Noboru Yamamoto wrote: > Amy Baum wrote: > >> >> Hi - >> >> Is there a routine that epics will call when a record >> is destroyed? I've been through the developer's guide >> and can't find anything. I'd like to close some file >> handles that were opened when init_record() was called. >> >> Thanks! >> >> Amy >> > > As far as I understand, a record stays alive as far as IOC is running. > I don't think there is a method to delete a record from a running database on IOC. > Or do you need a special operation on the filehandler before robooting IOC? > > > Regards, > Noboru > > I'm wondering about a routine that gets called when the IOC is exiting - when the record is destroyed. Amy
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
