1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: sequencer SEGV
To: "Benjamin Sailer" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Tue, 18 Nov 2003 12:42:10 -0600
> so if I believe the debugger, there is a bug in the
> thread-safe version of our C-library, but I don't dare to make such a
statement about the
> million-times-used glibc version 2.2.5 ...
This could well be a glibc problem.
Are you linking statically or dynamically?
There was a definite problem with static builds and some versions of
glibc discussed in tech-talk, starting on July 31, 2003.  Thread was
"Problem with static build on Linux".  I was getting strange errors like
yours in commonly used libraries and functions, e.g.:
"I have tested the static image on another Linux system and it sometimes
fails in nss_getline() as one the other system, but it sometimes fails
in __current_locale_name() instead."
My resolution to the problem was to upgrade glibc:
"Following up on suggestions here earlier today I upgraded all of the
glibc packages on my Redhat 8 machine to the latest versions from
Redhat.  It does indeed fix the problem, and I can now build
applications statically that run fine.
sonata> rpm -qa | grep glibc
glibc-debug-2.3.2-4.80.6
glibc-2.3.2-4.80.6
glibc-devel-2.3.2-4.80.6
glibc-common-2.3.2-4.80.6
glibc-profile-2.3.2-4.80.6
glibc-kernheaders-2.4-7.20
glibc-utils-2.3.2-4.80.6
glibc-debug-static-2.3.2-4.80.6 "
Mark Rivers
RE: sequencer SEGV Benjamin Sailer
Prev: RE: sequencer SEGV Nick Rees
Next: close_record ? Amy Baum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: sequencer SEGV Benjamin Sailer
