan and sysClkRateSet() Steven Hartman
Next: RE : EPICS periodic scan and sysClkRateSet() GOURNAY Jean-François DAPNIA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS periodic scan and sysClkRateSet() Kevin Tsubota
