1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: RTLinux for an IOC
To: [email protected]
Cc: [email protected]
Date: Tue, 18 Nov 2003 06:57:48 -0600
[email protected] wrote:
G'day,
There is a great work going on with RTEMS and, of course Tornado (vxWorks)
is the traditional IOC, but is anyone using a semi-commercial variant of RT
Linux as a serious IOC? For example I'm looking at RedHawk Linux
(Concurrent computers -
http://www.ccur.com/isd_solutions_redhawklinux.asp).
Any fundamental reason why this might not be a good idea before I try it?
Any experiences or thoughts ?
As I recall RTLinux is a small real-time kernel that also runs the regular Linux kernel as a low priority RTLinux thread. Since an integral part of EPICS is Channel Access it is hard to see how an IOC could be run using only RTLinux threads.
Once the 2.6 kernel is available, linux will have much better real time characteristics. My guess is that, with more work needed on base/src/libCom/osi/(posix and/or linux), linux will be sufficient for most EPICS IOC applications.
For applications with harder real time requirements at least two other approaches are available. Both require that the real time requirements are localized to a small part of the application. If the entire application has hard real-time requirements than perhaps EPICS is the wrong solution.
On method is to use RTLinux or RTAI for the hard real-time and write EPICS device/driver support that communicates with the RTLinux or RTAI threads.
Another approach is becoming available. I/O boards are becoming available that include easily programmable FPGAs and high performance Digital and Analog I/O. The FPGAs can be programmed to handle the hard real-time and again EPICS device/driver support can be created to communicate with the FPGA code.
Just my thoughts.
Marty Kraimer
RTLinux for an IOC Richard . Farnsworth
Prev: asynDriver Marty Kraimer
Next: RE: RTLinux for an IOC Williams Jr, Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RTLinux for an IOC Richard . Farnsworth
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
