1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux -> PPC cross-compile of the Motor Record
To: "Ronald L. Sluiter" <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Mon, 24 Nov 2003 13:22:57 +0000 (GMT)
Hi Ron,
Please find attached, versions of:
gnu.ppc/gcc/cp/error.c
gnu.ppc/gcc/cp/typeck.c
which are patched for the "tree_list" problem.
If you use these files to build the cross-compiler, this
should enable you to get round the compiler error.
I'm really confused now by the fact that the problem shows
up on the solaris->68k cross-compile but not on the
solaris->PPC cross-compile even though you would think
they should both be built from gcc-2.96??
Cheers,
Andy
On Fri, 21 Nov 2003, Ronald L. Sluiter wrote:
> Dear Andy,
> Oh! the joy of collaboration.
> I was just struggling with this problem when I saw your post.
> Strangely, this same problem does occur with the 68K version of the
> Tornado 2.2 (and 2.2.1) compiler.
> /home/oxygen/SLUITER/wind68K2.2/host/sun4-solaris2/bin/cc68k -c
> -D_POSIX_SOURCE -DCPU=MC68040 -DvxWorks -include
> /home/oxygen/SLUITER/wind68K2.2/target/h/vxWorks.h -ansi -O0 -g -Wall
> -m68040 -fno-implicit-templates -fno-builtin -I. -I..
> -I../../../include/os/vxWorks -I../../../include
> -I/home/oxygen/SLUITER/local/epics/Vx_5-5_R3-14-4/support/mpf2-4/include/os/vxWorks
> -I/home/oxygen/SLUITER/local/epics/Vx_5-5_R3-14-4/base/include/os/vxWorks
> -I/home/oxygen/SLUITER/local/epics/Vx_5-5_R3-14-4/support/ipac2-5/include/os/vxWorks
> -I/home/oxygen/SLUITER/wind68K2.2/target/h ../drvOms.cc
> .../drvOms.cc:878: sorry, not implemented: `tree_list' not supported by
> dump_type
> .../drvOms.cc: In function `int motorIsrEnable(int)':
> .../drvOms.cc:878: ANSI C++ prohibits conversion from `()' to `(...)'
> .../drvOms.cc:938: sorry, not implemented: `tree_list' not supported by
> dump_type
> .../drvOms.cc: In function `void motorIsrDisable(int)':
> .../drvOms.cc:938: ANSI C++ prohibits conversion from `()' to `(...)'
> .../drvOms.cc: In function `int motor_init()':
> .../drvOms.cc:1071: warning: unsigned int format, pointer arg (arg 5)
> .../../../include/motordrvComCode.h: At top level:
> .../drvOms.cc:922: warning: `void motorIsrDisable(int)' defined but not used
> dumond% cc68k -v
> Reading specs from
> /home/oxygen/SLUITER/wind68K2.2/host/sun4-solaris2/bin/../lib/gcc-lib/m68k-wrs-vxworks/gcc-2.96/specs
> gcc version gcc-2.96 (2.96+) 19990621 VxWorks 5.5
> 85973
> Please send those patches.
> Thanks,
> Ron Sluiter
> Andy Foster wrote:
> >Dear All,
> >I recently tried compiling the latest version of the
> >Motor record (V5-2 for 3.14.4) using the Linux -> PPC cross-compiler
> >that I built from the GNU/Wind River sources available from the SNS site.
> >The compilation failed due to a compiler problem:
> >/export/home/ajf/tornado2.2/ppc/host/x86-linux/bin/ccppc -c   -D_POSIX_SOURCE
> >   -DCPU=PPC604  -DvxWorks -include /export/home/ajf/tornado2.2/ppc/target/h/vxWorks.h
> >   -ansi  -O3  -Wall     -mcpu=604 -mstrict-align -mlongcall -fno-implicit-templates
> >   -fno-builtin  -I. -I.. -I../../../include/os/vxWorks -I../../../include
> >   -I/export/home/ajf/epics3.14.4/base/include/os/vxWorks
> >   -I/export/home/ajf/tornado2.2/ppc/target/h  ../drvOms.cc
> >.../drvOms.cc: In function `int set_status(int, int)':
> >.../drvOms.cc:228: warning: `bool ls_active' might be used
> >                  uninitialized in this function
> >.../drvOms.cc:878:
> >    sorry, not implemented: `tree_list' not supported by dump_type
> >I eventually tracked down the problem
> >as being due to a change that was made to the GNU compiler between
> >gcc-2.95 and gcc-2.95.1. I have patched my copy of the SNS compiler
> >sources and this enabled me to compile successfully.
> >Interestingly, when cross-compiling from Solaris, using the
> >cross-compiler supplied with Tornado 2.2, this problem
> >does not occur. I can only assume then that the compiler which
> >Wind River supplies is being built from a slightly different set
> >of source files than the one on the SNS site.
> >I was also surprised that for the built compiler:
> >ccppc -v gives:
> >Reading specs from ./../lib/gcc-lib/powerpc-wrs-vxworks/gcc-2.96/specs
> >gcc version gcc-2.96 (2.96+) 19990621 AltiVec
> >which seems to indicate that the sources are from gcc-2.96, i.e. a release
> >which should have already included the patches that I had to apply.
> >If anyone else is having problems compiling the motor record and is
> >interested in the patched compiler code, I would be happy
> >to supply it.
> >Cheers,
> >Andy
> >Observatory Sciences Limited    Email: [email protected]
> >William James House             Tel: 44 - (0)1223 - 508259
> >Cowley Road                     Fax: 44 - (0)1223 - 508258
> >Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
/* Call-backs for C++ error reporting.
   This code is non-reentrant.
   Copyright (C) 1993, 94-97, 1998, 1999 Free Software Foundation, Inc.
   This file is part of GNU CC.
GNU CC is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2, or (at your option)
any later version.
GNU CC is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with GNU CC; see the file COPYING.  If not, write to
the Free Software Foundation, 59 Temple Place - Suite 330,
Boston, MA 02111-1307, USA.  */
#include "config.h"
#include "system.h"
#include "tree.h"
#include "cp-tree.h"
#include "obstack.h"
#include "toplev.h"
typedef char* cp_printer ();
#define A args_as_string
#define C code_as_string
#define D decl_as_string
#define E expr_as_string
#define F fndecl_as_string
#define L language_as_string
#define O op_as_string
#define P parm_as_string
#define Q assop_as_string
#define T type_as_string
#define V cv_as_string
#define o (cp_printer *) 0
cp_printer * cp_printers[256] =
/*0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x00 */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x10 */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x20 */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x30 */
  o, A, o, C, D, E, F, o, o, o, o, o, L, o, o, O, /* 0x40 */
  P, Q, o, o, T, o, V, o, o, o, o, o, o, o, o, o, /* 0x50 */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x60 */
  o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, o, /* 0x70 */
#undef C
#undef D
#undef E
#undef F
#undef L
#undef O
#undef P
#undef Q
#undef T
#undef V
#undef o
#define obstack_chunk_alloc xmalloc
#define obstack_chunk_free free
/* Obstack where we build text strings for overloading, etc.  */
static struct obstack scratch_obstack;
static char *scratch_firstobj;
# define OB_INIT() (scratch_firstobj ? (obstack_free (&scratch_obstack, scratch_firstobj), 0) : 0)
# define OB_PUTC(C) (obstack_1grow (&scratch_obstack, (C)))
# define OB_PUTC2(C1,C2)	\
  (obstack_1grow (&scratch_obstack, (C1)), obstack_1grow (&scratch_obstack, (C2)))
# define OB_PUTS(S) (obstack_grow (&scratch_obstack, (S), sizeof (S) - 1))
# define OB_PUTID(ID)  \
  (obstack_grow (&scratch_obstack, IDENTIFIER_POINTER (ID),	\
		 IDENTIFIER_LENGTH (ID)))
# define OB_PUTCP(S) (obstack_grow (&scratch_obstack, (S), strlen (S)))
# define OB_FINISH() (obstack_1grow (&scratch_obstack, '\0'))
# define OB_PUTI(CST) do { sprintf (digit_buffer, HOST_WIDE_INT_PRINT_DEC, (HOST_WIDE_INT)(CST)); \
			   OB_PUTCP (digit_buffer); } while (0)
# define OB_UNPUT(N) obstack_blank (&scratch_obstack, - (N));
# define OB_END_TEMPLATE_ID() 						    \
  ((obstack_next_free (&scratch_obstack) != obstack_base (&scratch_obstack) \
    && obstack_next_free (&scratch_obstack)[-1] == '>')			    \
   ? OB_PUTC2 (' ', '>') : OB_PUTC ('>'))
# define NEXT_CODE(t) (TREE_CODE (TREE_TYPE (t)))
enum pad { none, before, after };
static void dump_type PROTO((tree, int));
static void dump_type_real PROTO((tree, int, int));
static void dump_simple_decl PROTO((tree, tree, int));
static void dump_decl PROTO((tree, int));
static void dump_function_decl PROTO((tree, int));
static void dump_expr PROTO((tree, int));
static void dump_unary_op PROTO((char *, tree, int));
static void dump_binary_op PROTO((char *, tree));
static void dump_aggr_type PROTO((tree, int, int));
static void dump_type_prefix PROTO((tree, int, int));
static void dump_type_suffix PROTO((tree, int, int));
static void dump_function_name PROTO((tree));
static void dump_expr_list PROTO((tree));
static void dump_global_iord PROTO((tree));
static void dump_qualifiers PROTO((tree, enum pad));
static void dump_char PROTO((int));
static void dump_parameters PROTO((tree, int, int));
static void dump_exception_spec PROTO((tree, int));
static char *aggr_variety PROTO((tree));
static tree ident_fndecl PROTO((tree));
static int interesting_scope_p PROTO((tree));
void
init_error ()
  gcc_obstack_init (&scratch_obstack);
  scratch_firstobj = (char *)obstack_alloc (&scratch_obstack, 0);
/* Returns nonzero if SCOPE is something we want to print for random decls.  */
static int
interesting_scope_p (scope)
     tree scope;
  if (scope == NULL_TREE
      || scope == global_namespace)
    return 0;
  return (TREE_CODE (scope) == NAMESPACE_DECL
	  || AGGREGATE_TYPE_P (scope));
static void
dump_qualifiers (t, p)
     tree t;
     enum pad p;
  if (TYPE_QUALS (t))
      if (p == before) OB_PUTC (' ');
      switch (TYPE_QUALS (t))
	case TYPE_QUAL_CONST:
	  OB_PUTS ("const");
	  break;
	case TYPE_QUAL_VOLATILE:
	  OB_PUTS ("volatile");
	  break;
	case TYPE_QUAL_RESTRICT:
	  OB_PUTS ("__restrict");
	  break;
	case TYPE_QUAL_CONST | TYPE_QUAL_VOLATILE:
	  OB_PUTS ("const volatile");
	  break;
	case TYPE_QUAL_CONST | TYPE_QUAL_RESTRICT:
	  OB_PUTS ("const __restrict");
	  break;
	case TYPE_QUAL_VOLATILE | TYPE_QUAL_RESTRICT:
	  OB_PUTS ("volatile __restrict");
	  break;
	case TYPE_QUAL_CONST | TYPE_QUAL_VOLATILE | TYPE_QUAL_RESTRICT:
	  OB_PUTS ("const volatile __restrict");
	  break;
	default:
	  my_friendly_abort (0);
      if (p == after) OB_PUTC (' ');
/* This must be large enough to hold any printed integer or floating-point
   value.  */
static char digit_buffer[128];
/* Dump into the obstack a human-readable equivalent of TYPE.  */
static void
dump_type_real (t, v, canonical_name)
     tree t;
     int v;			/* verbose? */
     int canonical_name;
  if (t == NULL_TREE)
    return;
  if (TYPE_PTRMEMFUNC_P (t))
    goto offset_type;
  switch (TREE_CODE (t))
    case ERROR_MARK:
      OB_PUTS ("{error}");
      break;
    case UNKNOWN_TYPE:
      OB_PUTS ("{unknown type}");
      break;
    case TREE_LIST:
      /* A list of function parms.  */
      dump_parameters (t, 0, canonical_name);
      break;
    case IDENTIFIER_NODE:
      OB_PUTID (t);
      break;
    case TREE_VEC:
      dump_type_real (BINFO_TYPE (t), v, canonical_name);
      break;
    case RECORD_TYPE:
    case UNION_TYPE:
    case ENUMERAL_TYPE:
      if (TYPE_LANG_SPECIFIC (t)
	  && (IS_SIGNATURE_POINTER (t) || IS_SIGNATURE_REFERENCE (t)))
	  dump_qualifiers (t, after);
	  dump_type_real (SIGNATURE_TYPE (t), v, canonical_name);
	  if (IS_SIGNATURE_POINTER (t))
	    OB_PUTC ('*');
	  else
	    OB_PUTC ('&');
      else
	dump_aggr_type (t, v, canonical_name);
      break;
    case TYPE_DECL:
    case TEMPLATE_DECL:
    case NAMESPACE_DECL:
      dump_decl (t, v);
      break;
    case COMPLEX_TYPE:
      OB_PUTS ("complex ");
      dump_type_real (TREE_TYPE (t), v, canonical_name);
      break;
    case VECTOR_TYPE:
      OB_PUTS ("vector ");
      if (TYPE_MAIN_VARIANT (t) == vector_unsigned_char_type_node)
	OB_PUTS ("unsigned char");
      else if (TYPE_MAIN_VARIANT (t) == vector_signed_char_type_node)
	OB_PUTS ("signed char");
      else if (TYPE_MAIN_VARIANT (t) == vector_boolean_char_type_node)
	OB_PUTS ("bool char");
      else if (TYPE_MAIN_VARIANT (t) == vector_unsigned_short_type_node)
	OB_PUTS ("unsigned short");
      else if (TYPE_MAIN_VARIANT (t) == vector_signed_short_type_node)
	OB_PUTS ("signed short");
      else if (TYPE_MAIN_VARIANT (t) == vector_boolean_short_type_node)
	OB_PUTS ("bool short");
      else if (TYPE_MAIN_VARIANT (t) == vector_unsigned_long_type_node)
	OB_PUTS ("unsigned long");
      else if (TYPE_MAIN_VARIANT (t) == vector_signed_long_type_node)
	OB_PUTS ("signed long");
      else if (TYPE_MAIN_VARIANT (t) == vector_boolean_long_type_node)
	OB_PUTS ("bool long");
      else if (TYPE_MAIN_VARIANT (t) == vector_float_type_node)
	OB_PUTS ("float");
      else if (TYPE_MAIN_VARIANT (t) == vector_pixel_type_node)
	OB_PUTS ("pixel");
      else
	sorry ("`%s' not supported by dump_type",
	       tree_code_name[(int) TREE_CODE (t)]);
      break;
    case INTEGER_TYPE:
      if (!TREE_UNSIGNED (TYPE_MAIN_VARIANT (t)) && TREE_UNSIGNED (t))
	OB_PUTS ("unsigned ");
      else if (TREE_UNSIGNED (TYPE_MAIN_VARIANT (t)) && !TREE_UNSIGNED (t))
	OB_PUTS ("signed ");
      /* fall through.  */
    case REAL_TYPE:
    case VOID_TYPE:
    case BOOLEAN_TYPE:
	tree type;
	type = canonical_name ? TYPE_MAIN_VARIANT (t) : t;
	if (TYPE_NAME (type) && TYPE_IDENTIFIER (type))
	  OB_PUTID (TYPE_IDENTIFIER (type));
	else
	  /* Types like intQI_type_node and friends have no names.
	     These don't come up in user error messages, but it's nice
	     to be able to print them from the debugger.  */
	  OB_PUTS ("{anonymous}");
      break;
    case TEMPLATE_TEMPLATE_PARM:
      if (!TEMPLATE_TEMPLATE_PARM_TEMPLATE_INFO (t))
	  /* For parameters inside template signature. */
	  if (TYPE_IDENTIFIER (t))
	    OB_PUTID (TYPE_IDENTIFIER (t));
	  else
	    OB_PUTS ("{anonymous template template parm}");
      else
	  int i;
	  tree args = TYPE_TI_ARGS (t);
	  OB_PUTC ('<');
	  for (i = 0; i < TREE_VEC_LENGTH (args); i++)
	      tree arg = TREE_VEC_ELT (args, i);
	      if (TREE_CODE_CLASS (TREE_CODE (arg)) == 't'
		  || TREE_CODE (arg) == TEMPLATE_DECL)
	        dump_type_real (arg, 0, canonical_name);
	      else
	        dump_expr (arg, 0);
	      if (i < TREE_VEC_LENGTH (args)-1)
	        OB_PUTC2 (',', ' ');
	  OB_END_TEMPLATE_ID ();
      break;
    case TEMPLATE_TYPE_PARM:
      else
	OB_PUTS ("{anonymous template type parm}");
      break;
      /* This is not always necessary for pointers and such, but doing this
	 reduces code size.  */
    case ARRAY_TYPE:
    case POINTER_TYPE:
    case REFERENCE_TYPE:
    case OFFSET_TYPE:
    offset_type:
    case FUNCTION_TYPE:
    case METHOD_TYPE:
      dump_type_prefix (t, v, canonical_name);
      dump_type_suffix (t, v, canonical_name);
      break;
    case TYPENAME_TYPE:
      OB_PUTS ("typename ");
      dump_type_real (TYPE_CONTEXT (t), 0, canonical_name);
      OB_PUTS ("::");
      dump_decl (TYPENAME_TYPE_FULLNAME (t), v);
      break;
    case TYPEOF_TYPE:
      OB_PUTS ("__typeof (");
      dump_expr (TYPE_FIELDS (t), 1);
      OB_PUTC (')');
      break;
    default:
static char *
aggr_variety (t)
     tree t;
  if (TREE_CODE (t) == ENUMERAL_TYPE)
    return "enum";
  else if (TREE_CODE (t) == UNION_TYPE)
    return "union";
  else if (TYPE_LANG_SPECIFIC (t) && CLASSTYPE_DECLARED_CLASS (t))
    return "class";
  else if (TYPE_LANG_SPECIFIC (t) && IS_SIGNATURE (t))
    return "signature";
  else
    return "struct";
static void
dump_type (t, v)
     tree t;
  dump_type_real (t, v, 0);
/* Print out a class declaration, in the form `class foo'.  */
static void
     tree t;
     int canonical_name;
  tree name;
  char *variety = aggr_variety (t);
  if (v > 0)
      OB_PUTCP (variety);
      OB_PUTC (' ');
  name = TYPE_NAME (canonical_name ? TYPE_MAIN_VARIANT (t) : t);
  if (name && CP_DECL_CONTEXT (name) != global_namespace)
      /* FUNCTION_DECL or RECORD_TYPE */
      dump_decl (DECL_CONTEXT (name), 0);
      OB_PUTC2 (':', ':');
  /* kludge around weird behavior on g++.brendan/line1.C */
  if (name && TREE_CODE (name) != IDENTIFIER_NODE)
    name = DECL_NAME (name);
  if (name == 0 || ANON_AGGRNAME_P (name))
      OB_PUTS ("{anonymous");
      if (!v)
	  OB_PUTC (' ');
	  OB_PUTCP (variety);
      OB_PUTC ('}');
  else
    OB_PUTID (name);
/* Dump into the obstack the initial part of the output for a given type.
   This is necessary when dealing with things like functions returning
   functions.  Examples:
   return type of `int (* fee ())()': pointer -> function -> int.  Both
   pointer (and reference and offset) and function (and member) types must
   deal with prefix and suffix.
   Arrays must also do this for DECL nodes, like int a[], and for things like
   int *[]&.  */
static void
     tree t;
     int v;			/* verbosity */
     int canonical_name;
      t = TYPE_PTRMEMFUNC_FN_TYPE (t);
      goto offset_type;
    case POINTER_TYPE:
	tree sub = TREE_TYPE (t);
	dump_type_prefix (sub, v, canonical_name);
	/* A tree for a member pointer looks like pointer to offset,
	   so let the OFFSET_TYPE case handle it.  */
	if (!TYPE_PTRMEM_P (t))
	    switch (TREE_CODE (sub))
		/* We don't want int ( *)() */
	      case FUNCTION_TYPE:
	      case METHOD_TYPE:
		break;
	      case ARRAY_TYPE:
		OB_PUTC2 (' ', '(');
		break;
	      case POINTER_TYPE:
		/* We don't want "char * *" */
		if (TYPE_QUALS (sub) == TYPE_UNQUALIFIED)
		  break;
		/* But we do want "char *const *" */
	      default:
		OB_PUTC (' ');
	    if (TREE_CODE (t) == POINTER_TYPE)
	      OB_PUTC ('*');
	    else
	      OB_PUTC ('&');
	    dump_qualifiers (t, none);
      break;
    case OFFSET_TYPE:
    offset_type:
      dump_type_prefix (TREE_TYPE (t), v, canonical_name);
      if (TREE_CODE (t) == OFFSET_TYPE)	/* pmfs deal with this in d_t_p */
	  OB_PUTC (' ');
	  dump_type_real (TYPE_OFFSET_BASETYPE (t), 0, canonical_name);
      OB_PUTC ('*');
      break;
      /* Can only be reached through function pointer -- this would not be
         correct if FUNCTION_DECLs used it.  */
    case FUNCTION_TYPE:
      break;
    case METHOD_TYPE:
      dump_aggr_type (TYPE_METHOD_BASETYPE (t), 0, canonical_name);
      break;
    case ARRAY_TYPE:
      break;
    case ENUMERAL_TYPE:
    case ERROR_MARK:
    case INTEGER_TYPE:
    case BOOLEAN_TYPE:
    case REAL_TYPE:
    case RECORD_TYPE:
    case TREE_LIST:
    case TYPE_DECL:
    case TREE_VEC:
    case UNION_TYPE:
    case UNKNOWN_TYPE:
    case VOID_TYPE:
    case TYPENAME_TYPE:
    case COMPLEX_TYPE:
    case VECTOR_TYPE:
      dump_type_real (t, v, canonical_name);
      break;
    default:
      sorry ("`%s' not supported by dump_type_prefix",
static void
     tree t;
     int canonical_name;
    case POINTER_TYPE:
    case OFFSET_TYPE:
      if (TREE_CODE (TREE_TYPE (t)) == ARRAY_TYPE)
	OB_PUTC (')');
      dump_type_suffix (TREE_TYPE (t), v, canonical_name);
      break;
      /* Can only be reached through function pointer */
    case FUNCTION_TYPE:
    case METHOD_TYPE:
	tree arg;
	OB_PUTC (')');
	arg = TYPE_ARG_TYPES (t);
	if (TREE_CODE (t) == METHOD_TYPE)
	  arg = TREE_CHAIN (arg);
	/* Function pointers don't have default args.  Not in standard C++,
	   anyway; they may in g++, but we'll just pretend otherwise.  */
	dump_parameters (arg, 0, canonical_name);
	  dump_qualifiers
	    (TREE_TYPE (TREE_VALUE (TYPE_ARG_TYPES (t))), before);
	dump_exception_spec (TYPE_RAISES_EXCEPTIONS (t), canonical_name);
	break;
    case ARRAY_TYPE:
      OB_PUTC ('[');
      if (TYPE_DOMAIN (t))
	  if (TREE_CODE (TYPE_MAX_VALUE (TYPE_DOMAIN (t))) == INTEGER_CST)
	    OB_PUTI (TREE_INT_CST_LOW (TYPE_MAX_VALUE (TYPE_DOMAIN (t))) + 1);
	  else if (TREE_CODE (TYPE_MAX_VALUE (TYPE_DOMAIN (t))) == MINUS_EXPR)
	    dump_expr (TREE_OPERAND (TYPE_MAX_VALUE (TYPE_DOMAIN (t)), 0), 0);
	  else
	    dump_expr (fold (build_binary_op
			     (PLUS_EXPR, TYPE_MAX_VALUE (TYPE_DOMAIN (t)),
			      integer_one_node)), 0);
      OB_PUTC (']');
      break;
    case ENUMERAL_TYPE:
    case ERROR_MARK:
    case INTEGER_TYPE:
    case BOOLEAN_TYPE:
    case REAL_TYPE:
    case RECORD_TYPE:
    case TREE_LIST:
    case TYPE_DECL:
    case TREE_VEC:
    case UNION_TYPE:
    case UNKNOWN_TYPE:
    case VOID_TYPE:
    case TYPENAME_TYPE:
    case COMPLEX_TYPE:
    case VECTOR_TYPE:
      break;
    default:
      sorry ("`%s' not supported by dump_type_suffix",
/* Return a function declaration which corresponds to the IDENTIFIER_NODE
   argument.  */
static tree
ident_fndecl (t)
     tree t;
  tree n = lookup_name (t, 0);
  if (n == NULL_TREE)
    return NULL_TREE;
  if (TREE_CODE (n) == FUNCTION_DECL)
    return n;
  else if (TREE_CODE (n) == TREE_LIST
	   && TREE_CODE (TREE_VALUE (n)) == FUNCTION_DECL)
    return TREE_VALUE (n);
  my_friendly_abort (66);
  return NULL_TREE;
#ifndef NO_DOLLAR_IN_LABEL
#  define GLOBAL_THING "_GLOBAL_$"
#else
#  ifndef NO_DOT_IN_LABEL
#    define GLOBAL_THING "_GLOBAL_."
#  else
#    define GLOBAL_THING "_GLOBAL__"
#  endif
#endif
#define GLOBAL_IORD_P(NODE) \
  ! strncmp (IDENTIFIER_POINTER(NODE), GLOBAL_THING, sizeof (GLOBAL_THING) - 1)
static void
dump_global_iord (t)
     tree t;
  char *name = IDENTIFIER_POINTER (t);
  OB_PUTS ("(static ");
  if (name [sizeof (GLOBAL_THING) - 1] == 'I')
    OB_PUTS ("initializers");
  else if (name [sizeof (GLOBAL_THING) - 1] == 'D')
    OB_PUTS ("destructors");
  else
    my_friendly_abort (352);
  OB_PUTS (" for ");
  OB_PUTCP (input_filename);
  OB_PUTC (')');
static void
dump_simple_decl (t, type, v)
     tree t;
     tree type;
     int v;
  if (v > 0)
      dump_type_prefix (type, v, 0);
      OB_PUTC (' ');
  if (interesting_scope_p (DECL_CONTEXT (t)))
      dump_decl (DECL_CONTEXT (t), 0);
      OB_PUTC2 (':',':');
  if (DECL_NAME (t))
    dump_decl (DECL_NAME (t), v);
  else
    OB_PUTS ("{anon}");
  if (v > 0)
    dump_type_suffix (type, v, 0);
static void
dump_decl (t, v)
     tree t;
  if (t == NULL_TREE)
    return;
    case ERROR_MARK:
      OB_PUTS (" /* decl error */ ");
      break;
    case TYPE_DECL:
	/* Don't say 'typedef class A' */
        if (DECL_ARTIFICIAL (t))
	    if (v > 0 && TREE_CODE (TREE_TYPE (t)) == TEMPLATE_TYPE_PARM)
	      /* Say `class T' not just `T'. */
	      OB_PUTS ("class ");
	    dump_type (TREE_TYPE (t), v);
	    break;
      if (v > 0)
	OB_PUTS ("typedef ");
      dump_simple_decl (t, DECL_ORIGINAL_TYPE (t)
			? DECL_ORIGINAL_TYPE (t) : TREE_TYPE (t), v);
      break;
    case VAR_DECL:
      if (DECL_NAME (t) && VTABLE_NAME_P (DECL_NAME (t)))
	  OB_PUTS ("vtable for ");
	  if (TYPE_P (DECL_CONTEXT (t)))
	    dump_type (DECL_CONTEXT (t), v);
	  else
	    /* This case can arise with -fno-vtable-thunks.  See
	       expand_upcast_fixups.  It's not clear what to print
	       here.  */
	  break;
      /* else fall through */
    case FIELD_DECL:
    case PARM_DECL:
      dump_simple_decl (t, TREE_TYPE (t), v);
      break;
      if (CP_DECL_CONTEXT (t) != global_namespace)
	  dump_decl (DECL_CONTEXT (t), v);
	  OB_PUTC2 (':',':');
      if (DECL_NAME (t) == anonymous_namespace_name)
      else
	OB_PUTID (DECL_NAME (t));
      break;
    case SCOPE_REF:
      dump_decl (TREE_OPERAND (t, 0), 0);
      OB_PUTS ("::");
      dump_decl (TREE_OPERAND (t, 1), 0);
      break;
    case ARRAY_REF:
      dump_decl (TREE_OPERAND (t, 0), v);
      OB_PUTC ('[');
      dump_decl (TREE_OPERAND (t, 1), v);
      OB_PUTC (']');
      break;
      /* So that we can do dump_decl in dump_aggr_type and have it work for
	 both class and function scope.  */
    case RECORD_TYPE:
    case UNION_TYPE:
    case ENUMERAL_TYPE:
      dump_type (t, v);
      break;
    case TYPE_EXPR:
      my_friendly_abort (69);
      break;
      /* These special cases are duplicated here so that other functions
	 can feed identifiers to cp_error and get them demangled properly.  */
      { tree f;
	if (DESTRUCTOR_NAME_P (t)
	    && (f = ident_fndecl (t))
	    && DECL_LANGUAGE (f) == lang_cplusplus)
	    OB_PUTC ('~');
	    dump_decl (DECL_NAME (f), 0);
	else if (IDENTIFIER_TYPENAME_P (t))
	    OB_PUTS ("operator ");
	    /* Not exactly IDENTIFIER_TYPE_VALUE.  */
	    dump_type (TREE_TYPE (t), 0);
	    break;
	else if (IDENTIFIER_OPNAME_P (t))
	    char *name_string = operator_name_string (t);
	    OB_PUTCP (name_string);
	else
	  OB_PUTID (t);
      break;
    case OVERLOAD:
      t = OVL_CURRENT (t);
      /* Fall through.  */
    case FUNCTION_DECL:
      if (GLOBAL_IORD_P (DECL_ASSEMBLER_NAME (t)))
	dump_global_iord (DECL_ASSEMBLER_NAME (t));
      else if (! DECL_LANG_SPECIFIC (t))
	OB_PUTS ("{internal}");
      else
	dump_function_decl (t, v);
      break;
    case TEMPLATE_DECL:
	tree orig_args = DECL_TEMPLATE_PARMS (t);
	tree args;
	int i;
	for (args = orig_args = nreverse (orig_args);
	     args;
	     args = TREE_CHAIN (args))
	    int len = TREE_VEC_LENGTH (TREE_VALUE (args));
	    OB_PUTS ("template <");
	    for (i = 0; i < len; i++)
		tree arg = TREE_VEC_ELT (TREE_VALUE (args), i);
		tree defval = TREE_PURPOSE (arg);
		arg = TREE_VALUE (arg);
		if (TREE_CODE (arg) == TYPE_DECL)
		    if (DECL_NAME (arg))
			OB_PUTS ("class ");
			OB_PUTID (DECL_NAME (arg));
		    else
		      OB_PUTS ("class");
		else
		  dump_decl (arg, 1);
		if (defval)
		    OB_PUTS (" = ");
		      dump_type (defval, 1);
		    else
		      dump_expr (defval, 1);
	    if (len != 0)
	      OB_UNPUT (2);
	    OB_PUTC (' ');
	nreverse(orig_args);
	if (TREE_CODE (DECL_TEMPLATE_RESULT (t)) == TYPE_DECL)
	else if (TREE_CODE (DECL_TEMPLATE_RESULT (t)) == VAR_DECL)
	  dump_decl (DECL_TEMPLATE_RESULT (t), v);
	else if (TREE_TYPE (t) == NULL_TREE)
	   my_friendly_abort (353);
	else switch (NEXT_CODE (t))
	  case METHOD_TYPE:
	  case FUNCTION_TYPE:
	    break;
	  default:
	    /* This case can occur with some illegal code.  */
      break;
    case TEMPLATE_ID_EXPR:
	tree args;
	tree name = TREE_OPERAND (t, 0);
	if (is_overloaded_fn (name))
	  name = DECL_NAME (get_first_fn (name));
	dump_decl (name, v);
	OB_PUTC ('<');
	for (args = TREE_OPERAND (t, 1); args; args = TREE_CHAIN (args))
	    if (TREE_CODE_CLASS (TREE_CODE (TREE_VALUE (args))) == 't'
		|| TREE_CODE (TREE_VALUE (args)) == TEMPLATE_DECL)
	      dump_type (TREE_VALUE (args), 0);
	    else
	      dump_expr (TREE_VALUE (args), 0);
	    if (TREE_CHAIN (args))
      break;
    case LOOKUP_EXPR:
      break;
    case LABEL_DECL:
      break;
    case CONST_DECL:
      if ((TREE_TYPE (t) != NULL_TREE && NEXT_CODE (t) == ENUMERAL_TYPE)
	  || (DECL_INITIAL (t) &&
	      TREE_CODE (DECL_INITIAL (t)) == TEMPLATE_PARM_INDEX))
      else if (DECL_NAME (t))
      else if (DECL_INITIAL (t))
	dump_expr (DECL_INITIAL (t), 0);
      else
	OB_PUTS ("enumerator");
      break;
    case USING_DECL:
      OB_PUTS ("using ");
      dump_type (DECL_INITIAL (t), 0);
      OB_PUTS ("::");
      break;
    default:
      sorry ("`%s' not supported by dump_decl",
/* Pretty print a function decl. There are several ways we want to print a
   function declaration. We use V to tell us what.
     V    - 01 23
   args   - ++ ++
   retval - -+ ++
   default- -+ -+
   throw  - -- ++
   As cp_error can only apply the '#' flag once to give 0 and 1 for V, there
   is %D which doesn't print the throw specs, and %F which does. */
static void
     tree t;
     int v;
  tree name;
  tree fntype;
  tree parmtypes;
  tree cname = NULL_TREE;
  if (TREE_CODE (t) == TEMPLATE_DECL)
    t = DECL_TEMPLATE_RESULT (t);
  name = DECL_ASSEMBLER_NAME (t);
  fntype = TREE_TYPE (t);
  parmtypes = TYPE_ARG_TYPES (fntype);
  /* Friends have DECL_CLASS_CONTEXT set, but not DECL_CONTEXT.  */
  if (DECL_CLASS_SCOPE_P (t))
    cname = DECL_CLASS_CONTEXT (t);
  /* this is for partially instantiated template methods */
  else if (TREE_CODE (fntype) == METHOD_TYPE)
    cname = TREE_TYPE (TREE_VALUE (parmtypes));
  /* Print the return type.  */
  if (v > 0)
      if (DECL_STATIC_FUNCTION_P (t))
	OB_PUTS ("static ");
      if (! DECL_CONV_FN_P (t)
	  && ! DECL_CONSTRUCTOR_P (t)
	  && ! DECL_DESTRUCTOR_P (t))
	  dump_type_prefix (TREE_TYPE (fntype), 1, 0);
	  OB_PUTC (' ');
  /* Print the function name.  */
  if (cname)
      dump_type (cname, 0);
      if (TREE_CODE (fntype) == METHOD_TYPE && parmtypes)
	parmtypes = TREE_CHAIN (parmtypes);
      if (DECL_CONSTRUCTOR_FOR_VBASE_P (t))
	/* Skip past "in_charge" identifier.  */
  else if (CP_DECL_CONTEXT (t) != global_namespace)
      OB_PUTC2 (':',':');
  if (DESTRUCTOR_NAME_P (name) && DECL_LANGUAGE (t) == lang_cplusplus)
  dump_function_name (t);
  /* If V is negative, we don't print the argument types.  */
  if (v < 0)
    return;
  dump_parameters (parmtypes, v & 1, 0);
  if (v && ! DECL_CONV_FN_P (t))
    dump_type_suffix (TREE_TYPE (fntype), 1, 0);
      if (IS_SIGNATURE (cname))
	/* We look at the type pointed to by the `optr' field of `this.'  */
	dump_qualifiers
	  (TREE_TYPE (TREE_TYPE (TYPE_FIELDS (TREE_VALUE (TYPE_ARG_TYPES (fntype))))), before);
      else
	dump_qualifiers
	  (TREE_TYPE (TREE_VALUE (TYPE_ARG_TYPES (fntype))), before);
  if (v >= 2)
    dump_exception_spec (TYPE_RAISES_EXCEPTIONS (fntype), 0);
/* Print a parameter list. V indicates if we show default values or not. If
   these are for a member function, the member object ptr
   (and any other hidden args) should have already been removed. */
static void
dump_parameters (parmtypes, v, canonical_name)
     tree parmtypes;
     int v;
     int canonical_name;
  int first;
  OB_PUTC ('(');
  for (first = 1; parmtypes != void_list_node;
       parmtypes = TREE_CHAIN (parmtypes))
      if (!first)
      first = 0;
      if (!parmtypes)
          OB_PUTS ("...");
          break;
      dump_type_real (TREE_VALUE (parmtypes), 0, canonical_name);
      if (TREE_PURPOSE (parmtypes) && v)
          OB_PUTS (" = ");
          dump_expr (TREE_PURPOSE (parmtypes), 0);
  OB_PUTC (')');
/* Print an exception specification. T is the exception specification. */
static void
dump_exception_spec (t, canonical_name)
     tree t;
     int canonical_name;
  if (t)
      OB_PUTS (" throw (");
      if (TREE_VALUE (t) != NULL_TREE)
        while (1)
            dump_type_real (TREE_VALUE (t), 0, canonical_name);
            t = TREE_CHAIN (t);
            if (!t)
              break;
      OB_PUTC (')');
/* Handle the function name for a FUNCTION_DECL node, grokking operators
   and destructors properly.  */
static void
     tree t;
  tree name = DECL_NAME (t);
  if (DECL_DESTRUCTOR_P (t))
      OB_PUTC ('~');
      dump_decl (name, 0);
  else if (DECL_CONV_FN_P (t))
      /* This cannot use the hack that the operator's return
	 type is stashed off of its name because it may be
	 used for error reporting.  In the case of conflicting
	 declarations, both will have the same name, yet
	 the types will be different, hence the TREE_TYPE field
	 of the first name will be clobbered by the second.  */
      dump_type (TREE_TYPE (TREE_TYPE (t)), 0);
  else if (IDENTIFIER_OPNAME_P (name))
      char *name_string = operator_name_string (name);
  else
  if (DECL_LANG_SPECIFIC (t) && DECL_USE_TEMPLATE (t)
      && DECL_TEMPLATE_INFO (t)
      && (DECL_TEMPLATE_SPECIALIZATION (t)
	  || TREE_CODE (DECL_TI_TEMPLATE (t)) != TEMPLATE_DECL
	  || DECL_TEMPLATE_SPECIALIZATION (DECL_TI_TEMPLATE (t))
	  || PRIMARY_TEMPLATE_P (DECL_TI_TEMPLATE (t))))
      tree args = DECL_TEMPLATE_INFO (t) ? DECL_TI_ARGS (t) : NULL_TREE;
      OB_PUTC ('<');
      /* Be careful only to print things when we have them, so as not
	 to crash producing error messages.  */
      if (args)
	  if (TREE_CODE (args) == TREE_LIST)
	      tree arg;
	      int need_comma = 0;
	      for (arg = args; arg; arg = TREE_CHAIN (arg))
		  tree a = TREE_VALUE (arg);
		  if (need_comma)
		    OB_PUTS (", ");
		  if (a)
		      if (TREE_CODE_CLASS (TREE_CODE (a)) == 't'
			  || TREE_CODE (a) == TEMPLATE_DECL)
			dump_type (a, 0);
		      else
			dump_expr (a, 0);
		  need_comma = 1;
	  else if (TREE_CODE (args) == TREE_VEC)
	      int i;
	      int need_comma = 0;
	      if (TREE_VEC_LENGTH (args) > 0
		  && TREE_CODE (TREE_VEC_ELT (args, 0)) == TREE_VEC)
		args = TREE_VEC_ELT (args,
				     TREE_VEC_LENGTH (args) - 1);
		  tree a = TREE_VEC_ELT (args, i);
		  if (need_comma)
		    OB_PUTS (", ");
		  if (a)
			dump_type (a, 0);
		      else
			dump_expr (a, 0);
		  need_comma = 1;
static void
dump_char (c)
     int c;
  switch (c)
    case TARGET_NEWLINE:
      OB_PUTS ("\\n");
      break;
    case TARGET_TAB:
      OB_PUTS ("\\t");
      break;
    case TARGET_VT:
      OB_PUTS ("\\v");
      break;
    case TARGET_BS:
      OB_PUTS ("\\b");
      break;
    case TARGET_CR:
      OB_PUTS ("\\r");
      break;
    case TARGET_FF:
      OB_PUTS ("\\f");
      break;
    case TARGET_BELL:
      OB_PUTS ("\\a");
      break;
    case '\\':
      OB_PUTS ("\\\\");
      break;
    case '\'':
      OB_PUTS ("\\'");
      break;
    case '\"':
      OB_PUTS ("\\\"");
      break;
    default:
      if (ISPRINT (c))
	OB_PUTC (c);
      else
	  sprintf (digit_buffer, "\\%03o", (int) c);
/* Print out a list of initializers (subr of dump_expr) */
static void
dump_expr_list (l)
     tree l;
  while (l)
      dump_expr (TREE_VALUE (l), 0);
      if (TREE_CHAIN (l))
      l = TREE_CHAIN (l);
/* Print out an expression */
static void
dump_expr (t, nop)
     tree t;
     int nop;			/* suppress parens */
    case VAR_DECL:
    case PARM_DECL:
    case FIELD_DECL:
    case CONST_DECL:
    case FUNCTION_DECL:
    case TEMPLATE_DECL:
      dump_decl (t, -1);
      break;
    case INTEGER_CST:
	tree type = TREE_TYPE (t);
	my_friendly_assert (type != 0, 81);
	/* If it's an enum, output its tag, rather than its value.  */
	if (TREE_CODE (type) == ENUMERAL_TYPE)
	    char *p = enum_name_string (t, type);
	    OB_PUTCP (p);
	else if (type == boolean_type_node)
	    if (t == boolean_false_node
		|| (TREE_INT_CST_LOW (t) == 0
		    && TREE_INT_CST_HIGH (t) == 0))
	      OB_PUTS ("false");
	    else if (t == boolean_true_node)
	      OB_PUTS ("true");
	else if (type == char_type_node)
	    OB_PUTC ('\'');
	    dump_char (TREE_INT_CST_LOW (t));
	    OB_PUTC ('\'');
	else if (TREE_INT_CST_HIGH (t)
		 != (TREE_INT_CST_LOW (t) >> (HOST_BITS_PER_WIDE_INT - 1)))
	    tree val = t;
	    if (TREE_INT_CST_HIGH (val) < 0)
		OB_PUTC ('-');
		val = build_int_2 (~TREE_INT_CST_LOW (val),
				   -TREE_INT_CST_HIGH (val));
	    /* Would "%x%0*x" or "%x%*0x" get zero-padding on all
	       systems?  */
	      static char format[10]; /* "%x%09999x\0" */
	      if (!format[0])
		sprintf (format, "%%x%%0%dx", HOST_BITS_PER_INT / 4);
	      sprintf (digit_buffer, format, TREE_INT_CST_HIGH (val),
		       TREE_INT_CST_LOW (val));
	else
	  OB_PUTI (TREE_INT_CST_LOW (t));
      break;
    case REAL_CST:
#ifndef REAL_IS_NOT_DOUBLE
      sprintf (digit_buffer, "%g", TREE_REAL_CST (t));
#else
	unsigned char *p = (unsigned char *) &TREE_REAL_CST (t);
	size_t i;
	strcpy (digit_buffer, "0x");
	for (i = 0; i < sizeof TREE_REAL_CST (t); i++)
	  sprintf (digit_buffer + 2 + 2*i, "%02x", *p++);
#endif
      break;
    case PTRMEM_CST:
      OB_PUTC ('&');
      dump_type (PTRMEM_CST_CLASS (t), 0);
      OB_PUTS ("::");
      OB_PUTID (DECL_NAME (PTRMEM_CST_MEMBER (t)));
      break;
    case STRING_CST:
	char *p = TREE_STRING_POINTER (t);
	int len = TREE_STRING_LENGTH (t) - 1;
	int i;
	OB_PUTC ('\"');
	  dump_char (p[i]);
	OB_PUTC ('\"');
      break;
    case COMPOUND_EXPR:
      dump_binary_op (",", t);
      break;
    case COND_EXPR:
      OB_PUTC ('(');
      dump_expr (TREE_OPERAND (t, 0), 0);
      OB_PUTS (" ? ");
      dump_expr (TREE_OPERAND (t, 1), 0);
      OB_PUTS (" : ");
      dump_expr (TREE_OPERAND (t, 2), 0);
      OB_PUTC (')');
      break;
    case SAVE_EXPR:
      if (TREE_HAS_CONSTRUCTOR (t))
	  OB_PUTS ("new ");
      else
      break;
    case AGGR_INIT_EXPR:
      OB_PUTID (TYPE_IDENTIFIER (TREE_TYPE (t)));
      OB_PUTC ('(');
      if (TREE_OPERAND (t, 1))
	dump_expr_list (TREE_CHAIN (TREE_OPERAND (t, 1)));
      OB_PUTC (')');
      break;
    case CALL_EXPR:
	tree fn = TREE_OPERAND (t, 0);
	tree args = TREE_OPERAND (t, 1);
	if (TREE_CODE (fn) == ADDR_EXPR)
	  fn = TREE_OPERAND (fn, 0);
	if (TREE_TYPE (fn) != NULL_TREE && NEXT_CODE (fn) == METHOD_TYPE)
	    tree ob = TREE_VALUE (args);
	    if (TREE_CODE (ob) == ADDR_EXPR)
		dump_expr (TREE_OPERAND (ob, 0), 0);
		OB_PUTC ('.');
	    else if (TREE_CODE (ob) != PARM_DECL
		     || strcmp (IDENTIFIER_POINTER (DECL_NAME (ob)), "this"))
		dump_expr (ob, 0);
		OB_PUTC2 ('-', '>');
	    args = TREE_CHAIN (args);
	dump_expr (fn, 0);
	OB_PUTC ('(');
	dump_expr_list (args);
	OB_PUTC (')');
      break;
    case NEW_EXPR:
	tree type = TREE_OPERAND (t, 1);
	if (NEW_EXPR_USE_GLOBAL (t))
	  OB_PUTS ("::");
	OB_PUTS ("new ");
	if (TREE_OPERAND (t, 0))
	    OB_PUTC ('(');
	    dump_expr_list (TREE_OPERAND (t, 0));
	    OB_PUTS (") ");
	if (TREE_CODE (type) == ARRAY_REF)
	  type = build_cplus_array_type
	    (TREE_OPERAND (type, 0),
	     build_index_type (size_binop (MINUS_EXPR, TREE_OPERAND (type, 1),
					   integer_one_node)));
	dump_type (type, 0);
	if (TREE_OPERAND (t, 2))
	    OB_PUTC ('(');
	    dump_expr_list (TREE_OPERAND (t, 2));
	    OB_PUTC (')');
      break;
    case TARGET_EXPR:
      /* Note that this only works for G++ target exprs.  If somebody
	 builds a general TARGET_EXPR, there's no way to represent that
	 it initializes anything other that the parameter slot for the
	 default argument.  Note we may have cleared out the first
	 operand in expand_expr, so don't go killing ourselves.  */
      break;
    case MODIFY_EXPR:
    case PLUS_EXPR:
    case MINUS_EXPR:
    case MULT_EXPR:
    case TRUNC_DIV_EXPR:
    case TRUNC_MOD_EXPR:
    case MIN_EXPR:
    case MAX_EXPR:
    case LSHIFT_EXPR:
    case RSHIFT_EXPR:
    case BIT_IOR_EXPR:
    case BIT_XOR_EXPR:
    case BIT_AND_EXPR:
    case BIT_ANDTC_EXPR:
    case TRUTH_ANDIF_EXPR:
    case TRUTH_ORIF_EXPR:
    case LT_EXPR:
    case LE_EXPR:
    case GT_EXPR:
    case GE_EXPR:
    case EQ_EXPR:
    case NE_EXPR:
      dump_binary_op (opname_tab[(int) TREE_CODE (t)], t);
      break;
    case CEIL_DIV_EXPR:
    case FLOOR_DIV_EXPR:
    case ROUND_DIV_EXPR:
      dump_binary_op ("/", t);
      break;
    case CEIL_MOD_EXPR:
    case FLOOR_MOD_EXPR:
    case ROUND_MOD_EXPR:
      dump_binary_op ("%", t);
      break;
    case COMPONENT_REF:
	tree ob = TREE_OPERAND (t, 0);
	if (TREE_CODE (ob) == INDIRECT_REF)
	    ob = TREE_OPERAND (ob, 0);
		dump_expr (ob, 0);
	else
	    dump_expr (ob, 0);
	    OB_PUTC ('.');
	dump_expr (TREE_OPERAND (t, 1), 1);
      break;
    case ARRAY_REF:
      OB_PUTC ('[');
      OB_PUTC (']');
      break;
    case CONVERT_EXPR:
      dump_unary_op ("+", t, nop);
      break;
    case ADDR_EXPR:
      if (TREE_CODE (TREE_OPERAND (t, 0)) == FUNCTION_DECL
	  || TREE_CODE (TREE_OPERAND (t, 0)) == STRING_CST)
      else
	dump_unary_op ("&", t, nop);
      break;
    case INDIRECT_REF:
	  t = TREE_OPERAND (t, 0);
	  my_friendly_assert (TREE_CODE (t) == CALL_EXPR, 237);
	  OB_PUTC ('(');
	  OB_PUTC (')');
      else
	  if (TREE_OPERAND (t,0) != NULL_TREE
	      && TREE_TYPE (TREE_OPERAND (t, 0))
	      && NEXT_CODE (TREE_OPERAND (t, 0)) == REFERENCE_TYPE)
	    dump_expr (TREE_OPERAND (t, 0), nop);
	  else
	    dump_unary_op ("*", t, nop);
      break;
    case NEGATE_EXPR:
    case BIT_NOT_EXPR:
    case TRUTH_NOT_EXPR:
    case PREDECREMENT_EXPR:
    case PREINCREMENT_EXPR:
      dump_unary_op (opname_tab [(int)TREE_CODE (t)], t, nop);
      break;
    case POSTDECREMENT_EXPR:
    case POSTINCREMENT_EXPR:
      OB_PUTC ('(');
      OB_PUTCP (opname_tab[(int)TREE_CODE (t)]);
      OB_PUTC (')');
      break;
    case NON_LVALUE_EXPR:
      /* FIXME: This is a KLUDGE workaround for a parsing problem.  There
	 should be another level of INDIRECT_REF so that I don't have to do
	 this.  */
      if (TREE_TYPE (t) != NULL_TREE && NEXT_CODE (t) == POINTER_TYPE)
	  tree next = TREE_TYPE (TREE_TYPE (t));
	  while (TREE_CODE (next) == POINTER_TYPE)
	    next = TREE_TYPE (next);
	  if (TREE_CODE (next) == FUNCTION_TYPE)
	      if (!nop) OB_PUTC ('(');
	      OB_PUTC ('*');
	      dump_expr (TREE_OPERAND (t, 0), 1);
	      if (!nop) OB_PUTC (')');
	      break;
	  /* else FALLTHRU */
      break;
    case NOP_EXPR:
      break;
    case CONSTRUCTOR:
      if (TREE_TYPE (t) && TYPE_PTRMEMFUNC_P (TREE_TYPE (t)))
	  tree idx = build_component_ref (t, index_identifier, NULL_TREE, 0);
	  if (integer_all_onesp (idx))
	      tree pfn = PFN_FROM_PTRMEMFUNC (t);
	      dump_unary_op ("&", pfn, 0);
	      break;
	  else if (TREE_CODE (idx) == INTEGER_CST
		   && tree_int_cst_equal (idx, integer_zero_node))
	      /* A NULL pointer-to-member constant.  */
	      OB_PUTS ("((");
	      OB_PUTS (") 0)");
	      break;
		   && TREE_INT_CST_HIGH (idx) == 0)
	      tree virtuals;
	      unsigned HOST_WIDE_INT n;
	      t = TREE_TYPE (TYPE_PTRMEMFUNC_FN_TYPE (TREE_TYPE (t)));
	      t = TYPE_METHOD_BASETYPE (t);
	      virtuals = BINFO_VIRTUALS (TYPE_BINFO (TYPE_MAIN_VARIANT (t)));
	      n = TREE_INT_CST_LOW (idx);
	      /* Map vtable index back one, to allow for the null pointer to
		 member.  */
	      --n;
	      while (n > 0 && virtuals)
		  --n;
		  virtuals = TREE_CHAIN (virtuals);
	      if (virtuals)
		  dump_expr (FNADDR_FROM_VTABLE_ENTRY (TREE_VALUE (virtuals)), 0);
		  break;
      OB_PUTC ('{');
      dump_expr_list (CONSTRUCTOR_ELTS (t));
      OB_PUTC ('}');
      break;
    case OFFSET_REF:
	if (is_dummy_object (ob))
	    t = TREE_OPERAND (t, 1);
	    if (TREE_CODE (t) == FUNCTION_DECL)
	      /* A::f */
	      dump_expr (t, 0);
	    else if (BASELINK_P (t))
	      dump_expr (OVL_CURRENT (TREE_VALUE (t)), 0);
	    else
	      dump_decl (t, 0);
	else
		OB_PUTS (" ->* ");
	    else
		dump_expr (ob, 0);
		OB_PUTS (" .* ");
	break;
    case TEMPLATE_PARM_INDEX:
      dump_decl (TEMPLATE_PARM_DECL (t), -1);
      break;
      OB_PUTID (t);
      break;
    case SCOPE_REF:
      dump_type (TREE_OPERAND (t, 0), 0);
      OB_PUTS ("::");
      break;
    case CAST_EXPR:
      if (TREE_OPERAND (t, 0) == NULL_TREE
	  || TREE_CHAIN (TREE_OPERAND (t, 0)))
	  OB_PUTC ('(');
	  OB_PUTC (')');
      else
	  OB_PUTC ('(');
	  OB_PUTC (')');
	  OB_PUTC ('(');
	  OB_PUTC (')');
      break;
    case LOOKUP_EXPR:
      OB_PUTID (TREE_OPERAND (t, 0));
      break;
    case ARROW_EXPR:
      OB_PUTS ("->");
      break;
    case SIZEOF_EXPR:
    case ALIGNOF_EXPR:
      if (TREE_CODE (t) == SIZEOF_EXPR)
	OB_PUTS ("sizeof (");
      else
	  my_friendly_assert (TREE_CODE (t) == ALIGNOF_EXPR, 0);
	  OB_PUTS ("__alignof__ (");
      if (TREE_CODE_CLASS (TREE_CODE (TREE_OPERAND (t, 0))) == 't')
      else
	dump_unary_op ("*", t, 0);
      OB_PUTC (')');
      break;
    case DEFAULT_ARG:
      OB_PUTS ("{unparsed}");
      break;
    case TRY_CATCH_EXPR:
    case WITH_CLEANUP_EXPR:
    case CLEANUP_POINT_EXPR:
      break;
      dump_decl (t, 0);
      break;
    case BIND_EXPR:
      OB_PUTS ("{ ");
      dump_expr (TREE_OPERAND (t, 1), nop);
      OB_PUTS ("} ");
      break;
    case LOOP_EXPR:
      OB_PUTS ("while (1) { ");
      OB_PUTS ("} ");
      break;
    case EXIT_EXPR:
      OB_PUTS ("if (");
      OB_PUTS (") break; ");
      break;
    case TREE_LIST:
      if (TREE_VALUE (t) && TREE_CODE (TREE_VALUE (t)) == FUNCTION_DECL)
	  OB_PUTID (DECL_NAME (TREE_VALUE (t)));
	  break;
      /*  This list is incomplete, but should suffice for now.
	  It is very important that `sorry' does not call
	  `report_error_function'.  That could cause an infinite loop.  */
    default:
      sorry ("`%s' not supported by dump_expr",
      /* fall through to ERROR_MARK...  */
    case ERROR_MARK:
      OB_PUTCP ("{error}");
      break;
static void
dump_binary_op (opstring, t)
     char *opstring;
     tree t;
  OB_PUTC ('(');
  OB_PUTC (' ');
  OB_PUTCP (opstring);
  OB_PUTC (' ');
  OB_PUTC (')');
static void
dump_unary_op (opstring, t, nop)
     char *opstring;
     tree t;
     int nop;
/* Print a function decl with exception specification included. */
char *
fndecl_as_string (fndecl, print_default_args_p)
     tree fndecl;
     int print_default_args_p;
  OB_INIT ();
  dump_function_decl (fndecl, 2 + print_default_args_p);
  OB_FINISH ();
  return (char *)obstack_base (&scratch_obstack);
/* Same, but handle a _TYPE.
   Called from convert_to_reference, mangle_class_name_for_template,
   build_unary_op, and GNU_xref_decl.  If CANONICAL_NAME is non-zero,
   when describing a typedef, we use the name of the type described,
   rather than the name of the typedef.  */
char *
type_as_string_real (typ, v, canonical_name)
     tree typ;
     int v;
     int canonical_name;
  OB_INIT ();
  dump_type_real (typ, v, canonical_name);
  OB_FINISH ();
char *
type_as_string (typ, v)
     tree typ;
     int v;
  return type_as_string_real (typ, v, 0);
char *
expr_as_string (decl, v)
     tree decl;
     int v ATTRIBUTE_UNUSED;
  OB_INIT ();
  dump_expr (decl, 1);
  OB_FINISH ();
/* A cross between type_as_string and fndecl_as_string.
   Only called from substitute_nice_name.  */
char *
decl_as_string (decl, v)
     tree decl;
     int v;
  OB_INIT ();
  dump_decl (decl, v);
  OB_FINISH ();
/* Generate the three forms of printable names for lang_printable_name.  */
char *
lang_decl_name (decl, v)
     tree decl;
     int v;
  if (v >= 2)
    return decl_as_string (decl, 1);
  OB_INIT ();
  if (v == 1 && DECL_CLASS_SCOPE_P (decl))
      tree cname;
      if (TREE_CODE (decl) == FUNCTION_DECL)
	cname = DECL_CLASS_CONTEXT (decl);
      else
	cname = DECL_CONTEXT (decl);
    dump_function_name (decl);
  else
    dump_decl (DECL_NAME (decl), 0);
  OB_FINISH ();
char *
cp_file_of (t)
     tree t;
  if (TREE_CODE (t) == PARM_DECL && DECL_CONTEXT (t))
    return DECL_SOURCE_FILE (DECL_CONTEXT (t));
  else if (TREE_CODE_CLASS (TREE_CODE (t)) == 't')
    return DECL_SOURCE_FILE (TYPE_MAIN_DECL (t));
  else if (TREE_CODE (t) == OVERLOAD)
    return DECL_SOURCE_FILE (OVL_FUNCTION (t));
  else
    return DECL_SOURCE_FILE (t);
int
cp_line_of (t)
     tree t;
  int line = 0;
    line = DECL_SOURCE_LINE (DECL_CONTEXT (t));
  if (TREE_CODE (t) == TYPE_DECL && DECL_ARTIFICIAL (t)
      && TYPE_MAIN_DECL (TREE_TYPE (t)))
    t = TREE_TYPE (t);
    line = DECL_SOURCE_LINE (TYPE_MAIN_DECL (t));
    line = DECL_SOURCE_LINE (OVL_FUNCTION (t));
  else
    line = DECL_SOURCE_LINE (t);
  if (line == 0)
    return lineno;
  return line;
char *
code_as_string (c, v)
     enum tree_code c;
  return tree_code_name [c];
char *
language_as_string (c, v)
     enum languages c;
  switch (c)
    case lang_c:
      return "C";
    case lang_cplusplus:
      return "C++";
    case lang_java:
      return "Java";
    default:
      my_friendly_abort (355);
      return 0;
/* Return the proper printed version of a parameter to a C++ function.  */
char *
parm_as_string (p, v)
     int p;
  if (p < 0)
    return "`this'";
  sprintf (digit_buffer, "%d", p+1);
  return digit_buffer;
char *
op_as_string (p, v)
     enum tree_code p;
  static char buf[] = "operator                ";
  if (p == 0)
    return "{unknown}";
  strcpy (buf + 9, opname_tab [p]);
  return buf;
char *
assop_as_string (p, v)
     enum tree_code p;
  if (p == 0)
    return "{unknown}";
  strcpy (buf + 9, assignop_tab [p]);
  return buf;
char *
args_as_string (p, v)
     tree p;
     int v;
  if (p == NULL_TREE)
    return "";
  if (TREE_CODE_CLASS (TREE_CODE (TREE_VALUE (p))) == 't')
    return type_as_string (p, v);
  OB_INIT ();
  for (; p; p = TREE_CHAIN (p))
      if (TREE_VALUE (p) == null_node)
	OB_PUTS ("NULL");
      else
	dump_type (error_type (TREE_VALUE (p)), v);
      if (TREE_CHAIN (p))
	OB_PUTS (", ");
  OB_FINISH ();
char *
cv_as_string (p, v)
     tree p;
  OB_INIT ();
  dump_qualifiers (p, before);
  OB_FINISH ();
/* Build expressions with type checking for C++ compiler.
   Copyright (C) 1987, 88, 89, 92-98, 1999 Free Software Foundation, Inc.
   Hacked by Michael Tiemann ([email protected])
any later version.
/* This file is part of the C++ front end.
   It contains routines to build C++ expressions given their operands,
   including computing the types of the result, C and C++ specific error
   checks, and some optimization.
   There are also routines to build RETURN_STMT nodes and CASE_STMT nodes,
   and to process initializations in declarations (since they work
   like a strange sort of assignment).  */
#include "config.h"
#include "system.h"
#include "tree.h"
#include "rtl.h"
#include "flags.h"
#include "output.h"
#include "expr.h"
#include "toplev.h"
static tree convert_for_assignment PROTO((tree, tree, const char *, tree,
					  int));
static tree pointer_int_sum PROTO((enum tree_code, tree, tree));
static tree rationalize_conditional_expr PROTO((enum tree_code, tree));
static int comp_target_parms PROTO((tree, tree, int));
static int comp_ptr_ttypes_real PROTO((tree, tree, int));
static int comp_ptr_ttypes_const PROTO((tree, tree));
static int comp_ptr_ttypes_reinterpret PROTO((tree, tree));
static int comp_array_types PROTO((int (*) (tree, tree, int), tree,
				   tree, int));
static tree common_base_type PROTO((tree, tree));
#if 0
static tree convert_sequence PROTO((tree, tree));
#endif
static tree lookup_anon_field PROTO((tree, tree));
static tree pointer_diff PROTO((tree, tree, tree));
static tree build_component_addr PROTO((tree, tree));
static tree qualify_type PROTO((tree, tree));
static tree get_delta_difference PROTO((tree, tree, int));
static int comp_cv_target_types PROTO((tree, tree, int));
static void casts_away_constness_r PROTO((tree *, tree *));
static int casts_away_constness PROTO ((tree, tree));
/* Return the target type of TYPE, which meas return T for:
   T*, T&, T[], T (...), and otherwise, just T.  */
tree
target_type (type)
     tree type;
  if (TREE_CODE (type) == REFERENCE_TYPE)
    type = TREE_TYPE (type);
  while (TREE_CODE (type) == POINTER_TYPE
	 || TREE_CODE (type) == ARRAY_TYPE
	 || TREE_CODE (type) == FUNCTION_TYPE
	 || TREE_CODE (type) == METHOD_TYPE
	 || TREE_CODE (type) == OFFSET_TYPE)
  return type;
/* Do `exp = require_complete_type (exp);' to make sure exp
   does not have an incomplete type.  (That includes void types.)
   Returns the error_mark_node if the VALUE does not have
   complete type when this function returns.  */
tree
require_complete_type (value)
     tree value;
  tree type;
  if (processing_template_decl || value == error_mark_node)
    return value;
  if (TREE_CODE (value) == OVERLOAD)
    type = unknown_type_node;
  else
    type = TREE_TYPE (value);
  /* First, detect a valid value with a complete type.  */
  if (TYPE_SIZE (type) != 0
      && TYPE_SIZE (type) != size_zero_node
      && ! (TYPE_LANG_SPECIFIC (type)
	    && (IS_SIGNATURE_POINTER (type) || IS_SIGNATURE_REFERENCE (type))
	    && TYPE_SIZE (SIGNATURE_TYPE (type)) == 0))
    return value;
  /* If we see X::Y, we build an OFFSET_TYPE which has
     not been laid out.  Try to avoid an error by interpreting
     it as this->X::Y, if reasonable.  */
  if (TREE_CODE (value) == OFFSET_REF
      && current_class_ref != 0
      && TREE_OPERAND (value, 0) == current_class_ref)
      tree base, member = TREE_OPERAND (value, 1);
      tree basetype = TYPE_OFFSET_BASETYPE (type);
      my_friendly_assert (TREE_CODE (member) == FIELD_DECL, 305);
      base = convert_pointer_to (basetype, current_class_ptr);
      value = build (COMPONENT_REF, TREE_TYPE (member),
		     build_indirect_ref (base, NULL_PTR), member);
      return require_complete_type (value);
  if (complete_type_or_else (type, value))
    return value;
  else
    return error_mark_node;
/* Makes sure EXPR is a complete type when used in a void context, like a
   whole expression, or lhs of a comma operator. Issue a diagnostic and
   return error_mark_node on failure. This is a little tricky, because some
   valid void types look stunningly similar to invalid void types. We err on
   the side of caution */
tree
require_complete_type_in_void (expr)
     tree expr;
  switch (TREE_CODE (expr))
    case COND_EXPR:
        tree op;
        op = TREE_OPERAND (expr,2);
        op = require_complete_type_in_void (op);
        TREE_OPERAND (expr,2) = op;
        if (op == error_mark_node)
            expr = op;
            break;
        /* fallthrough */
    case COMPOUND_EXPR:
        tree op;
        op = TREE_OPERAND (expr,1);
        TREE_OPERAND (expr,1) = op;
            expr = op;
            break;
        break;
    case NOP_EXPR:
        tree op;
        op = TREE_OPERAND (expr,0);
        TREE_OPERAND (expr,0) = op;
            expr = op;
            break;
        break;
    case CALL_EXPR:   /* function call return can be ignored */
    case RTL_EXPR:    /* RTL nodes have no value */
    case DELETE_EXPR: /* delete expressions have no type */
    case VEC_DELETE_EXPR:
    case INTEGER_CST: /* used for null pointer */
    case EXIT_EXPR:   /* have no return */
    case LOOP_EXPR:   /* have no return */
    case BIND_EXPR:   /* have no return */
    case THROW_EXPR:  /* have no return */
    case MODIFY_EXPR: /* sometimes this has a void type, but that's ok */
    case CONVERT_EXPR:  /* sometimes has a void type */
      break;
    case INDIRECT_REF:
        tree op = TREE_OPERAND (expr,0);
        /* Calling a function returning a reference has an implicit
           dereference applied. We don't want to make that an error. */
        if (TREE_CODE (op) == CALL_EXPR
            && TREE_CODE (TREE_TYPE (op)) == REFERENCE_TYPE)
          break;
        /* else fallthrough */
    default:
      expr = require_complete_type (expr);
      break;
  return expr;
/* Try to complete TYPE, if it is incomplete.  For example, if TYPE is
   a template instantiation, do the instantiation.  Returns TYPE,
   whether or not it could be completed, unless something goes
   horribly wrong, in which case the error_mark_node is returned.  */
tree
complete_type (type)
     tree type;
  if (type == NULL_TREE)
    /* Rather than crash, we return something sure to cause an error
       at some point.  */
  if (type == error_mark_node || TYPE_SIZE (type) != NULL_TREE)
  else if (TREE_CODE (type) == ARRAY_TYPE && TYPE_DOMAIN (type))
      tree t = complete_type (TREE_TYPE (type));
      if (TYPE_SIZE (t) != NULL_TREE && ! processing_template_decl)
	layout_type (type);
      TYPE_NEEDS_CONSTRUCTING (type)
	= TYPE_NEEDS_CONSTRUCTING (TYPE_MAIN_VARIANT (t));
      TYPE_NEEDS_DESTRUCTOR (type)
	= TYPE_NEEDS_DESTRUCTOR (TYPE_MAIN_VARIANT (t));
  else if (CLASS_TYPE_P (type) && CLASSTYPE_TEMPLATE_INSTANTIATION (type))
    instantiate_class_template (TYPE_MAIN_VARIANT (type));
  return type;
/* Like complete_type, but issue an error if the TYPE cannot be
   completed.  VALUE is used for informative diagnostics.
   Returns NULL_TREE if the type cannot be made complete.  */
tree
     tree type;
     tree value;
  type = complete_type (type);
  if (type == error_mark_node)
    /* We already issued an error.  */
    return NULL_TREE;
  else if (!TYPE_SIZE (type) || TYPE_SIZE (type) == size_zero_node)
      incomplete_type_error (value, type);
      return NULL_TREE;
  else
    return type;
/* Return truthvalue of whether type of EXP is instantiated.  */
int
type_unknown_p (exp)
     tree exp;
  return (TREE_CODE (exp) == OVERLOAD
          || TREE_CODE (exp) == TREE_LIST
	  || TREE_TYPE (exp) == unknown_type_node
	  || (TREE_CODE (TREE_TYPE (exp)) == OFFSET_TYPE
	      && TREE_TYPE (TREE_TYPE (exp)) == unknown_type_node));
/* Return truthvalue of whether T is function (or pfn) type.  */
int
fntype_p (t)
     tree t;
  return (TREE_CODE (t) == FUNCTION_TYPE || TREE_CODE (t) == METHOD_TYPE
	      && (TREE_CODE (TREE_TYPE (t)) == FUNCTION_TYPE
		  || TREE_CODE (TREE_TYPE (t)) == METHOD_TYPE)));
/* Return a variant of TYPE which has all the type qualifiers of LIKE
   as well as those of TYPE.  */
static tree
qualify_type (type, like)
     tree type, like;
  /* @@ Must do member pointers here.  */
  return cp_build_qualified_type (type, (CP_TYPE_QUALS (type)
					 | CP_TYPE_QUALS (like)));
/* Return the common type of two parameter lists.
   We assume that comptypes has already been done and returned 1;
   if that isn't so, this may crash.
   As an optimization, free the space we allocate if the parameter
   lists are already common.  */
tree
commonparms (p1, p2)
     tree p1, p2;
  tree oldargs = p1, newargs, n;
  int i, len;
  int any_change = 0;
  char *first_obj = (char *) oballoc (0);
  len = list_length (p1);
  newargs = tree_last (p1);
  if (newargs == void_list_node)
    i = 1;
  else
      i = 0;
      newargs = 0;
  for (; i < len; i++)
    newargs = tree_cons (NULL_TREE, NULL_TREE, newargs);
  n = newargs;
  for (i = 0; p1;
       p1 = TREE_CHAIN (p1), p2 = TREE_CHAIN (p2), n = TREE_CHAIN (n), i++)
      if (TREE_PURPOSE (p1) && !TREE_PURPOSE (p2))
	  TREE_PURPOSE (n) = TREE_PURPOSE (p1);
	  any_change = 1;
      else if (! TREE_PURPOSE (p1))
	  if (TREE_PURPOSE (p2))
	      TREE_PURPOSE (n) = TREE_PURPOSE (p2);
	      any_change = 1;
      else
	  if (1 != simple_cst_equal (TREE_PURPOSE (p1), TREE_PURPOSE (p2)))
	    any_change = 1;
      if (TREE_VALUE (p1) != TREE_VALUE (p2))
	  any_change = 1;
	  TREE_VALUE (n) = common_type (TREE_VALUE (p1), TREE_VALUE (p2));
      else
	TREE_VALUE (n) = TREE_VALUE (p1);
  if (! any_change)
      obfree (first_obj);
      return oldargs;
  return newargs;
/* Given a type, perhaps copied for a typedef,
   find the "original" version of it.  */
tree
original_type (t)
     tree t;
  while (TYPE_NAME (t) != NULL_TREE)
      tree x = TYPE_NAME (t);
      if (TREE_CODE (x) != TYPE_DECL)
	break;
      x = DECL_ORIGINAL_TYPE (x);
      if (x == NULL_TREE)
	break;
      t = x;
  return t;
/* Return the common type of two types.
   This is the type for the result of most arithmetic operations
   if the operands have the given two types.
   We do not deal with enumeral types here because they have already been
   converted to integer types.  */
tree
common_type (t1, t2)
     tree t1, t2;
  register enum tree_code code1;
  register enum tree_code code2;
  tree attributes;
  /* Save time if the two types are the same.  */
  if (t1 == t2)
    return t1;
  t1 = original_type (t1);
  t2 = original_type (t2);
  if (t1 == t2)
    return t1;
  /* If one type is nonsense, use the other.  */
  if (t1 == error_mark_node)
    return t2;
  if (t2 == error_mark_node)
    return t1;
  /* Merge the attributes.  */
  attributes = merge_machine_type_attributes (t1, t2);
  { register tree a1, a2;
    a1 = TYPE_ATTRIBUTES (t1);
    a2 = TYPE_ATTRIBUTES (t2);
    /* Either one unset?  Take the set one.  */
    if (!(attributes = a1))
       attributes = a2;
    /* One that completely contains the other?  Take it.  */
    else if (a2 && !attribute_list_contained (a1, a2))
	if (attribute_list_contained (a2, a1))
	  attributes = a2;
	else
	    /* Pick the longest list, and hang on the other list.  */
	    /* ??? For the moment we punt on the issue of attrs with args.  */
	    if (list_length (a1) < list_length (a2))
	      attributes = a2, a2 = a1;
	    for (; a2; a2 = TREE_CHAIN (a2))
	      if (lookup_attribute (IDENTIFIER_POINTER (TREE_PURPOSE (a2)),
				    attributes) == NULL_TREE)
		  a1 = copy_node (a2);
		  TREE_CHAIN (a1) = attributes;
		  attributes = a1;
  /* Treat an enum type as the unsigned integer type of the same width.  */
  if (TREE_CODE (t1) == ENUMERAL_TYPE)
    t1 = type_for_size (TYPE_PRECISION (t1), 1);
  if (TREE_CODE (t2) == ENUMERAL_TYPE)
    t2 = type_for_size (TYPE_PRECISION (t2), 1);
  if (TYPE_PTRMEMFUNC_P (t1))
    t1 = TYPE_PTRMEMFUNC_FN_TYPE (t1);
  if (TYPE_PTRMEMFUNC_P (t2))
    t2 = TYPE_PTRMEMFUNC_FN_TYPE (t2);
  code1 = TREE_CODE (t1);
  code2 = TREE_CODE (t2);
  /* If one type is complex, form the common type of the non-complex
     components, then make that complex.  Use T1 or T2 if it is the
     required type.  */
  if (code1 == COMPLEX_TYPE || code2 == COMPLEX_TYPE)
      tree subtype1 = code1 == COMPLEX_TYPE ? TREE_TYPE (t1) : t1;
      tree subtype2 = code2 == COMPLEX_TYPE ? TREE_TYPE (t2) : t2;
      tree subtype = common_type (subtype1, subtype2);
      if (code1 == COMPLEX_TYPE && TREE_TYPE (t1) == subtype)
	return build_type_attribute_variant (t1, attributes);
      else if (code2 == COMPLEX_TYPE && TREE_TYPE (t2) == subtype)
	return build_type_attribute_variant (t2, attributes);
      else
	return build_type_attribute_variant (build_complex_type (subtype),
					     attributes);
  switch (code1)
    case INTEGER_TYPE:
    case REAL_TYPE:
      /* If only one is real, use it as the result.  */
      if (code1 == REAL_TYPE && code2 != REAL_TYPE)
      if (code2 == REAL_TYPE && code1 != REAL_TYPE)
      /* Both real or both integers; use the one with greater precision.  */
      if (TYPE_PRECISION (t1) > TYPE_PRECISION (t2))
      else if (TYPE_PRECISION (t2) > TYPE_PRECISION (t1))
      /* Same precision.  Prefer longs to ints even when same size.  */
      if (TYPE_MAIN_VARIANT (t1) == long_unsigned_type_node
	  || TYPE_MAIN_VARIANT (t2) == long_unsigned_type_node)
        return build_type_attribute_variant (long_unsigned_type_node,
					     attributes);
      if (TYPE_MAIN_VARIANT (t1) == long_integer_type_node
	  || TYPE_MAIN_VARIANT (t2) == long_integer_type_node)
	  /* But preserve unsignedness from the other type,
	     since long cannot hold all the values of an unsigned int.  */
	  if (TREE_UNSIGNED (t1) || TREE_UNSIGNED (t2))
	     t1 = long_unsigned_type_node;
	  else
	     t1 = long_integer_type_node;
      if (TYPE_MAIN_VARIANT (t1) == long_double_type_node
	  || TYPE_MAIN_VARIANT (t2) == long_double_type_node)
	return build_type_attribute_variant (long_double_type_node,
					     attributes);
      /* Otherwise prefer the unsigned one.  */
      if (TREE_UNSIGNED (t1))
      else
    case POINTER_TYPE:
      /* For two pointers, do this recursively on the target type,
	 and combine the qualifiers of the two types' targets.  */
      /* This code was turned off; I don't know why.
 	 But ANSI C++ specifies doing this with the qualifiers.
 	 So I turned it on again.  */
	tree tt1 = TREE_TYPE (t1);
	tree tt2 = TREE_TYPE (t2);
	tree b1, b2;
	int type_quals;
	tree target;
	if (TREE_CODE (tt1) == OFFSET_TYPE)
	    b1 = TYPE_OFFSET_BASETYPE (tt1);
	    b2 = TYPE_OFFSET_BASETYPE (tt2);
	    tt1 = TREE_TYPE (tt1);
	    tt2 = TREE_TYPE (tt2);
	else
	  b1 = b2 = NULL_TREE;
	type_quals = (CP_TYPE_QUALS (tt1) | CP_TYPE_QUALS (tt2));
	tt1 = TYPE_MAIN_VARIANT (tt1);
	tt2 = TYPE_MAIN_VARIANT (tt2);
	if (tt1 == tt2)
	  target = tt1;
	else if (b1)
	    compiler_error ("common_type called with uncommon member types");
	    target = tt1;
	else if (tt1 == void_type_node || tt2 == void_type_node)
	  target = void_type_node;
	else if (tt1 == unknown_type_node)
	  target = tt2;
	else if (tt2 == unknown_type_node)
	  target = tt1;
	else
	  target = common_type (tt1, tt2);
	target = cp_build_qualified_type (target, type_quals);
	if (b1)
	    if (same_type_p (b1, b2)
		|| (DERIVED_FROM_P (b1, b2) && binfo_or_else (b1, b2)))
	      target = build_offset_type (b2, target);
	    else if (binfo_or_else (b2, b1))
	      target = build_offset_type (b1, target);
	if (code1 == POINTER_TYPE)
	  t1 = build_pointer_type (target);
	else
	  t1 = build_reference_type (target);
	t1 = build_type_attribute_variant (t1, attributes);
	if (TREE_CODE (target) == METHOD_TYPE)
	  t1 = build_ptrmemfunc_type (t1);
	return t1;
    case ARRAY_TYPE:
	tree elt = common_type (TREE_TYPE (t1), TREE_TYPE (t2));
	/* Save space: see if the result is identical to one of the args.  */
	if (elt == TREE_TYPE (t1) && TYPE_DOMAIN (t1))
	if (elt == TREE_TYPE (t2) && TYPE_DOMAIN (t2))
	/* Merge the element types, and have a size if either arg has one.  */
	t1 = build_cplus_array_type
	  (elt, TYPE_DOMAIN (TYPE_DOMAIN (t1) ? t1 : t2));
    case FUNCTION_TYPE:
      /* Function types: prefer the one that specified arg types.
	 If both do, merge the arg types.  Also merge the return types.  */
	tree valtype = common_type (TREE_TYPE (t1), TREE_TYPE (t2));
	tree p1 = TYPE_ARG_TYPES (t1);
	tree p2 = TYPE_ARG_TYPES (t2);
	tree rval, raises;
	if (valtype == TREE_TYPE (t1) && ! p2)
	if (valtype == TREE_TYPE (t2) && ! p1)
	/* Simple way if one arg fails to specify argument types.  */
	if (p1 == NULL_TREE || TREE_VALUE (p1) == void_type_node)
	    rval = build_function_type (valtype, p2);
	    if ((raises = TYPE_RAISES_EXCEPTIONS (t2)))
	      rval = build_exception_variant (rval, raises);
	    return build_type_attribute_variant (rval, attributes);
	raises = TYPE_RAISES_EXCEPTIONS (t1);
	if (p2 == NULL_TREE || TREE_VALUE (p2) == void_type_node)
	    rval = build_function_type (valtype, p1);
	    if (raises)
	rval = build_function_type (valtype, commonparms (p1, p2));
    case RECORD_TYPE:
    case UNION_TYPE:
      t1 = TYPE_MAIN_VARIANT (t1);
      t2 = TYPE_MAIN_VARIANT (t2);
      if (DERIVED_FROM_P (t1, t2) && binfo_or_else (t1, t2))
      else if (binfo_or_else (t2, t1))
      else
	  compiler_error ("common_type called with uncommon aggregate types");
    case METHOD_TYPE:
      if (TREE_CODE (TREE_TYPE (t1)) == TREE_CODE (TREE_TYPE (t2)))
	  /* Get this value the long way, since TYPE_METHOD_BASETYPE
	     is just the main variant of this.  */
	  tree basetype;
	  tree raises, t3;
	  tree b1 = TYPE_OFFSET_BASETYPE (t1);
	  tree b2 = TYPE_OFFSET_BASETYPE (t2);
	    basetype = TREE_TYPE (TREE_VALUE (TYPE_ARG_TYPES (t2)));
	  else
	      if (binfo_or_else (b2, b1) == NULL_TREE)
		compiler_error ("common_type called with uncommon method types");
	      basetype = TREE_TYPE (TREE_VALUE (TYPE_ARG_TYPES (t1)));
	  /* If this was a member function type, get back to the
	     original type of type member function (i.e., without
	     the class instance variable up front.  */
	  t1 = build_function_type (TREE_TYPE (t1),
				    TREE_CHAIN (TYPE_ARG_TYPES (t1)));
	  t2 = build_function_type (TREE_TYPE (t2),
				    TREE_CHAIN (TYPE_ARG_TYPES (t2)));
	  t3 = common_type (t1, t2);
	  t3 = build_cplus_method_type (basetype, TREE_TYPE (t3),
					TYPE_ARG_TYPES (t3));
	  t1 = build_exception_variant (t3, raises);
      else
    case OFFSET_TYPE:
      /* Pointers to members should now be handled by the POINTER_TYPE
	 case above.  */
      my_friendly_abort (990325);
    default:
/* Return 1 if TYPE1 and TYPE2 raise the same exceptions.  */
int
compexcepttypes (t1, t2)
     tree t1, t2;
  return TYPE_RAISES_EXCEPTIONS (t1) == TYPE_RAISES_EXCEPTIONS (t2);
/* Compare the array types T1 and T2, using CMP as the type comparison
   function for the element types.  STRICT is as for comptypes.  */
static int
comp_array_types (cmp, t1, t2, strict)
     register int (*cmp) PROTO((tree, tree, int));
     tree t1, t2;
     int strict;
  tree d1;
  tree d2;
  if (t1 == t2)
    return 1;
  /* The type of the array elements must be the same.  */
  if (!(TREE_TYPE (t1) == TREE_TYPE (t2)
	|| (*cmp) (TREE_TYPE (t1), TREE_TYPE (t2),
		   strict & ~COMPARE_REDECLARATION)))
    return 0;
  d1 = TYPE_DOMAIN (t1);
  d2 = TYPE_DOMAIN (t2);
  if (d1 == d2)
    return 1;
  /* If one of the arrays is dimensionless, and the other has a
     dimension, they are of different types.  However, it is legal to
     write:
       extern int a[];
       int a[3];
     by [basic.link]:
       declarations for an array object can specify
       array types that differ by the presence or absence of a major
       array bound (_dcl.array_).  */
  if (!d1 || !d2)
    return strict & COMPARE_REDECLARATION;
  /* Check that the dimensions are the same.  */
  return (cp_tree_equal (TYPE_MIN_VALUE (d1),
			 TYPE_MIN_VALUE (d2))
	  && cp_tree_equal (TYPE_MAX_VALUE (d1),
			    TYPE_MAX_VALUE (d2)));
/* Return 1 if TYPE1 and TYPE2 are compatible types for assignment
   or various other operations.  STRICT is a bitwise-or of the
   COMPARE_* flags.  */
int
comptypes (type1, type2, strict)
     tree type1, type2;
     int strict;
  register tree t1 = type1;
  register tree t2 = type2;
  int attrval, val;
  int orig_strict = strict;
  /* The special exemption for redeclaring array types without an
     array bound only applies at the top level:
       extern int (*i)[];
       int (*i)[8];
     is not legal, for example.  */
  strict &= ~COMPARE_REDECLARATION;
  /* Suppress errors caused by previously reported errors */
  if (t1 == t2)
    return 1;
  /* This should never happen.  */
  my_friendly_assert (t1 != error_mark_node, 307);
    return 0;
  if (strict & COMPARE_RELAXED)
      if (t1 == t2)
	return 1;
  /* Different classes of types can't be compatible.  */
  if (TREE_CODE (t1) != TREE_CODE (t2))
    return 0;
  /* Qualifiers must match.  */
  if (CP_TYPE_QUALS (t1) != CP_TYPE_QUALS (t2))
    return 0;
  if (strict == COMPARE_STRICT
      && TYPE_FOR_JAVA (t1) != TYPE_FOR_JAVA (t2))
    return 0;
  /* Allow for two different type nodes which have essentially the same
     definition.  Note that we already checked for equality of the type
     qualifiers (just above).  */
  if (TYPE_MAIN_VARIANT (t1) == TYPE_MAIN_VARIANT (t2))
    return 1;
  /* ??? COMP_TYPE_ATTRIBUTES is currently useless for variables as each
     attribute is its own main variant (`val' will remain 0).  */
#ifndef COMP_TYPE_ATTRIBUTES
#define COMP_TYPE_ATTRIBUTES(t1,t2)	1
#endif
  if (strict & COMPARE_NO_ATTRIBUTES)
    attrval = 1;
  /* 1 if no need for warning yet, 2 if warning cause has been seen.  */
  else if (! (attrval = COMP_TYPE_ATTRIBUTES (t1, t2)))
     return 0;
  val = 0;
  switch (TREE_CODE (t1))
      if (TEMPLATE_TYPE_IDX (t1) != TEMPLATE_TYPE_IDX (t2)
	  || TEMPLATE_TYPE_LEVEL (t1) != TEMPLATE_TYPE_LEVEL (t2))
	return 0;
      if (! comp_template_parms (DECL_TEMPLATE_PARMS (TYPE_NAME (t1)),
				 DECL_TEMPLATE_PARMS (TYPE_NAME (t2))))
	return 0;
      if (!TEMPLATE_TEMPLATE_PARM_TEMPLATE_INFO (t1)
	  && ! TEMPLATE_TEMPLATE_PARM_TEMPLATE_INFO (t2))
	return 1;
      /* Don't check inheritance.  */
      strict = COMPARE_STRICT;
      /* fall through */
    case RECORD_TYPE:
    case UNION_TYPE:
      if (TYPE_TEMPLATE_INFO (t1) && TYPE_TEMPLATE_INFO (t2)
	  && (TYPE_TI_TEMPLATE (t1) == TYPE_TI_TEMPLATE (t2)
	      || TREE_CODE (t1) == TEMPLATE_TEMPLATE_PARM))
	val = comp_template_args (TYPE_TI_ARGS (t1),
				  TYPE_TI_ARGS (t2));
    look_hard:
      if ((strict & COMPARE_BASE) && DERIVED_FROM_P (t1, t2))
	  val = 1;
	  break;
      if ((strict & COMPARE_RELAXED) && DERIVED_FROM_P (t2, t1))
	  val = 1;
	  break;
      break;
    case OFFSET_TYPE:
      val = (comptypes (build_pointer_type (TYPE_OFFSET_BASETYPE (t1)),
			build_pointer_type (TYPE_OFFSET_BASETYPE (t2)), strict)
	     && comptypes (TREE_TYPE (t1), TREE_TYPE (t2), strict));
      break;
    case METHOD_TYPE:
      if (! compexcepttypes (t1, t2))
	return 0;
      /* This case is anti-symmetrical!
	 One can pass a base member (or member function)
	 to something expecting a derived member (or member function),
	 but not vice-versa!  */
      val = (comptypes (TREE_TYPE (t1), TREE_TYPE (t2), strict)
	     && compparms (TYPE_ARG_TYPES (t1), TYPE_ARG_TYPES (t2)));
      break;
    case POINTER_TYPE:
      /* first, check whether the referred types match with the
         required level of strictness */
      val = comptypes (t1, t2, strict);
      if (val)
	break;
      if (TREE_CODE (t1) == RECORD_TYPE
	  && TREE_CODE (t2) == RECORD_TYPE)
	goto look_hard;
      break;
    case FUNCTION_TYPE:
	return 0;
      val = ((TREE_TYPE (t1) == TREE_TYPE (t2)
      break;
    case ARRAY_TYPE:
      /* Target types must match incl. qualifiers.  We use ORIG_STRICT
	 here since this is the one place where
	 COMPARE_REDECLARATION should be used.  */
      val = comp_array_types (comptypes, t1, t2, orig_strict);
      break;
      return TEMPLATE_TYPE_IDX (t1) == TEMPLATE_TYPE_IDX (t2)
	&& TEMPLATE_TYPE_LEVEL (t1) == TEMPLATE_TYPE_LEVEL (t2);
    case TYPENAME_TYPE:
      if (TYPE_IDENTIFIER (t1) != TYPE_IDENTIFIER (t2))
	return 0;
      return same_type_p (TYPE_CONTEXT (t1), TYPE_CONTEXT (t2));
    default:
      break;
  return attrval == 2 && val == 1 ? 2 : val;
/* Subroutine of comp_target-types.  Make sure that the cv-quals change
   only in the same direction as the target type.  */
static int
comp_cv_target_types (ttl, ttr, nptrs)
     tree ttl, ttr;
     int nptrs;
  int t;
  if (!at_least_as_qualified_p (ttl, ttr)
      && !at_least_as_qualified_p (ttr, ttl))
    /* The qualifications are incomparable.  */
    return 0;
  if (TYPE_MAIN_VARIANT (ttl) == TYPE_MAIN_VARIANT (ttr))
    return more_qualified_p (ttr, ttl) ? -1 : 1;
  t = comp_target_types (ttl, ttr, nptrs);
  if ((t == 1 && at_least_as_qualified_p (ttl, ttr))
      || (t == -1 && at_least_as_qualified_p (ttr, ttl)))
    return t;
  return 0;
/* Return 1 or -1 if TTL and TTR are pointers to types that are equivalent,
   ignoring their qualifiers, 0 if not. Return 1 means that TTR can be
   converted to TTL. Return -1 means that TTL can be converted to TTR but
   not vice versa.
   NPTRS is the number of pointers we can strip off and keep cool.
   This is used to permit (for aggr A, aggr B) A, B* to convert to A*,
   but to not permit B** to convert to A**.
   This should go away.  Callers should use can_convert or something
   similar instead.  (jason 17 Apr 1997)  */
int
     tree ttl, ttr;
     int nptrs;
  ttl = TYPE_MAIN_VARIANT (ttl);
  ttr = TYPE_MAIN_VARIANT (ttr);
  if (same_type_p (ttl, ttr))
    return 1;
  if (TREE_CODE (ttr) != TREE_CODE (ttl))
    return 0;
  if ((TREE_CODE (ttr) == POINTER_TYPE
       || TREE_CODE (ttr) == REFERENCE_TYPE)
      /* If we get a pointer with nptrs == 0, we don't allow any tweaking
	 of the type pointed to.  This is necessary for reference init
	 semantics.  We won't get here from a previous call with nptrs == 1;
	 for multi-level pointers we end up in comp_ptr_ttypes.  */
      && nptrs > 0)
      int is_ptr = TREE_CODE (ttr) == POINTER_TYPE;
      ttl = TREE_TYPE (ttl);
      ttr = TREE_TYPE (ttr);
      if (is_ptr)
	  if (TREE_CODE (ttl) == UNKNOWN_TYPE
	      || TREE_CODE (ttr) == UNKNOWN_TYPE)
	    return 1;
	  else if (TREE_CODE (ttl) == VOID_TYPE
		   && TREE_CODE (ttr) != FUNCTION_TYPE
		   && TREE_CODE (ttr) != METHOD_TYPE
		   && TREE_CODE (ttr) != OFFSET_TYPE)
	    return 1;
	  else if (TREE_CODE (ttr) == VOID_TYPE
		   && TREE_CODE (ttl) != FUNCTION_TYPE
		   && TREE_CODE (ttl) != METHOD_TYPE
		   && TREE_CODE (ttl) != OFFSET_TYPE)
	    return -1;
	  else if (TREE_CODE (ttl) == POINTER_TYPE
		   || TREE_CODE (ttl) == ARRAY_TYPE)
	      if (comp_ptr_ttypes (ttl, ttr))
		return 1;
	      else if (comp_ptr_ttypes (ttr, ttl))
		return -1;
	      return 0;
      /* Const and volatile mean something different for function types,
	 so the usual checks are not appropriate.  */
      if (TREE_CODE (ttl) == FUNCTION_TYPE || TREE_CODE (ttl) == METHOD_TYPE)
	return comp_target_types (ttl, ttr, nptrs - 1);
      return comp_cv_target_types (ttl, ttr, nptrs - 1);
  if (TREE_CODE (ttr) == ARRAY_TYPE)
    return comp_array_types (comp_target_types, ttl, ttr, COMPARE_STRICT);
  else if (TREE_CODE (ttr) == FUNCTION_TYPE || TREE_CODE (ttr) == METHOD_TYPE)
      tree argsl, argsr;
      int saw_contra = 0;
      if (pedantic)
	  if (!same_type_p (TREE_TYPE (ttl), TREE_TYPE (ttr)))
	    return 0;
      else
	  switch (comp_target_types (TREE_TYPE (ttl), TREE_TYPE (ttr), -1))
	    case 0:
	      return 0;
	    case -1:
	      saw_contra = 1;
      argsl = TYPE_ARG_TYPES (ttl);
      argsr = TYPE_ARG_TYPES (ttr);
      /* Compare 'this' here, not in comp_target_parms.  */
      if (TREE_CODE (ttr) == METHOD_TYPE)
	  tree tl = TYPE_METHOD_BASETYPE (ttl);
	  tree tr = TYPE_METHOD_BASETYPE (ttr);
	  if (!same_or_base_type_p (tr, tl))
	      if (same_or_base_type_p (tl, tr))
		saw_contra = 1;
	      else
		return 0;
	  argsl = TREE_CHAIN (argsl);
	  argsr = TREE_CHAIN (argsr);
	switch (comp_target_parms (argsl, argsr, 1))
	  case 0:
	    return 0;
	  case -1:
	    saw_contra = 1;
	return saw_contra ? -1 : 1;
  /* for C++ */
  else if (TREE_CODE (ttr) == OFFSET_TYPE)
      int base;
      /* Contravariance: we can assign a pointer to base member to a pointer
	 to derived member.  Note difference from simple pointer case, where
	 we can pass a pointer to derived to a pointer to base.  */
      if (same_or_base_type_p (TYPE_OFFSET_BASETYPE (ttr),
			       TYPE_OFFSET_BASETYPE (ttl)))
	base = 1;
      else if (same_or_base_type_p (TYPE_OFFSET_BASETYPE (ttl),
				    TYPE_OFFSET_BASETYPE (ttr)))
	  tree tmp = ttl;
	  ttl = ttr;
	  ttr = tmp;
	  base = -1;
      else
	return 0;
	    return base;
	  return 0;
      else
	  if (comp_cv_target_types (ttl, ttr, nptrs) == 1)
	    return base;
	  return 0;
  else if (IS_AGGR_TYPE (ttl))
      if (nptrs < 0)
	return 0;
      if (same_or_base_type_p (build_pointer_type (ttl),
			       build_pointer_type (ttr)))
	return 1;
      if (same_or_base_type_p (build_pointer_type (ttr),
			       build_pointer_type (ttl)))
	return -1;
      return 0;
  return 0;
/* Returns 1 if TYPE1 is at least as qualified as TYPE2.  */
int
at_least_as_qualified_p (type1, type2)
     tree type1;
     tree type2;
  /* All qualifiers for TYPE2 must also appear in TYPE1.  */
  return ((CP_TYPE_QUALS (type1) & CP_TYPE_QUALS (type2))
	  == CP_TYPE_QUALS (type2));
/* Returns 1 if TYPE1 is more qualified than TYPE2.  */
int
more_qualified_p (type1, type2)
     tree type1;
     tree type2;
  return (CP_TYPE_QUALS (type1) != CP_TYPE_QUALS (type2)
	  && at_least_as_qualified_p (type1, type2));
/* Returns 1 if TYPE1 is more cv-qualified than TYPE2, -1 if TYPE2 is
   more cv-qualified that TYPE1, and 0 otherwise.  */
int
comp_cv_qualification (type1, type2)
     tree type1;
     tree type2;
  if (CP_TYPE_QUALS (type1) == CP_TYPE_QUALS (type2))
    return 0;
  if (at_least_as_qualified_p (type1, type2))
    return 1;
  else if (at_least_as_qualified_p (type2, type1))
    return -1;
  return 0;
/* Returns 1 if the cv-qualification signature of TYPE1 is a proper
   subset of the cv-qualification signature of TYPE2, and the types
   are similar.  Returns -1 if the other way 'round, and 0 otherwise.  */
int
comp_cv_qual_signature (type1, type2)
     tree type1;
     tree type2;
  if (comp_ptr_ttypes_real (type2, type1, -1))
    return 1;
  else if (comp_ptr_ttypes_real (type1, type2, -1))
    return -1;
  else
    return 0;
/* If two types share a common base type, return that basetype.
   If there is not a unique most-derived base type, this function
   returns ERROR_MARK_NODE.  */
static tree
common_base_type (tt1, tt2)
     tree tt1, tt2;
  tree best = NULL_TREE;
  int i;
  /* If one is a baseclass of another, that's good enough.  */
  if (UNIQUELY_DERIVED_FROM_P (tt1, tt2))
    return tt1;
  if (UNIQUELY_DERIVED_FROM_P (tt2, tt1))
    return tt2;
  /* Otherwise, try to find a unique baseclass of TT1
     that is shared by TT2, and follow that down.  */
  for (i = CLASSTYPE_N_BASECLASSES (tt1)-1; i >= 0; i--)
      tree basetype = TYPE_BINFO_BASETYPE (tt1, i);
      tree trial = common_base_type (basetype, tt2);
      if (trial)
	  if (trial == error_mark_node)
	    return trial;
	  if (best == NULL_TREE)
	    best = trial;
	  else if (best != trial)
  /* Same for TT2.  */
  for (i = CLASSTYPE_N_BASECLASSES (tt2)-1; i >= 0; i--)
      tree basetype = TYPE_BINFO_BASETYPE (tt2, i);
      tree trial = common_base_type (tt1, basetype);
      if (trial)
	    return trial;
	    best = trial;
  return best;
/* Subroutines of `comptypes'.  */
/* Return 1 if two parameter type lists PARMS1 and PARMS2 are
   equivalent in the sense that functions with those parameter types
   can have equivalent types.  The two lists must be equivalent,
   element by element.
   C++: See comment above about TYPE1, TYPE2.  */
int
compparms (parms1, parms2)
     tree parms1, parms2;
  register tree t1 = parms1, t2 = parms2;
  /* An unspecified parmlist matches any specified parmlist
     whose argument types don't need default promotions.  */
  while (1)
      if (t1 == 0 && t2 == 0)
	return 1;
      /* If one parmlist is shorter than the other,
	 they fail to match.  */
      if (t1 == 0 || t2 == 0)
	return 0;
      if (!same_type_p (TREE_VALUE (t2), TREE_VALUE (t1)))
	return 0;
      t1 = TREE_CHAIN (t1);
      t2 = TREE_CHAIN (t2);
/* This really wants return whether or not parameter type lists
   would make their owning functions assignment compatible or not.
   The return value is like for comp_target_types.
   This should go away, possibly with the exception of the empty parmlist
   conversion; there are no conversions between function types in C++.
static int
comp_target_parms (parms1, parms2, strict)
     int strict;
  int warn_contravariance = 0;
  /* In C, an unspecified parmlist matches any specified parmlist
     whose argument types don't need default promotions.  This is not
     true for C++, but let's do it anyway for unfixed headers.  */
  if (t1 == 0 && t2 != 0)
      if (! flag_strict_prototype && t2 == void_list_node)
        /* t1 might be the arglist of a function pointer in extern "C"
           declared to take (), which we fudged to (...).  Don't make the
	   user pay for our mistake.  */;
      else
        cp_pedwarn ("ANSI C++ prohibits conversion from `(%#T)' to `(...)'",
                    parms2);
      return self_promoting_args_p (t2);
  if (t2 == 0)
    return self_promoting_args_p (t1);
  for (; t1 || t2; t1 = TREE_CHAIN (t1), t2 = TREE_CHAIN (t2))
      tree p1, p2;
	 they fail to match, unless STRICT is <= 0.  */
	  if (strict > 0)
	    return 0;
	  if (strict < 0)
	    return 1 + warn_contravariance;
	  return ((t1 && TREE_PURPOSE (t1)) + warn_contravariance);
      p1 = TREE_VALUE (t1);
      p2 = TREE_VALUE (t2);
      if (same_type_p (p1, p2))
	continue;
      if (pedantic)
	return 0;
      if ((TREE_CODE (p1) == POINTER_TYPE && TREE_CODE (p2) == POINTER_TYPE)
	  || (TREE_CODE (p1) == REFERENCE_TYPE
	      && TREE_CODE (p2) == REFERENCE_TYPE))
	  if (strict <= 0
	      && (TYPE_MAIN_VARIANT (TREE_TYPE (p1))
		  == TYPE_MAIN_VARIANT (TREE_TYPE (p2))))
	    continue;
	  /* The following is wrong for contravariance,
	     but many programs depend on it.  */
	  if (TREE_TYPE (p1) == void_type_node)
	    continue;
	  if (TREE_TYPE (p2) == void_type_node)
	      warn_contravariance = 1;
	      continue;
	  if (IS_AGGR_TYPE (TREE_TYPE (p1))
	      && !same_type_p (TYPE_MAIN_VARIANT (TREE_TYPE (p1)),
	    return 0;
      /* Note backwards order due to contravariance.  */
      if (comp_target_types (p2, p1, 1) <= 0)
	  if (comp_target_types (p1, p2, 1) > 0)
	      continue;
	  if (strict != 0)
	    return 0;
  return warn_contravariance ? -1 : 1;
/* Return 1 if PARMS specifies a fixed number of parameters
   and none of their types is affected by default promotions.  */
int
self_promoting_args_p (parms)
     tree parms;
  register tree t;
  for (t = parms; t; t = TREE_CHAIN (t))
      register tree type = TREE_VALUE (t);
      if (TREE_CHAIN (t) == 0 && type != void_type_node)
	return 0;
      if (type == 0)
	return 0;
      if (TYPE_MAIN_VARIANT (type) == float_type_node)
	return 0;
      if (C_PROMOTING_INTEGER_TYPE_P (type))
	return 0;
  return 1;
/* Implement the vec_step keyword: Return the number of components in the
   given vector type.  */
tree
c_vec_step (type)
     tree type;
  enum tree_code code = TREE_CODE (type);
  if (code != VECTOR_TYPE)
      error ("operand of `vec_step' must be a vector type");
      return size_int (0);
  return size_binop (CEIL_DIV_EXPR, size_int (16),
		     c_sizeof (TREE_TYPE (type)));
   the given vector type.  */
tree
c_vec_step_expr (expr)
     tree expr;
  return c_vec_step (TREE_TYPE (expr));
/* Digest a vector constant.  */
tree
build_vector_constant (type, values)
     tree type;
     tree values;
  tree vtype;
  tree valarray[16], valtail;
  int valnum, elements;
  /* Get the vector element type and number of elements.  */
  vtype = TREE_TYPE (type);
  elements = (TREE_INT_CST_LOW (TYPE_SIZE (type))
	      / TREE_INT_CST_LOW (TYPE_SIZE (vtype)));
  /* Walk the values list placing the converted constants into valarray and counting
     the number of constants.  */
  for (valtail = values, valnum = 0;
       valtail;
       valtail = TREE_CHAIN (valtail), valnum++)
      register tree val = TREE_VALUE (valtail);
      STRIP_NOPS (val);
      if (TREE_CODE (val) != INTEGER_CST && TREE_CODE (val) != REAL_CST)
	  error("expected a constant expression");
      valarray[valnum] = convert_for_assignment (vtype, val, "assignment",
						 NULL_TREE, 0);
  /* Check for the correct number of elements.  */
  if (valnum != 1 && valnum != elements)
      error (valnum < elements
	     ? "too few initializers" : "too many initializers");
  /* A single constant value is shorthand for a duplicated value.  Duplicate it
     now.  */
  while (valnum < elements)
    valarray[valnum++] = valarray[0];
  /* Combine the constant [integer] values until there are exactly four.  */
  while (elements > 4)
      int i, j;
      for (i = 2, j = 0; i <= elements; i += 2, j++)
	  unsigned HOST_WIDE_INT a = TREE_INT_CST_LOW (valarray[i-2]);
	  unsigned HOST_WIDE_INT b = TREE_INT_CST_LOW (valarray[i-1]);
	  int bits = 128 / elements;
	  valarray[j] = build_int_2 ((a << bits) | (b & ((1 << bits) - 1)), 0);
      elements /= 2;
  return build_vector (type, valarray[0], valarray[1],
		       valarray[2], valarray[3]);
/* Return an unsigned type the same as TYPE in other respects.
   C++: must make these work for type variants as well.  */
tree
unsigned_type (type)
     tree type;
  tree type1 = TYPE_MAIN_VARIANT (type);
  if (type1 == signed_char_type_node || type1 == char_type_node)
    return unsigned_char_type_node;
  if (type1 == integer_type_node)
    return unsigned_type_node;
  if (type1 == short_integer_type_node)
    return short_unsigned_type_node;
  if (type1 == long_integer_type_node)
    return long_unsigned_type_node;
  if (type1 == long_long_integer_type_node)
    return long_long_unsigned_type_node;
#if HOST_BITS_PER_WIDE_INT >= 64
  if (type1 == intTI_type_node)
    return unsigned_intTI_type_node;
#endif
  if (type1 == intDI_type_node)
    return unsigned_intDI_type_node;
  if (type1 == intSI_type_node)
    return unsigned_intSI_type_node;
  if (type1 == intHI_type_node)
    return unsigned_intHI_type_node;
  if (type1 == intQI_type_node)
    return unsigned_intQI_type_node;
  return signed_or_unsigned_type (1, type);
/* Return a signed type the same as TYPE in other respects.  */
tree
signed_type (type)
     tree type;
  if (type1 == unsigned_char_type_node || type1 == char_type_node)
    return signed_char_type_node;
  if (type1 == unsigned_type_node)
    return integer_type_node;
  if (type1 == short_unsigned_type_node)
    return short_integer_type_node;
  if (type1 == long_unsigned_type_node)
    return long_integer_type_node;
  if (type1 == long_long_unsigned_type_node)
    return long_long_integer_type_node;
  if (type1 == unsigned_intTI_type_node)
    return intTI_type_node;
#endif
  if (type1 == unsigned_intDI_type_node)
    return intDI_type_node;
  if (type1 == unsigned_intSI_type_node)
    return intSI_type_node;
  if (type1 == unsigned_intHI_type_node)
    return intHI_type_node;
  if (type1 == unsigned_intQI_type_node)
    return intQI_type_node;
  return signed_or_unsigned_type (0, type);
/* Return a type the same as TYPE except unsigned or
   signed according to UNSIGNEDP.  */
tree
signed_or_unsigned_type (unsignedp, type)
     int unsignedp;
     tree type;
  if (! INTEGRAL_TYPE_P (type)
      || TREE_UNSIGNED (type) == unsignedp)
    return type;
  if (TYPE_PRECISION (type) == TYPE_PRECISION (signed_char_type_node))
    return unsignedp ? unsigned_char_type_node : signed_char_type_node;
  if (TYPE_PRECISION (type) == TYPE_PRECISION (integer_type_node))
    return unsignedp ? unsigned_type_node : integer_type_node;
  if (TYPE_PRECISION (type) == TYPE_PRECISION (short_integer_type_node))
    return unsignedp ? short_unsigned_type_node : short_integer_type_node;
  if (TYPE_PRECISION (type) == TYPE_PRECISION (long_integer_type_node))
    return unsignedp ? long_unsigned_type_node : long_integer_type_node;
  if (TYPE_PRECISION (type) == TYPE_PRECISION (long_long_integer_type_node))
    return (unsignedp ? long_long_unsigned_type_node
	    : long_long_integer_type_node);
  return type;
/* Compute the value of the `sizeof' operator.  */
tree
c_sizeof (type)
     tree type;
  tree t;
  if (processing_template_decl)
    return build_min (SIZEOF_EXPR, sizetype, type);
  if (code == FUNCTION_TYPE)
      if (pedantic || warn_pointer_arith)
	pedwarn ("ANSI C++ forbids taking the sizeof a function type");
      return size_int (1);
  if (code == METHOD_TYPE)
	pedwarn ("ANSI C++ forbids taking the sizeof a method type");
  if (code == VOID_TYPE)
	pedwarn ("ANSI C++ forbids taking the sizeof a void type");
  if (code == ERROR_MARK)
  /* ARM $5.3.2: ``When applied to a reference, the result is the size of the
     referenced object.'' */
  if (code == REFERENCE_TYPE)
  /* We couldn't find anything in the ARM or the draft standard that says,
     one way or the other, if doing sizeof on something that doesn't have
     an object associated with it is correct or incorrect.  For example, if
     you declare `struct S { char str[16]; };', and in your program do
     a `sizeof (S::str)', should we flag that as an error or should we give
     the size of it?  Since it seems like a reasonable thing to do, we'll go
     with giving the value.  */
  if (code == OFFSET_TYPE)
  /* @@ This also produces an error for a signature ref.
        In that case we should be able to do better.  */
  if (IS_SIGNATURE (type))
      error ("`sizeof' applied to a signature type");
  if (TYPE_SIZE (complete_type (type)) == 0)
      cp_error ("`sizeof' applied to incomplete type `%T'", type);
  /* Convert in case a char is more than one unit.  */
  t = size_binop (CEIL_DIV_EXPR, TYPE_SIZE (type),
		  size_int (TYPE_PRECISION (char_type_node)));
  t = convert (sizetype, t);
  /* size_binop does not put the constant in range, so do it now.  */
  if (TREE_CODE (t) == INTEGER_CST && force_fit_type (t, 0))
    TREE_CONSTANT_OVERFLOW (t) = TREE_OVERFLOW (t) = 1;
  return t;
tree
expr_sizeof (e)
     tree e;
    return build_min (SIZEOF_EXPR, sizetype, e);
  if (TREE_CODE (e) == COMPONENT_REF
      && DECL_C_BIT_FIELD (TREE_OPERAND (e, 1)))
    error ("sizeof applied to a bit-field");
  /* ANSI says arrays and functions are converted inside comma.
     But we can't really convert them in build_compound_expr
     because that would break commas in lvalues.
     So do the conversion here if operand was a comma.  */
  if (TREE_CODE (e) == COMPOUND_EXPR
      && (TREE_CODE (TREE_TYPE (e)) == ARRAY_TYPE
	  || TREE_CODE (TREE_TYPE (e)) == FUNCTION_TYPE))
    e = default_conversion (e);
  else if (is_overloaded_fn (e))
  else if (type_unknown_p (e))
      incomplete_type_error (e, TREE_TYPE (e));
  return c_sizeof (TREE_TYPE (e));
tree
c_sizeof_nowarn (type)
     tree type;
  tree t;
      || code == METHOD_TYPE
      || code == VOID_TYPE
      || code == ERROR_MARK)
  if (TYPE_SIZE (type) == 0)
  force_fit_type (t, 0);
  return t;
/* Implement the __alignof keyword: Return the minimum required
   alignment of TYPE, measured in bytes.  */
tree
c_alignof (type)
     tree type;
  tree t;
    return build_min (ALIGNOF_EXPR, sizetype, type);
  if (code == FUNCTION_TYPE || code == METHOD_TYPE)
    return size_int (FUNCTION_BOUNDARY / BITS_PER_UNIT);
  if (code == VOID_TYPE || code == ERROR_MARK)
  /* C++: this is really correct!  */
      error ("`__alignof' applied to a signature type");
  t = size_int (TYPE_ALIGN (type) / BITS_PER_UNIT);
  return t;
/* Perform the array-to-pointer and function-to-pointer conversions
   for EXP.
   In addition, references are converted to rvalues and manifest
   constants are replaced by their values.  */
tree
decay_conversion (exp)
     tree exp;
  register tree type;
  register enum tree_code code;
  if (TREE_CODE (exp) == OFFSET_REF)
    exp = resolve_offset_ref (exp);
  type = TREE_TYPE (exp);
      exp = convert_from_reference (exp);
  /* Constants can be used directly unless they're not loadable.  */
  if (TREE_CODE (exp) == CONST_DECL)
    exp = DECL_INITIAL (exp);
  /* Replace a nonvolatile const static variable with its value.  We
     don't do this for arrays, though; we want the address of the
     first element of the array, not the address of the first element
     of its initializing constant.  We *do* replace variables that the
     user isn't really supposed to know about; this is a hack to deal
     with __PRETTY_FUNCTION__ and the like.  */
  else if (TREE_READONLY_DECL_P (exp)
	   && (code != ARRAY_TYPE
	       || (TREE_CODE (exp) == VAR_DECL && DECL_IGNORED_P (exp))))
      exp = decl_constant_value (exp);
  /* build_c_cast puts on a NOP_EXPR to make the result not an lvalue.
     Leave such NOP_EXPRs, since RHS is being used in non-lvalue context.  */
      error ("void value not ignored as it ought to be");
    my_friendly_abort (990506);
  if (code == FUNCTION_TYPE || is_overloaded_fn (exp))
    return build_unary_op (ADDR_EXPR, exp, 0);
  if (code == ARRAY_TYPE)
      register tree adr;
      tree ptrtype;
      if (TREE_CODE (exp) == INDIRECT_REF)
	  /* Stripping away the INDIRECT_REF is not the right
	     thing to do for references...  */
	  tree inner = TREE_OPERAND (exp, 0);
	  if (TREE_CODE (TREE_TYPE (inner)) == REFERENCE_TYPE)
	      inner = build1 (CONVERT_EXPR,
			      build_pointer_type (TREE_TYPE
						  (TREE_TYPE (inner))),
			      inner);
	      TREE_CONSTANT (inner) = TREE_CONSTANT (TREE_OPERAND (inner, 0));
	  return cp_convert (build_pointer_type (TREE_TYPE (type)), inner);
      if (TREE_CODE (exp) == COMPOUND_EXPR)
	  tree op1 = decay_conversion (TREE_OPERAND (exp, 1));
	  return build (COMPOUND_EXPR, TREE_TYPE (op1),
			TREE_OPERAND (exp, 0), op1);
      if (!lvalue_p (exp)
	  && ! (TREE_CODE (exp) == CONSTRUCTOR && TREE_STATIC (exp)))
	  error ("invalid use of non-lvalue array");
      ptrtype = build_pointer_type (TREE_TYPE (type));
      if (TREE_CODE (exp) == VAR_DECL)
	  /* ??? This is not really quite correct
	     in that the type of the operand of ADDR_EXPR
	     is not the target type of the type of the ADDR_EXPR itself.
	     Question is, can this lossage be avoided?  */
	  adr = build1 (ADDR_EXPR, ptrtype, exp);
	  if (mark_addressable (exp) == 0)
	  TREE_CONSTANT (adr) = staticp (exp);
	  TREE_SIDE_EFFECTS (adr) = 0;   /* Default would be, same as EXP.  */
	  return adr;
      /* This way is better for a COMPONENT_REF since it can
	 simplify the offset for a component.  */
      adr = build_unary_op (ADDR_EXPR, exp, 1);
      return cp_convert (ptrtype, adr);
  return exp;
tree
default_conversion (exp)
     tree exp;
  tree type;
  exp = decay_conversion (exp);
  if (INTEGRAL_CODE_P (code))
      tree t = type_promotes_to (type);
      if (t != type)
	return cp_convert (t, exp);
  return exp;
/* Take the address of an inline function without setting TREE_ADDRESSABLE
   or TREE_USED.  */
tree
inline_conversion (exp)
     tree exp;
  if (TREE_CODE (exp) == FUNCTION_DECL)
    exp = build1 (ADDR_EXPR, build_pointer_type (TREE_TYPE (exp)), exp);
  return exp;
/* Returns nonzero iff exp is a STRING_CST or the result of applying
   decay_conversion to one.  */
int
string_conv_p (totype, exp, warn)
     tree totype, exp;
     int warn;
  tree t;
  if (! flag_const_strings || TREE_CODE (totype) != POINTER_TYPE)
    return 0;
  t = TREE_TYPE (totype);
  if (!same_type_p (t, char_type_node)
      && !same_type_p (t, wchar_type_node))
    return 0;
  if (TREE_CODE (exp) == STRING_CST)
      /* Make sure that we don't try to convert between char and wchar_t.  */
      if (!same_type_p (TYPE_MAIN_VARIANT (TREE_TYPE (TREE_TYPE (exp))), t))
	return 0;
  else
      /* Is this a string constant which has decayed to 'const char *'?  */
      t = build_pointer_type (build_qualified_type (t, TYPE_QUAL_CONST));
      if (!same_type_p (TREE_TYPE (exp), t))
	return 0;
      STRIP_NOPS (exp);
      if (TREE_CODE (exp) != ADDR_EXPR
	  || TREE_CODE (TREE_OPERAND (exp, 0)) != STRING_CST)
	return 0;
  /* This warning is not very useful, as it complains about printf.  */
  if (warn && warn_write_strings)
    cp_warning ("deprecated conversion from string constant to `%T'", totype);
  return 1;
tree
build_object_ref (datum, basetype, field)
     tree datum, basetype, field;
  tree dtype;
  if (datum == error_mark_node)
  dtype = TREE_TYPE (datum);
  if (TREE_CODE (dtype) == REFERENCE_TYPE)
    dtype = TREE_TYPE (dtype);
  if (! IS_AGGR_TYPE_CODE (TREE_CODE (dtype)))
      cp_error ("request for member `%T::%D' in expression of non-aggregate type `%T'",
		basetype, field, dtype);
  else if (IS_SIGNATURE (basetype))
      warning ("signature name in scope resolution ignored");
      return build_component_ref (datum, field, NULL_TREE, 1);
  else if (is_aggr_type (basetype, 1))
      tree binfo = binfo_or_else (basetype, dtype);
      if (binfo)
	return build_x_component_ref (build_scoped_ref (datum, basetype),
				      field, binfo, 1);
/* Like `build_component_ref, but uses an already found field, and converts
   from a reference.  Must compute access for current_class_ref.
   Otherwise, ok.  */
tree
build_component_ref_1 (datum, field, protect)
     tree datum, field;
     int protect;
  return convert_from_reference
    (build_component_ref (datum, field, NULL_TREE, protect));
/* Given a COND_EXPR, MIN_EXPR, or MAX_EXPR in T, return it in a form that we
   can, for example, use as an lvalue.  This code used to be in
   unary_complex_lvalue, but we needed it to deal with `a = (d == c) ? b : c'
   expressions, where we're dealing with aggregates.  But now it's again only
   called from unary_complex_lvalue.  The case (in particular) that led to
   this was with CODE == ADDR_EXPR, since it's not an lvalue when we'd
   get it there.  */
static tree
rationalize_conditional_expr (code, t)
     tree t;
  /* For MIN_EXPR or MAX_EXPR, fold-const.c has arranged things so that
     the first operand is always the one to be used if both operands
     are equal, so we know what conditional expression this used to be.  */
  if (TREE_CODE (t) == MIN_EXPR || TREE_CODE (t) == MAX_EXPR)
      return
	build_conditional_expr (build_x_binary_op ((TREE_CODE (t) == MIN_EXPR
						    ? LE_EXPR : GE_EXPR),
						   TREE_OPERAND (t, 1)),
			    build_unary_op (code, TREE_OPERAND (t, 0), 0),
			    build_unary_op (code, TREE_OPERAND (t, 1), 0));
  return
    build_conditional_expr (TREE_OPERAND (t, 0),
			    build_unary_op (code, TREE_OPERAND (t, 1), 0),
			    build_unary_op (code, TREE_OPERAND (t, 2), 0));
/* Given the TYPE of an anonymous union field inside T, return the
   FIELD_DECL for the field.  If not found return NULL_TREE.  Because
   anonymous unions can nest, we must also search all anonymous unions
   that are directly reachable.  */
static tree
lookup_anon_field (t, type)
     tree t, type;
  tree field;
  for (field = TYPE_FIELDS (t); field; field = TREE_CHAIN (field))
      if (TREE_STATIC (field))
	continue;
      if (TREE_CODE (field) != FIELD_DECL)
	continue;
      /* If we find it directly, return the field.  */
      if (DECL_NAME (field) == NULL_TREE
	  && type == TREE_TYPE (field))
	  return field;
      /* Otherwise, it could be nested, search harder.  */
	  && ANON_AGGR_TYPE_P (TREE_TYPE (field)))
	  tree subfield = lookup_anon_field (TREE_TYPE (field), type);
	  if (subfield)
	    return subfield;
  return NULL_TREE;
/* Build a COMPONENT_REF for a given DATUM, and it's member COMPONENT.
   COMPONENT can be an IDENTIFIER_NODE that is the name of the member
   that we are interested in, or it can be a FIELD_DECL.  */
tree
build_component_ref (datum, component, basetype_path, protect)
     tree datum, component, basetype_path;
     int protect;
  register tree basetype;
  register tree field = NULL;
  register tree ref;
  tree field_type;
  int type_quals;
    return build_min_nt (COMPONENT_REF, datum, component);
      || TREE_TYPE (datum) == error_mark_node)
  /* BASETYPE holds the type of the class containing the COMPONENT.  */
  basetype = TYPE_MAIN_VARIANT (TREE_TYPE (datum));
  /* If DATUM is a COMPOUND_EXPR or COND_EXPR, move our reference
     inside it.  */
  switch (TREE_CODE (datum))
    case COMPOUND_EXPR:
	tree value = build_component_ref (TREE_OPERAND (datum, 1), component,
					  basetype_path, protect);
	return build (COMPOUND_EXPR, TREE_TYPE (value),
		      TREE_OPERAND (datum, 0), value);
    case COND_EXPR:
      return build_conditional_expr
	(TREE_OPERAND (datum, 0),
			      basetype_path, protect),
	 build_component_ref (TREE_OPERAND (datum, 2), component,
			      basetype_path, protect));
    case TEMPLATE_DECL:
      cp_error ("invalid use of %D", datum);
      datum = error_mark_node;
      break;
    default:
      break;
  code = TREE_CODE (basetype);
      datum = convert_from_reference (datum);
  if (TREE_CODE (datum) == OFFSET_REF)
      datum = resolve_offset_ref (datum);
  /* First, see if there is a field or component with name COMPONENT.  */
  if (TREE_CODE (component) == TREE_LIST)
      /* I could not trigger this code. MvL */
      my_friendly_abort (980326);
#ifdef DEAD
      my_friendly_assert (!(TREE_CHAIN (component) == NULL_TREE
		&& DECL_CHAIN (TREE_VALUE (component)) == NULL_TREE), 309);
#endif
      return build (COMPONENT_REF, TREE_TYPE (component), datum, component);
  if (! IS_AGGR_TYPE_CODE (code))
      if (code != ERROR_MARK)
	cp_error ("request for member `%D' in `%E', which is of non-aggregate type `%T'",
		  component, datum, basetype);
  if (!complete_type_or_else (basetype, datum))
  if (TREE_CODE (component) == BIT_NOT_EXPR)
      if (TYPE_IDENTIFIER (basetype) != TREE_OPERAND (component, 0))
	  cp_error ("destructor specifier `%T::~%T' must have matching names",
		    basetype, TREE_OPERAND (component, 0));
      if (! TYPE_HAS_DESTRUCTOR (basetype))
	  cp_error ("type `%T' has no destructor", basetype);
      return TREE_VEC_ELT (CLASSTYPE_METHOD_VEC (basetype), 1);
  /* Look up component name in the structure type definition.  */
  if (CLASSTYPE_VFIELD (basetype)
      && DECL_NAME (CLASSTYPE_VFIELD (basetype)) == component)
    /* Special-case this because if we use normal lookups in an ambiguous
       hierarchy, the compiler will abort (because vptr lookups are
       not supposed to be ambiguous.  */
    field = CLASSTYPE_VFIELD (basetype);
  else if (TREE_CODE (component) == FIELD_DECL)
    field = component;
  else if (TREE_CODE (component) == TYPE_DECL)
      cp_error ("invalid use of type decl `%#D' as expression", component);
  else if (TREE_CODE (component) == TEMPLATE_DECL)
      cp_error ("invalid use of template `%#D' as expression", component);
  else
      tree name = component;
      if (TREE_CODE (component) == VAR_DECL)
	name = DECL_NAME (component);
      if (basetype_path == NULL_TREE)
	basetype_path = TYPE_BINFO (basetype);
      field = lookup_field (basetype_path, name,
			    protect && !VFIELD_NAME_P (name), 0);
      if (field == error_mark_node)
      if (field == NULL_TREE)
	  /* Not found as a data field, look for it as a method.  If found,
	     then if this is the only possible one, return it, else
	     report ambiguity error.  */
	  tree fndecls = lookup_fnfields (basetype_path, name, 1);
	  if (fndecls == error_mark_node)
	  if (fndecls)
	      /* If the function is unique and static, we can resolve it
		 now.  Otherwise, we have to wait and see what context it is
		 used in; a component_ref involving a non-static member
		 function can only be used in a call (expr.ref).  */
	      if (TREE_CHAIN (fndecls) == NULL_TREE
		  && TREE_CODE (TREE_VALUE (fndecls)) == FUNCTION_DECL)
		  if (DECL_STATIC_FUNCTION_P (TREE_VALUE (fndecls)))
		      tree fndecl = TREE_VALUE (fndecls);
		      enforce_access (TREE_PURPOSE (fndecls), fndecl);
		      mark_used (fndecl);
		      return fndecl;
		  else
		      /* A unique non-static member function.  Other parts
			 of the compiler expect something with
			 unknown_type_node to be really overloaded, so
			 let's oblige.  */
			= scratch_ovl_cons (TREE_VALUE (fndecls), NULL_TREE);
	      ref = build (COMPONENT_REF, unknown_type_node,
			   datum, TREE_VALUE (fndecls));
	      return ref;
	  cp_error ("`%#T' has no member named `%D'", basetype, name);
      else if (TREE_TYPE (field) == error_mark_node)
	  if (TREE_CODE (field) == TYPE_DECL)
	    cp_pedwarn ("invalid use of type decl `%#D' as expression", field);
	  else if (DECL_RTL (field) != 0)
	    mark_used (field);
	  else
	    TREE_USED (field) = 1;
	  return field;
  /* See if we have to do any conversions so that we pick up the field from the
     right context.  */
  if (DECL_FIELD_CONTEXT (field) != basetype)
      tree context = DECL_FIELD_CONTEXT (field);
      tree base = context;
      while (!same_type_p (base, basetype) && TYPE_NAME (base)
	     && ANON_AGGR_TYPE_P (base))
	  base = TYPE_CONTEXT (base);
      /* Handle base classes here...  */
      if (base != basetype && TYPE_USES_COMPLEX_INHERITANCE (basetype))
	  tree addr = build_unary_op (ADDR_EXPR, datum, 0);
	  if (integer_zerop (addr))
	      error ("invalid reference to NULL ptr, use ptr-to-member instead");
	  if (VBASE_NAME_P (DECL_NAME (field)))
	      /* It doesn't matter which vbase pointer we grab, just
		 find one of them.  */
	      tree binfo = get_binfo (base,
				      TREE_TYPE (TREE_TYPE (addr)), 0);
	      addr = convert_pointer_to_real (binfo, addr);
	  else
	    addr = convert_pointer_to (base, addr);
	  datum = build_indirect_ref (addr, NULL_PTR);
	  my_friendly_assert (datum != error_mark_node, 311);
      basetype = base;
      /* Handle things from anon unions here...  */
      if (TYPE_NAME (context) && ANON_AGGR_TYPE_P (context))
	  tree subfield = lookup_anon_field (basetype, context);
	  tree subdatum = build_component_ref (datum, subfield,
	  return build_component_ref (subdatum, field, basetype_path, protect);
  /* Compute the type of the field, as described in [expr.ref].  */
  type_quals = TYPE_UNQUALIFIED;
  field_type = TREE_TYPE (field);
  if (TREE_CODE (field_type) == REFERENCE_TYPE)
    /* The standard says that the type of the result should be the
       type referred to by the reference.  But for now, at least, we
       do the conversion from reference type later.  */
  else
      type_quals = (CP_TYPE_QUALS (field_type)
		    | CP_TYPE_QUALS (TREE_TYPE (datum)));
      /* A field is const (volatile) if the enclosing object, or the
	 field itself, is const (volatile).  But, a mutable field is
	 not const, even within a const object.  */
      if (DECL_LANG_SPECIFIC (field) && DECL_MUTABLE_P (field))
	type_quals &= ~TYPE_QUAL_CONST;
      if (!IS_SIGNATURE (field_type))
	field_type = cp_build_qualified_type (field_type, type_quals);
  ref = fold (build (COMPONENT_REF, field_type,
		     break_out_cleanups (datum), field));
  /* Mark the expression const or volatile, as appropriate.  Even
     though we've dealt with the type above, we still have to mark the
     expression itself.  */
  if (type_quals & TYPE_QUAL_CONST)
    TREE_READONLY (ref) = 1;
  else if (type_quals & TYPE_QUAL_VOLATILE)
    TREE_THIS_VOLATILE (ref) = 1;
  return ref;
/* Variant of build_component_ref for use in expressions, which should
   never have REFERENCE_TYPE.  */
tree
build_x_component_ref (datum, component, basetype_path, protect)
     int protect;
  tree t = build_component_ref (datum, component, basetype_path, protect);
  if (! processing_template_decl)
    t = convert_from_reference (t);
  return t;
/* Given an expression PTR for a pointer, return an expression
   for the value pointed to.
   ERRORSTRING is the name of the operator to appear in error messages.
   This function may need to overload OPERATOR_FNNAME.
   Must also handle REFERENCE_TYPEs for C++.  */
tree
build_x_indirect_ref (ptr, errorstring)
     tree ptr;
     const char *errorstring;
  tree rval;
    return build_min_nt (INDIRECT_REF, ptr);
  rval = build_opfncall (INDIRECT_REF, LOOKUP_NORMAL, ptr, NULL_TREE,
			 NULL_TREE);
  if (rval)
    return rval;
  return build_indirect_ref (ptr, errorstring);
tree
     tree ptr;
  register tree pointer, type;
  if (ptr == error_mark_node)
  if (ptr == current_class_ptr)
    return current_class_ref;
  pointer = (TREE_CODE (TREE_TYPE (ptr)) == REFERENCE_TYPE
	     ? ptr : default_conversion (ptr));
  type = TREE_TYPE (pointer);
  if (TYPE_PTR_P (type) || TREE_CODE (type) == REFERENCE_TYPE)
      /* [expr.unary.op]
	 If the type of the expression is "pointer to T," the type
	 of  the  result  is  "T."
         We must use the canonical variant because certain parts of
	 the back end, like fold, do pointer comparisons between
	 types.  */
      tree t = canonical_type_variant (TREE_TYPE (type));
      if (TREE_CODE (pointer) == ADDR_EXPR
	  && !flag_volatile
	  && same_type_p (t, TREE_TYPE (TREE_OPERAND (pointer, 0))))
	/* The POINTER was something like `&x'.  We simplify `*&x' to
	   `x'.  */
	return TREE_OPERAND (pointer, 0);
      else
	  tree ref = build1 (INDIRECT_REF, t, pointer);
	  /* We *must* set TREE_READONLY when dereferencing a pointer to const,
	     so that we get the proper error message if the result is used
	     to assign to.  Also, &* is supposed to be a no-op.  */
	  TREE_READONLY (ref) = CP_TYPE_CONST_P (t);
	  TREE_THIS_VOLATILE (ref) = CP_TYPE_VOLATILE_P (t);
	  TREE_SIDE_EFFECTS (ref)
	    = (TREE_THIS_VOLATILE (ref) || TREE_SIDE_EFFECTS (pointer)
	       || flag_volatile);
	  return ref;
  /* `pointer' won't be an error_mark_node if we were given a
     pointer to member, so it's cool to check for this here.  */
  else if (TYPE_PTRMEM_P (type) || TYPE_PTRMEMFUNC_P (type))
    error ("invalid use of `%s' on pointer to member", errorstring);
  else if (TREE_CODE (type) == RECORD_TYPE
	   && (IS_SIGNATURE_POINTER (type) || IS_SIGNATURE_REFERENCE (type)))
    error ("cannot dereference signature pointer/reference");
  else if (pointer != error_mark_node)
      if (errorstring)
	error ("invalid type argument of `%s'", errorstring);
      else
	error ("invalid type argument");
/* This handles expressions of the form "a[i]", which denotes
   an array reference.
   This is logically equivalent in C to *(a+i), but we may do it differently.
   If A is a variable or a member, we generate a primitive ARRAY_REF.
   This avoids forcing the array out of registers, and can work on
   arrays that are not lvalues (for example, members of structures returned
   by functions).
   If INDEX is of some user-defined type, it must be converted to
   integer type.  Otherwise, to make a compatible PLUS_EXPR, it
   will inherit the type of the array, which will be some pointer type.  */
tree
build_array_ref (array, idx)
     tree array, idx;
  if (idx == 0)
      error ("subscript missing in array reference");
  if (TREE_TYPE (array) == error_mark_node
      || TREE_TYPE (idx) == error_mark_node)
  if (TREE_CODE (TREE_TYPE (array)) == ARRAY_TYPE
      && TREE_CODE (array) != INDIRECT_REF)
      tree rval, type;
      /* Subscripting with type char is likely to lose
	 on a machine where chars are signed.
	 So warn on any machine, but optionally.
	 Don't warn for unsigned char since that type is safe.
	 Don't warn for signed char because anyone who uses that
	 must have done so deliberately.  */
      if (warn_char_subscripts
	  && TYPE_MAIN_VARIANT (TREE_TYPE (idx)) == char_type_node)
	warning ("array subscript has type `char'");
      /* Apply default promotions *after* noticing character types.  */
      idx = default_conversion (idx);
      if (TREE_CODE (TREE_TYPE (idx)) != INTEGER_TYPE)
	  error ("array subscript is not an integer");
      /* An array that is indexed by a non-constant
	 cannot be stored in a register; we must be able to do
	 address arithmetic on its address.
	 Likewise an array of elements of variable size.  */
      if (TREE_CODE (idx) != INTEGER_CST
	  || (TYPE_SIZE (TREE_TYPE (TREE_TYPE (array))) != 0
	      && (TREE_CODE (TYPE_SIZE (TREE_TYPE (TREE_TYPE (array))))
		  != INTEGER_CST)))
	  if (mark_addressable (array) == 0)
      /* An array that is indexed by a constant value which is not within
	 the array bounds cannot be stored in a register either; because we
	 would get a crash in store_bit_field/extract_bit_field when trying
	 to access a non-existent part of the register.  */
      if (TREE_CODE (idx) == INTEGER_CST
	  && TYPE_VALUES (TREE_TYPE (array))
	  && ! int_fits_type_p (idx, TYPE_VALUES (TREE_TYPE (array))))
      if (pedantic && !lvalue_p (array))
	pedwarn ("ANSI C++ forbids subscripting non-lvalue array");
      /* Note in C++ it is valid to subscript a `register' array, since
	 it is valid to take the address of something with that
	 storage specification.  */
      if (extra_warnings)
	  tree foo = array;
	  while (TREE_CODE (foo) == COMPONENT_REF)
	    foo = TREE_OPERAND (foo, 0);
	  if (TREE_CODE (foo) == VAR_DECL && DECL_REGISTER (foo))
	    warning ("subscripting array declared `register'");
      type = TREE_TYPE (TREE_TYPE (array));
      rval = build (ARRAY_REF, type, array, idx);
      /* Array ref is const/volatile if the array elements are
	 or if the array is..  */
      TREE_READONLY (rval)
	|= (CP_TYPE_CONST_P (type) | TREE_READONLY (array));
      TREE_SIDE_EFFECTS (rval)
	|= (CP_TYPE_VOLATILE_P (type) | TREE_SIDE_EFFECTS (array));
      TREE_THIS_VOLATILE (rval)
	|= (CP_TYPE_VOLATILE_P (type) | TREE_THIS_VOLATILE (array));
      return require_complete_type (fold (rval));
    tree ar = default_conversion (array);
    tree ind = default_conversion (idx);
    /* Put the integer in IND to simplify error checking.  */
    if (TREE_CODE (TREE_TYPE (ar)) == INTEGER_TYPE)
	tree temp = ar;
	ar = ind;
	ind = temp;
    if (ar == error_mark_node)
      return ar;
    if (TREE_CODE (TREE_TYPE (ar)) != POINTER_TYPE)
	error ("subscripted value is neither array nor pointer");
    if (TREE_CODE (TREE_TYPE (ind)) != INTEGER_TYPE)
    return build_indirect_ref (build_binary_op_nodefault (PLUS_EXPR, ar,
							  ind, PLUS_EXPR),
			       "array indexing");
/* Build a function call to function FUNCTION with parameters PARAMS.
   PARAMS is a list--a chain of TREE_LIST nodes--in which the
   TREE_VALUE of each node is a parameter-expression.  The PARAMS do
   not include any object pointer that may be required.  FUNCTION's
   data type may be a function type or a pointer-to-function.
   For C++: If FUNCTION's data type is a TREE_LIST, then the tree list
   is the list of possible methods that FUNCTION could conceivably
   be.  If the list of methods comes from a class, then it will be
   a list of lists (where each element is associated with the class
   that produced it), otherwise it will be a simple list (for
   functions overloaded in global scope).
   In the first case, TREE_VALUE (function) is the head of one of those
   lists, and TREE_PURPOSE is the name of the function.
   In the second case, TREE_PURPOSE (function) is the function's
   name directly.
   DECL is the class instance variable, usually CURRENT_CLASS_REF.
   When calling a TEMPLATE_DECL, we don't require a complete return
   type.  */
tree
build_x_function_call (function, params, decl)
     tree function, params, decl;
  tree type;
  tree template_id = NULL_TREE;
  int is_method;
  if (function == error_mark_node)
    return build_min_nt (CALL_EXPR, function, params, NULL_TREE);
  /* Save explicit template arguments if found */
  if (TREE_CODE (function) == TEMPLATE_ID_EXPR)
      template_id = function;
      function = TREE_OPERAND (function, 0);
  type = TREE_TYPE (function);
  if (TREE_CODE (type) == OFFSET_TYPE
      && TREE_TYPE (type) == unknown_type_node
      && TREE_CODE (function) == TREE_LIST
      && TREE_CHAIN (function) == NULL_TREE)
      /* Undo (Foo:bar)()...  */
      function = TREE_VALUE (function);
      my_friendly_assert (TREE_CODE (function) == TREE_LIST, 999);
      my_friendly_assert (TREE_CHAIN (function) == NULL_TREE, 999);
      if (TREE_CODE (function) == OVERLOAD)
	function = OVL_FUNCTION (function);
      my_friendly_assert (TREE_CODE (function) == FUNCTION_DECL, 999);
      function = DECL_NAME (function);
      return build_method_call (decl, function, params,
				TYPE_BINFO (type), LOOKUP_NORMAL);
  if ((TREE_CODE (function) == FUNCTION_DECL
       && DECL_STATIC_FUNCTION_P (function))
      || (TREE_CODE (function) == TEMPLATE_DECL
	  && DECL_STATIC_FUNCTION_P (DECL_RESULT (function))))
      return build_member_call(DECL_CONTEXT (function),
			       template_id
			       ? template_id : DECL_NAME (function),
			       params);
  is_method = ((TREE_CODE (function) == TREE_LIST
		&& current_class_type != NULL_TREE
		&& (IDENTIFIER_CLASS_VALUE (TREE_PURPOSE (function))
		    == function))
		   && DECL_FUNCTION_MEMBER_P (OVL_CURRENT (function)))
	       || TREE_CODE (function) == IDENTIFIER_NODE
	       || TREE_CODE (type) == METHOD_TYPE
	       || TYPE_PTRMEMFUNC_P (type));
  /* A friend template.  Make it look like a toplevel declaration.  */
  if (! is_method && TREE_CODE (function) == TEMPLATE_DECL)
    function = scratch_ovl_cons (function, NULL_TREE);
  /* Handle methods, friends, and overloaded functions, respectively.  */
  if (is_method)
      tree basetype = NULL_TREE;
	function = OVL_CURRENT (function);
      if (TREE_CODE (function) == FUNCTION_DECL
	  || DECL_FUNCTION_TEMPLATE_P (function))
	  basetype = DECL_CLASS_CONTEXT (function);
	  if (DECL_NAME (function))
	  else
	    function = TYPE_IDENTIFIER (DECL_CLASS_CONTEXT (function));
      else if (TREE_CODE (function) == TREE_LIST)
	  my_friendly_assert (TREE_CODE (TREE_VALUE (function))
			      == FUNCTION_DECL, 312);
	  basetype = DECL_CLASS_CONTEXT (TREE_VALUE (function));
	  function = TREE_PURPOSE (function);
      else if (TREE_CODE (function) != IDENTIFIER_NODE)
	  if (TREE_CODE (function) == OFFSET_REF)
	      if (TREE_OPERAND (function, 0))
		decl = TREE_OPERAND (function, 0);
	  /* Call via a pointer to member function.  */
	  if (decl == NULL_TREE)
	      error ("pointer to member function called, but not in class scope");
	      return error_mark_node;
	  /* What other type of POINTER_TYPE could this be? */
	  if (TREE_CODE (TREE_TYPE (function)) != POINTER_TYPE
	      && ! TYPE_PTRMEMFUNC_P (TREE_TYPE (function))
	      && TREE_CODE (function) != OFFSET_REF)
	    function = build (OFFSET_REF, TREE_TYPE (type), NULL_TREE,
			      function);
	  goto do_x_function;
      /* this is an abbreviated method call.
         must go through here in case it is a virtual function.
	 @@ Perhaps this could be optimized.  */
      if (basetype && (! current_class_type
		       || ! DERIVED_FROM_P (basetype, current_class_type)))
	return build_member_call (basetype, function, params);
	  if (current_class_type == NULL_TREE)
	      cp_error ("object missing in call to method `%D'", function);
	  /* Yow: call from a static member function.  */
	  decl = build_dummy_object (current_class_type);
      /* Put back explicit template arguments, if any.  */
      if (template_id)
        function = template_id;
				NULL_TREE, LOOKUP_NORMAL);
  else if (TREE_CODE (function) == COMPONENT_REF
	   && type == unknown_type_node)
      /* Undo what we did in build_component_ref.  */
      function = TREE_OPERAND (function, 1);
      function = DECL_NAME (OVL_CURRENT (function));
      if (template_id)
	  TREE_OPERAND (template_id, 0) = function;
  else if (really_overloaded_fn (function))
      if (OVL_FUNCTION (function) == NULL_TREE)
	  cp_error ("function `%D' declared overloaded, but no definitions appear with which to resolve it?!?",
		    TREE_PURPOSE (function));
      else
	  if (template_id)
	  return build_new_function_call (function, params);
  else
    /* Remove a potential OVERLOAD around it */
 do_x_function:
      /* If the component is a data element (or a virtual function), we play
	 games here to make things work.  */
      tree decl_addr;
      else
	decl = current_class_ref;
      decl_addr = build_unary_op (ADDR_EXPR, decl, 0);
      /* Sigh.  OFFSET_REFs are being used for too many things.
	 They're being used both for -> and ->*, and we want to resolve
	 the -> cases here, but leave the ->*.  We could use
	 resolve_offset_ref for those, too, but it would call
         get_member_function_from_ptrfunc and decl_addr wouldn't get
         updated properly.  Nasty.  */
      if (TREE_CODE (TREE_OPERAND (function, 1)) == FIELD_DECL)
	function = resolve_offset_ref (function);
      else
      function = get_member_function_from_ptrfunc (&decl_addr, function);
      params = expr_tree_cons (NULL_TREE, decl_addr, params);
      return build_function_call (function, params);
  if (type != error_mark_node)
      if (TREE_CODE (type) == REFERENCE_TYPE)
      if (IS_AGGR_TYPE (type))
	return build_opfncall (CALL_EXPR, LOOKUP_NORMAL, function, params, NULL_TREE);
  if (is_method)
      tree fntype = TREE_TYPE (function);
      tree ctypeptr = NULL_TREE;
      /* Explicitly named method?  */
      if (TREE_CODE (function) == FUNCTION_DECL)
	ctypeptr = build_pointer_type (DECL_CLASS_CONTEXT (function));
      /* Expression with ptr-to-method type?  It could either be a plain
	 usage, or it might be a case where the ptr-to-method is being
	 passed in as an argument.  */
      else if (TYPE_PTRMEMFUNC_P (fntype))
	  tree rec = TYPE_METHOD_BASETYPE (TREE_TYPE
					   (TYPE_PTRMEMFUNC_FN_TYPE (fntype)));
	  ctypeptr = build_pointer_type (rec);
      /* Unexpected node type?  */
      else
	my_friendly_abort (116);
	  if (current_function_decl
	      && DECL_STATIC_FUNCTION_P (current_function_decl))
	    error ("invalid call to member function needing `this' in static member function scope");
	  else
      if (TREE_CODE (TREE_TYPE (decl)) != POINTER_TYPE
	  && ! TYPE_PTRMEMFUNC_P (TREE_TYPE (decl)))
	  decl = build_unary_op (ADDR_EXPR, decl, 0);
	  decl = convert_pointer_to (TREE_TYPE (ctypeptr), decl);
      else
	decl = build_c_cast (ctypeptr, decl);
      params = expr_tree_cons (NULL_TREE, decl, params);
/* Resolve a pointer to member function.  INSTANCE is the object
   instance to use, if the member points to a virtual member.  */
tree
get_member_function_from_ptrfunc (instance_ptrptr, function)
     tree *instance_ptrptr;
     tree function;
  if (TYPE_PTRMEMFUNC_P (TREE_TYPE (function)))
      tree fntype, idx, e1, delta, delta2, e2, e3, aref, vtbl;
      tree instance, basetype;
      tree instance_ptr = *instance_ptrptr;
      if (TREE_SIDE_EFFECTS (instance_ptr))
	instance_ptr = save_expr (instance_ptr);
      if (TREE_SIDE_EFFECTS (function))
	function = save_expr (function);
      fntype = TYPE_PTRMEMFUNC_FN_TYPE (TREE_TYPE (function));
      basetype = TYPE_METHOD_BASETYPE (TREE_TYPE (fntype));
      delta = cp_convert (ptrdiff_type_node,
			  build_component_ref (function, delta_identifier,
					       NULL_TREE, 0));
      e3 = PFN_FROM_PTRMEMFUNC (function);
      if (TYPE_SIZE (basetype) != NULL_TREE
	  && ! TYPE_VIRTUAL_P (basetype))
	/* If basetype doesn't have virtual functions, don't emit code to
	   handle that case.  */
	e1 = e3;
      else
	  /* Promoting idx before saving it improves performance on RISC
	     targets.  Without promoting, the first compare used
	     load-with-sign-extend, while the second used normal load then
	     shift to sign-extend.  An optimizer flaw, perhaps, but it's
	     easier to make this change.  */
	  idx = save_expr (default_conversion
			   (build_component_ref (function,
						 index_identifier,
						 NULL_TREE, 0)));
	  e1 = build_binary_op (GE_EXPR, idx, integer_zero_node);
	  /* Convert down to the right base, before using the instance.  */
	  instance = convert_pointer_to_real (basetype, instance_ptr);
	  if (instance == error_mark_node && instance_ptr != error_mark_node)
	    return instance;
	  vtbl = convert_pointer_to (ptr_type_node, instance);
	  delta2 = DELTA2_FROM_PTRMEMFUNC (function);
	  vtbl = build
	    (PLUS_EXPR,
	     build_pointer_type (build_pointer_type (vtable_entry_type)),
	     vtbl, cp_convert (ptrdiff_type_node, delta2));
	  vtbl = build_indirect_ref (vtbl, NULL_PTR);
	  aref = build_array_ref (vtbl, build_binary_op (MINUS_EXPR,
							 idx,
							 integer_one_node));
	  if (! flag_vtable_thunks)
	      aref = save_expr (aref);
	      delta = build_binary_op
		(PLUS_EXPR,
		 build_conditional_expr (e1,
					 build_component_ref (aref,
							      delta_identifier,
							      NULL_TREE, 0),
					 integer_zero_node),
		 delta);
	  if (flag_vtable_thunks)
	    e2 = aref;
	  else
	    e2 = build_component_ref (aref, pfn_identifier, NULL_TREE, 0);
	  TREE_TYPE (e2) = TREE_TYPE (e3);
	  e1 = build_conditional_expr (e1, e2, e3);
	  /* Make sure this doesn't get evaluated first inside one of the
	     branches of the COND_EXPR.  */
	  if (TREE_CODE (instance_ptr) == SAVE_EXPR)
	    e1 = build (COMPOUND_EXPR, TREE_TYPE (e1),
			instance_ptr, e1);
      *instance_ptrptr = build (PLUS_EXPR, TREE_TYPE (instance_ptr),
				instance_ptr, delta);
      if (instance_ptr == error_mark_node
	  && TREE_CODE (e1) != ADDR_EXPR
	  && TREE_CODE (TREE_OPERAND (e1, 0)) != FUNCTION_DECL)
	cp_error ("object missing in `%E'", function);
      function = e1;
  return function;
tree
build_function_call_real (function, params, require_complete, flags)
     tree function, params;
     int require_complete, flags;
  register tree fntype, fndecl;
  register tree value_type;
  register tree coerced_params;
  tree name = NULL_TREE, assembler_name = NULL_TREE;
  int is_method;
     Strip such NOP_EXPRs, since FUNCTION is used in non-lvalue context.  */
  if (TREE_CODE (function) == NOP_EXPR
      && TREE_TYPE (function) == TREE_TYPE (TREE_OPERAND (function, 0)))
      && DECL_TARGET_OVERLOADED_INTRINSIC_P (function))
#ifdef SELECT_TARGET_OVERLOADED_INTRINSIC
      /* If this is an overloaded builtin function, we have to select
	 which overload to use now.  */
      function = SELECT_TARGET_OVERLOADED_INTRINSIC (function, params);
      if (function == NULL_TREE)
#endif
      name = DECL_NAME (function);
      assembler_name = DECL_ASSEMBLER_NAME (function);
      GNU_xref_call (current_function_decl,
		     IDENTIFIER_POINTER (name ? name
					 : TYPE_IDENTIFIER (DECL_CLASS_CONTEXT
							    (function))));
      mark_used (function);
      fndecl = function;
      /* Convert anything with function type to a pointer-to-function.  */
      if (pedantic && DECL_MAIN_P (function))
	pedwarn ("ANSI C++ forbids calling `main' from within program");
      /* Differs from default_conversion by not setting TREE_ADDRESSABLE
	 (because calling an inline function does not mean the function
	 needs to be separately compiled).  */
      if (DECL_INLINE (function))
	function = inline_conversion (function);
      else
	function = build_addr_func (function);
  else
      fndecl = NULL_TREE;
      cp_error ("must use .* or ->* to call pointer-to-member function in `%E (...)'",
		function);
  is_method = (TREE_CODE (fntype) == POINTER_TYPE
	       && TREE_CODE (TREE_TYPE (fntype)) == METHOD_TYPE);
  if (!((TREE_CODE (fntype) == POINTER_TYPE
	 && TREE_CODE (TREE_TYPE (fntype)) == FUNCTION_TYPE)
	|| is_method
	|| TREE_CODE (function) == TEMPLATE_ID_EXPR))
      cp_error ("`%E' cannot be used as a function", function);
  /* fntype now gets the type of function pointed to.  */
  fntype = TREE_TYPE (fntype);
  /* Convert the parameters to the types declared in the
     function prototype, or apply default promotions.  */
  if (flags & LOOKUP_COMPLAIN)
    coerced_params = convert_arguments (TYPE_ARG_TYPES (fntype),
					params, fndecl, LOOKUP_NORMAL);
  else
					params, fndecl, 0);
  if (coerced_params == error_mark_node)
      if (flags & LOOKUP_SPECULATIVELY)
	return NULL_TREE;
      else
  /* Check for errors in format strings.  */
  if (warn_format && (name || assembler_name))
    check_function_format (name, assembler_name, coerced_params);
  /* Recognize certain built-in functions so we can make tree-codes
     other than CALL_EXPR.  We do this when it enables fold-const.c
     to do something useful.  */
  if (TREE_CODE (function) == ADDR_EXPR
      && TREE_CODE (TREE_OPERAND (function, 0)) == FUNCTION_DECL
      && DECL_BUILT_IN (TREE_OPERAND (function, 0)))
    switch (DECL_FUNCTION_CODE (TREE_OPERAND (function, 0)))
      case BUILT_IN_ABS:
      case BUILT_IN_LABS:
      case BUILT_IN_FABS:
	if (coerced_params == 0)
	  return integer_zero_node;
	return build_unary_op (ABS_EXPR, TREE_VALUE (coerced_params), 0);
      default:
	break;
  /* C++ */
  value_type = TREE_TYPE (fntype) ? TREE_TYPE (fntype) : void_type_node;
    register tree result
      = build_call (function, value_type, coerced_params);
    if (require_complete)
	if (TREE_CODE (value_type) == VOID_TYPE)
	  return result;
	result = require_complete_type (result);
    if (IS_AGGR_TYPE (value_type))
      result = build_cplus_new (value_type, result);
    return convert_from_reference (result);
tree
  return build_function_call_real (function, params, 1, LOOKUP_NORMAL);
/* Convert the actual parameter expressions in the list VALUES
   to the types in the list TYPELIST.
   If parmdecls is exhausted, or when an element has NULL as its type,
   perform the default conversions.
   NAME is an IDENTIFIER_NODE or 0.  It is used only for error messages.
   This is also where warnings about wrong number of args are generated.
   Return a list of expressions for the parameters as converted.
   Both VALUES and the returned value are chains of TREE_LIST nodes
   with the elements of the list in the TREE_VALUE slots of those nodes.
   In C++, unspecified trailing parameters can be filled in with their
   default arguments, if such were specified.  Do so here.  */
tree
convert_arguments (typelist, values, fndecl, flags)
     tree typelist, values, fndecl;
     int flags;
  register tree typetail, valtail;
  register tree result = NULL_TREE;
  const char *called_thing = 0;
  int i = 0;
  /* Argument passing is always copy-initialization.  */
  flags |= LOOKUP_ONLYCONVERTING;
  if (fndecl)
      if (TREE_CODE (TREE_TYPE (fndecl)) == METHOD_TYPE)
	  if (DECL_NAME (fndecl) == NULL_TREE
	      || IDENTIFIER_HAS_TYPE_VALUE (DECL_NAME (fndecl)))
	    called_thing = "constructor";
	  else
	    called_thing = "member function";
      else
	called_thing = "function";
  for (valtail = values, typetail = typelist;
       valtail;
       valtail = TREE_CHAIN (valtail), i++)
      register tree type = typetail ? TREE_VALUE (typetail) : 0;
      if (val == error_mark_node)
      if (type == void_type_node)
	  if (fndecl)
	      cp_error_at ("too many arguments to %s `%+#D'", called_thing,
			   fndecl);
	      error ("at this point in file");
	  else
	    error ("too many arguments to function");
	  /* In case anybody wants to know if this argument
	     list is valid.  */
	  if (result)
	    TREE_TYPE (tree_last (result)) = error_mark_node;
	  break;
      if (TREE_CODE (val) == OFFSET_REF)
	val = resolve_offset_ref (val);
	 Strip such NOP_EXPRs, since VAL is used in non-lvalue context.  */
      if (TREE_CODE (val) == NOP_EXPR
	  && TREE_TYPE (val) == TREE_TYPE (TREE_OPERAND (val, 0))
	  && (type == 0 || TREE_CODE (type) != REFERENCE_TYPE))
	val = TREE_OPERAND (val, 0);
      if (type == 0 || TREE_CODE (type) != REFERENCE_TYPE)
	  if (TREE_CODE (TREE_TYPE (val)) == ARRAY_TYPE
	      || TREE_CODE (TREE_TYPE (val)) == FUNCTION_TYPE
	      || TREE_CODE (TREE_TYPE (val)) == METHOD_TYPE)
	    val = default_conversion (val);
      if (type != 0)
	  /* Formal parm type is specified by a function prototype.  */
	  tree parmval;
	      error ("parameter type of called function is incomplete");
	      parmval = val;
	  else
	      parmval = convert_for_initialization
		(NULL_TREE, type, val, flags,
		 "argument passing", fndecl, i);
#ifdef PROMOTE_PROTOTYPES
	      if ((TREE_CODE (type) == INTEGER_TYPE
		   || TREE_CODE (type) == ENUMERAL_TYPE)
		  && (TYPE_PRECISION (type)
		      < TYPE_PRECISION (integer_type_node)))
		parmval = default_conversion (parmval);
#endif
	  if (parmval == error_mark_node)
	  result = expr_tree_cons (NULL_TREE, parmval, result);
      else
	  if (TREE_CODE (TREE_TYPE (val)) == REFERENCE_TYPE)
	    val = convert_from_reference (val);
				   convert_arg_to_ellipsis (val),
				   result);
      if (typetail)
	typetail = TREE_CHAIN (typetail);
  if (typetail != 0 && typetail != void_list_node)
      /* See if there are default arguments that can be used */
      if (TREE_PURPOSE (typetail))
	  for (; typetail != void_list_node; ++i)
	      tree parmval
		= convert_default_arg (TREE_VALUE (typetail),
				       TREE_PURPOSE (typetail),
				       fndecl);
	      result = expr_tree_cons (0, parmval, result);
	      /* ends with `...'.  */
	      if (typetail == NULL_TREE)
		break;
      else
	  if (fndecl)
	      cp_error_at ("too few arguments to %s `%+#D'",
	                   called_thing, fndecl);
	  else
	    error ("too few arguments to function");
	  return error_mark_list;
  return nreverse (result);
/* Build a binary-operation expression, after performing default
   conversions on the operands.  CODE is the kind of expression to build.  */
tree
build_x_binary_op (code, arg1, arg2)
     tree arg1, arg2;
    return build_min_nt (code, arg1, arg2);
  return build_new_op (code, LOOKUP_NORMAL, arg1, arg2, NULL_TREE);
tree
build_binary_op (code, arg1, arg2)
     tree arg1, arg2;
  return build_binary_op_nodefault (code, arg1, arg2, code);
/* Build a binary-operation expression without default conversions.
   This function differs from `build' in several ways:
   the data type of the result is computed and recorded in it,
   warnings are generated if arg data types are invalid,
   special handling for addition and subtraction of pointers is known,
   and some optimization is done (operations on narrow ints
   are done in the narrower type when that gives the same result).
   Constant folding is also done before the result is returned.
   ERROR_CODE is the code that determines what to say in error messages.
   It is usually, but not always, the same as CODE.
   Note that the operands will never have enumeral types
   because either they have just had the default conversions performed
   or they have both just been converted to some other type in which
   the arithmetic is to be done.
   C++: must do special pointer arithmetic when implementing
   multiple inheritance, and deal with pointer to member functions.  */
tree
build_binary_op_nodefault (code, orig_op0, orig_op1, error_code)
     tree orig_op0, orig_op1;
     enum tree_code error_code;
  tree op0, op1;
  register enum tree_code code0, code1;
  tree type0, type1;
  /* Expression code to give to the expression when it is built.
     Normally this is CODE, which is what the caller asked for,
     but in some special cases we change it.  */
  register enum tree_code resultcode = code;
  /* Data type in which the computation is to be performed.
     In the simplest cases this is the common type of the arguments.  */
  register tree result_type = NULL;
  /* Nonzero means operands have already been type-converted
     in whatever way is necessary.
     Zero means they need to be converted to RESULT_TYPE.  */
  int converted = 0;
  /* Nonzero means create the expression with this type, rather than
     RESULT_TYPE.  */
  tree build_type = 0;
  /* Nonzero means after finally constructing the expression
     convert it to this type.  */
  tree final_type = 0;
  /* Nonzero if this is an operation like MIN or MAX which can
     safely be computed in short if both args are promoted shorts.
     Also implies COMMON.
     -1 indicates a bitwise operation; this makes a difference
     in the exact conditions for when it is safe to do the operation
     in a narrower mode.  */
  int shorten = 0;
  /* Nonzero if this is a comparison operation;
     if both args are promoted shorts, compare the original shorts.
     Also implies COMMON.  */
  int short_compare = 0;
  /* Nonzero if this is a right-shift operation, which can be computed on the
     original short and then promoted if the operand is a promoted short.  */
  int short_shift = 0;
  /* Nonzero means set RESULT_TYPE to the common type of the args.  */
  int common = 0;
  /* Apply default conversions.  */
  if (code == TRUTH_AND_EXPR || code == TRUTH_ANDIF_EXPR
      || code == TRUTH_OR_EXPR || code == TRUTH_ORIF_EXPR
      || code == TRUTH_XOR_EXPR)
      op0 = decay_conversion (orig_op0);
      op1 = decay_conversion (orig_op1);
  else
      op0 = default_conversion (orig_op0);
      op1 = default_conversion (orig_op1);
  /* Strip NON_LVALUE_EXPRs, etc., since we aren't using as an lvalue.  */
  STRIP_TYPE_NOPS (op0);
  STRIP_TYPE_NOPS (op1);
  /* DTRT if one side is an overloaded function, but complain about it.  */
  if (type_unknown_p (op0))
      tree t = instantiate_type (TREE_TYPE (op1), op0, 0);
      if (t != error_mark_node)
	  cp_pedwarn ("assuming cast to `%T' from overloaded function",
		      TREE_TYPE (t));
	  op0 = t;
  if (type_unknown_p (op1))
      tree t = instantiate_type (TREE_TYPE (op0), op1, 0);
		      TREE_TYPE (t));
	  op1 = t;
  type0 = TREE_TYPE (op0);
  type1 = TREE_TYPE (op1);
  /* The expression codes of the data types of the arguments tell us
     whether the arguments are integers, floating, pointers, etc.  */
  code0 = TREE_CODE (type0);
  code1 = TREE_CODE (type1);
  /* If an error was already reported for one of the arguments,
     avoid reporting another error.  */
  if (code0 == ERROR_MARK || code1 == ERROR_MARK)
  switch (code)
    case PLUS_EXPR:
      /* Handle the pointer + int case.  */
      if (code0 == POINTER_TYPE && code1 == INTEGER_TYPE)
	return pointer_int_sum (PLUS_EXPR, op0, op1);
      else if (code1 == POINTER_TYPE && code0 == INTEGER_TYPE)
	return pointer_int_sum (PLUS_EXPR, op1, op0);
      else
	common = 1;
      break;
    case MINUS_EXPR:
      /* Subtraction of two similar pointers.
	 We must subtract them as integers, then divide by object size.  */
      if (code0 == POINTER_TYPE && code1 == POINTER_TYPE
	  && comp_target_types (type0, type1, 1))
	return pointer_diff (op0, op1, common_type (type0, type1));
      /* Handle pointer minus int.  Just like pointer plus int.  */
      else if (code0 == POINTER_TYPE && code1 == INTEGER_TYPE)
	return pointer_int_sum (MINUS_EXPR, op0, op1);
      else
	common = 1;
      break;
    case MULT_EXPR:
      common = 1;
      break;
    case TRUNC_DIV_EXPR:
    case CEIL_DIV_EXPR:
    case FLOOR_DIV_EXPR:
    case ROUND_DIV_EXPR:
    case EXACT_DIV_EXPR:
      if ((code0 == INTEGER_TYPE || code0 == REAL_TYPE
	   || code0 == COMPLEX_TYPE)
	  && (code1 == INTEGER_TYPE || code1 == REAL_TYPE
	      || code1 == COMPLEX_TYPE))
	  if (TREE_CODE (op1) == INTEGER_CST && integer_zerop (op1))
	    cp_warning ("division by zero in `%E / 0'", op0);
	  else if (TREE_CODE (op1) == REAL_CST && real_zerop (op1))
	    cp_warning ("division by zero in `%E / 0.'", op0);
	  if (!(code0 == INTEGER_TYPE && code1 == INTEGER_TYPE))
	    resultcode = RDIV_EXPR;
	  else
	    /* When dividing two signed integers, we have to promote to int.
	       unless we divide by a constant != -1.  Note that default
	       conversion will have been performed on the operands at this
	       point, so we have to dig out the original type to find out if
	       it was unsigned.  */
	    shorten = ((TREE_CODE (op0) == NOP_EXPR
			&& TREE_UNSIGNED (TREE_TYPE (TREE_OPERAND (op0, 0))))
			   && (TREE_INT_CST_LOW (op1) != -1
			       || TREE_INT_CST_HIGH (op1) != -1)));
	  common = 1;
      break;
    case BIT_AND_EXPR:
    case BIT_ANDTC_EXPR:
    case BIT_IOR_EXPR:
    case BIT_XOR_EXPR:
      if (code0 == INTEGER_TYPE && code1 == INTEGER_TYPE)
	shorten = -1;
      /* If one operand is a constant, and the other is a short type
	 that has been converted to an int,
	 really do the work in the short type and then convert the
	 result to int.  If we are lucky, the constant will be 0 or 1
	 in the short type, making the entire operation go away.  */
      if (TREE_CODE (op0) == INTEGER_CST
	  && TREE_CODE (op1) == NOP_EXPR
	  && (TYPE_PRECISION (type1)
	      > TYPE_PRECISION (TREE_TYPE (TREE_OPERAND (op1, 0))))
	  && TREE_UNSIGNED (TREE_TYPE (TREE_OPERAND (op1, 0))))
	  final_type = result_type;
	  op1 = TREE_OPERAND (op1, 0);
	  result_type = TREE_TYPE (op1);
	  && TREE_CODE (op0) == NOP_EXPR
	  && (TYPE_PRECISION (type0)
	      > TYPE_PRECISION (TREE_TYPE (TREE_OPERAND (op0, 0))))
	  op0 = TREE_OPERAND (op0, 0);
	  result_type = TREE_TYPE (op0);
      break;
    case TRUNC_MOD_EXPR:
    case FLOOR_MOD_EXPR:
      if (code1 == INTEGER_TYPE && integer_zerop (op1))
	cp_warning ("division by zero in `%E %% 0'", op0);
      else if (code1 == REAL_TYPE && real_zerop (op1))
	cp_warning ("division by zero in `%E %% 0.'", op0);
	  /* Although it would be tempting to shorten always here, that loses
	     on some targets, since the modulo instruction is undefined if the
	     quotient can't be represented in the computation mode.  We shorten
	     only if unsigned or if dividing by something we know != -1.  */
	  common = 1;
      break;
    case TRUTH_ANDIF_EXPR:
    case TRUTH_ORIF_EXPR:
    case TRUTH_AND_EXPR:
    case TRUTH_OR_EXPR:
      result_type = boolean_type_node;
      break;
      /* Shift operations: result has same type as first operand;
	 always convert second operand to int.
	 Also set SHORT_SHIFT if shifting rightward.  */
    case RSHIFT_EXPR:
	  result_type = type0;
	  if (TREE_CODE (op1) == INTEGER_CST)
	      if (tree_int_cst_lt (op1, integer_zero_node))
		warning ("right shift count is negative");
	      else
		  if (TREE_INT_CST_LOW (op1) | TREE_INT_CST_HIGH (op1))
		    short_shift = 1;
		  if (TREE_INT_CST_HIGH (op1) != 0
		      || ((unsigned HOST_WIDE_INT) TREE_INT_CST_LOW (op1)
			  >= TYPE_PRECISION (type0)))
		    warning ("right shift count >= width of type");
	  /* Convert the shift-count to an integer, regardless of
	     size of value being shifted.  */
	  if (TYPE_MAIN_VARIANT (TREE_TYPE (op1)) != integer_type_node)
	    op1 = cp_convert (integer_type_node, op1);
	  /* Avoid converting op1 to result_type later.  */
	  converted = 1;
      break;
    case LSHIFT_EXPR:
		warning ("left shift count is negative");
	      else if (TREE_INT_CST_HIGH (op1) != 0
		warning ("left shift count >= width of type");
	  converted = 1;
      break;
    case RROTATE_EXPR:
    case LROTATE_EXPR:
		warning ("%s rotate count is negative",
			 (code == LROTATE_EXPR) ? "left" : "right");
		warning ("%s rotate count >= width of type",
      break;
    case EQ_EXPR:
    case NE_EXPR:
      build_type = boolean_type_node;
	short_compare = 1;
      else if (code0 == POINTER_TYPE && code1 == POINTER_TYPE)
	  register tree tt0 = TYPE_MAIN_VARIANT (TREE_TYPE (type0));
	  register tree tt1 = TYPE_MAIN_VARIANT (TREE_TYPE (type1));
	  if (comp_target_types (type0, type1, 1))
	    result_type = common_type (type0, type1);
	  else if (tt0 == void_type_node)
	      if (pedantic && TREE_CODE (tt1) == FUNCTION_TYPE
		  && tree_int_cst_lt (TYPE_SIZE (type0), TYPE_SIZE (type1)))
		pedwarn ("ANSI C++ forbids comparison of `void *' with function pointer");
	      else if (TREE_CODE (tt1) == OFFSET_TYPE)
		pedwarn ("ANSI C++ forbids conversion of a pointer to member to `void *'");
	  else if (tt1 == void_type_node)
	      if (pedantic && TREE_CODE (tt0) == FUNCTION_TYPE
		  && tree_int_cst_lt (TYPE_SIZE (type1), TYPE_SIZE (type0)))
	  else
	    cp_pedwarn ("comparison of distinct pointer types `%T' and `%T' lacks a cast",
			type0, type1);
	  if (result_type == NULL_TREE)
	    result_type = ptr_type_node;
      else if (code0 == POINTER_TYPE && TREE_CODE (op1) == INTEGER_CST
      else if (code1 == POINTER_TYPE && TREE_CODE (op0) == INTEGER_CST
	       && integer_zerop (op0))
	result_type = type1;
	  error ("ANSI C++ forbids comparison between pointer and integer");
      else if (code0 == INTEGER_TYPE && code1 == POINTER_TYPE)
      else if (TYPE_PTRMEMFUNC_P (type0) && TREE_CODE (op1) == INTEGER_CST
	  op0 = build_component_ref (op0, index_identifier, NULL_TREE, 0);
	  op1 = integer_zero_node;
      else if (TYPE_PTRMEMFUNC_P (type1) && TREE_CODE (op0) == INTEGER_CST
	  op0 = build_component_ref (op1, index_identifier, NULL_TREE, 0);
      else if (TYPE_PTRMEMFUNC_P (type0) && TYPE_PTRMEMFUNC_P (type1)
	       && same_type_p (type0, type1))
	  /* The code we generate for the test is:
	  (op0.index == op1.index
	   && ((op1.index != -1 && op0.delta2 == op1.delta2)
	       || op0.pfn == op1.pfn)) */
	  tree index0 = build_component_ref (op0, index_identifier,
					     NULL_TREE, 0);
	  tree index1 = save_expr (build_component_ref (op1, index_identifier,
							NULL_TREE, 0));
	  tree pfn0 = PFN_FROM_PTRMEMFUNC (op0);
	  tree pfn1 = PFN_FROM_PTRMEMFUNC (op1);
	  tree delta20 = DELTA2_FROM_PTRMEMFUNC (op0);
	  tree delta21 = DELTA2_FROM_PTRMEMFUNC (op1);
	  tree e1, e2, e3;
	  tree integer_neg_one_node
	    = build_binary_op (MINUS_EXPR, integer_zero_node,
			       integer_one_node);
	  e1 = build_binary_op (EQ_EXPR, index0, index1);
	  e2 = build_binary_op (NE_EXPR, index1, integer_neg_one_node);
	  e2 = build_binary_op (TRUTH_ANDIF_EXPR, e2,
				build_binary_op (EQ_EXPR, delta20, delta21));
	  /* We can't use build_binary_op for this cmp because it would get
	     confused by the ptr to method types and think we want pmfs.  */
	  e3 = build (EQ_EXPR, boolean_type_node, pfn0, pfn1);
	  e2 = build_binary_op (TRUTH_ORIF_EXPR, e2, e3);
	  e2 = build_binary_op (TRUTH_ANDIF_EXPR, e1, e2);
	  if (code == EQ_EXPR)
	    return e2;
	  return build_binary_op (EQ_EXPR, e2, integer_zero_node);
	       && same_type_p (TYPE_PTRMEMFUNC_FN_TYPE (type0), type1))
					     NULL_TREE, 0);
	  tree index1;
	  tree delta21 = integer_zero_node;
	  tree e1, e2, e3;
	    = build_binary_op (MINUS_EXPR, integer_zero_node, integer_one_node);
	  if (TREE_CODE (TREE_OPERAND (op1, 0)) == FUNCTION_DECL
	      && DECL_VINDEX (TREE_OPERAND (op1, 0)))
	      /* Map everything down one to make room for
		 the null pointer to member.  */
	      index1 = size_binop (PLUS_EXPR,
				   DECL_VINDEX (TREE_OPERAND (op1, 0)),
				   integer_one_node);
	      delta21 = CLASSTYPE_VFIELD (TYPE_METHOD_BASETYPE
					  (TREE_TYPE (type1)));
	      delta21 = DECL_FIELD_BITPOS (delta21);
	      delta21 = size_binop (FLOOR_DIV_EXPR, delta21,
				    size_int (BITS_PER_UNIT));
	      delta21 = convert (sizetype, delta21);
	  else
	    index1 = integer_neg_one_node;
	    tree nop1 = build1 (NOP_EXPR, TYPE_PTRMEMFUNC_FN_TYPE (type0),
				op1);
	    TREE_CONSTANT (nop1) = TREE_CONSTANT (op1);
	    op1 = nop1;
	  e3 = build (EQ_EXPR, boolean_type_node, pfn0, op1);
	    return e2;
	       && same_type_p (TYPE_PTRMEMFUNC_FN_TYPE (type1), type0))
	return build_binary_op (code, op1, op0);
      break;
    case MAX_EXPR:
    case MIN_EXPR:
      if ((code0 == INTEGER_TYPE || code0 == REAL_TYPE)
	   && (code1 == INTEGER_TYPE || code1 == REAL_TYPE))
	shorten = 1;
	  else
			  type0, type1);
      break;
    case LE_EXPR:
    case GE_EXPR:
    case LT_EXPR:
    case GT_EXPR:
	short_compare = 1;
	  else
			  type0, type1);
	  pedwarn ("ANSI C++ forbids comparison between pointer and integer");
      break;
    default:
      break;
  if ((code0 == INTEGER_TYPE || code0 == REAL_TYPE || code0 == COMPLEX_TYPE)
      (code1 == INTEGER_TYPE || code1 == REAL_TYPE || code1 == COMPLEX_TYPE))
      int none_complex = (code0 != COMPLEX_TYPE && code1 != COMPLEX_TYPE);
      if (shorten || common || short_compare)
      /* For certain operations (which identify themselves by shorten != 0)
	 if both args were extended from the same smaller type,
	 do the arithmetic in that type and then extend.
	 shorten !=0 and !=1 indicates a bitwise operation.
	 For them, this optimization is safe only if
	 both args are zero-extended or both are sign-extended.
	 Otherwise, we might change the result.
	 Eg, (short)-1 | (unsigned short)-1 is (int)-1
	 but calculated in (unsigned short) it would be (unsigned short)-1.  */
      if (shorten && none_complex)
	  int unsigned0, unsigned1;
	  tree arg0 = get_narrower (op0, &unsigned0);
	  tree arg1 = get_narrower (op1, &unsigned1);
	  /* UNS is 1 if the operation to be done is an unsigned one.  */
	  int uns = TREE_UNSIGNED (result_type);
	  tree type;
	  /* Handle the case that OP0 does not *contain* a conversion
	     but it *requires* conversion to FINAL_TYPE.  */
	  if (op0 == arg0 && TREE_TYPE (op0) != final_type)
	    unsigned0 = TREE_UNSIGNED (TREE_TYPE (op0));
	  if (op1 == arg1 && TREE_TYPE (op1) != final_type)
	    unsigned1 = TREE_UNSIGNED (TREE_TYPE (op1));
	  /* Now UNSIGNED0 is 1 if ARG0 zero-extends to FINAL_TYPE.  */
	  /* For bitwise operations, signedness of nominal type
	     does not matter.  Consider only how operands were extended.  */
	  if (shorten == -1)
	    uns = unsigned0;
	  /* Note that in all three cases below we refrain from optimizing
	     an unsigned operation on sign-extended args.
	     That would not be valid.  */
	  /* Both args variable: if both extended in same way
	     from same width, do it in that width.
	     Do it unsigned if args were zero-extended.  */
	  if ((TYPE_PRECISION (TREE_TYPE (arg0))
	       < TYPE_PRECISION (result_type))
	      && (TYPE_PRECISION (TREE_TYPE (arg1))
		  == TYPE_PRECISION (TREE_TYPE (arg0)))
	      && unsigned0 == unsigned1
	      && (unsigned0 || !uns))
	    result_type
	      = signed_or_unsigned_type (unsigned0,
					 common_type (TREE_TYPE (arg0),
						      TREE_TYPE (arg1)));
	  else if (TREE_CODE (arg0) == INTEGER_CST
		   && (unsigned1 || !uns)
		   && (type = signed_or_unsigned_type (unsigned1,
						       TREE_TYPE (arg1)),
		       int_fits_type_p (arg0, type)))
	    result_type = type;
	  else if (TREE_CODE (arg1) == INTEGER_CST
		   && (TYPE_PRECISION (TREE_TYPE (arg0))
		   && (type = signed_or_unsigned_type (unsigned0,
						       TREE_TYPE (arg0)),
		       int_fits_type_p (arg1, type)))
	    result_type = type;
      /* Shifts can be shortened if shifting right.  */
      if (short_shift)
	  int unsigned_arg;
	  tree arg0 = get_narrower (op0, &unsigned_arg);
	  if (arg0 == op0 && final_type == TREE_TYPE (op0))
	    unsigned_arg = TREE_UNSIGNED (TREE_TYPE (op0));
	  if (TYPE_PRECISION (TREE_TYPE (arg0)) < TYPE_PRECISION (result_type)
	      /* We can shorten only if the shift count is less than the
		 number of bits in the smaller type size.  */
	      && TREE_INT_CST_HIGH (op1) == 0
	      && TYPE_PRECISION (TREE_TYPE (arg0)) > TREE_INT_CST_LOW (op1)
	      /* If arg is sign-extended and then unsigned-shifted,
		 we can simulate this with a signed shift in arg's type
		 only if the extended result is at least twice as wide
		 as the arg.  Otherwise, the shift could use up all the
		 ones made by sign-extension and bring in zeros.
		 We can't optimize that case at all, but in most machines
		 it never happens because available widths are 2**N.  */
	      && (!TREE_UNSIGNED (final_type)
		  || unsigned_arg
		  || (((unsigned) 2 * TYPE_PRECISION (TREE_TYPE (arg0)))
		      <= TYPE_PRECISION (result_type))))
	      /* Do an unsigned shift if the operand was zero-extended.  */
	      result_type
		= signed_or_unsigned_type (unsigned_arg,
					   TREE_TYPE (arg0));
	      /* Convert value-to-be-shifted to that type.  */
	      if (TREE_TYPE (op0) != result_type)
		op0 = cp_convert (result_type, op0);
	      converted = 1;
      /* Comparison operations are shortened too but differently.
	 They identify themselves by setting short_compare = 1.  */
      if (short_compare)
	  /* Don't write &op0, etc., because that would prevent op0
	     from being kept in a register.
	     Instead, make copies of the our local variables and
	     pass the copies by reference, then copy them back afterward.  */
	  tree xop0 = op0, xop1 = op1, xresult_type = result_type;
	  enum tree_code xresultcode = resultcode;
	  tree val
	    = shorten_compare (&xop0, &xop1, &xresult_type, &xresultcode);
	  if (val != 0)
	    return cp_convert (boolean_type_node, val);
	  op0 = xop0, op1 = xop1;
	  converted = 1;
	  resultcode = xresultcode;
      if (short_compare && warn_sign_compare)
	  int op0_signed = ! TREE_UNSIGNED (TREE_TYPE (orig_op0));
	  int op1_signed = ! TREE_UNSIGNED (TREE_TYPE (orig_op1));
	  int unsignedp0, unsignedp1;
	  tree primop0 = get_narrower (op0, &unsignedp0);
	  tree primop1 = get_narrower (op1, &unsignedp1);
	  /* Check for comparison of different enum types.  */
	  if (TREE_CODE (TREE_TYPE (orig_op0)) == ENUMERAL_TYPE
	      && TREE_CODE (TREE_TYPE (orig_op1)) == ENUMERAL_TYPE
	      && TYPE_MAIN_VARIANT (TREE_TYPE (orig_op0))
	         != TYPE_MAIN_VARIANT (TREE_TYPE (orig_op1)))
	      cp_warning ("comparison between `%#T' and `%#T'",
			  TREE_TYPE (orig_op0), TREE_TYPE (orig_op1));
	  /* Give warnings for comparisons between signed and unsigned
	     quantities that may fail.  */
	  /* Do the checking based on the original operand trees, so that
	     casts will be considered, but default promotions won't be.  */
	  /* Do not warn if the comparison is being done in a signed type,
	     since the signed type will only be chosen if it can represent
	     all the values of the unsigned type.  */
	  if (! TREE_UNSIGNED (result_type))
	    /* OK */;
	  /* Do not warn if both operands are unsigned.  */
	  else if (op0_signed == op1_signed)
	    /* OK */;
	  /* Do not warn if the signed quantity is an unsuffixed
	     integer literal (or some static constant expression
	     involving such literals) and it is non-negative.  */
	  else if ((op0_signed && TREE_CODE (orig_op0) == INTEGER_CST
		    && tree_int_cst_sgn (orig_op0) >= 0)
		   || (op1_signed && TREE_CODE (orig_op1) == INTEGER_CST
		       && tree_int_cst_sgn (orig_op1) >= 0))
	    /* OK */;
	  /* Do not warn if the comparison is an equality operation,
	     the unsigned quantity is an integral constant and it does
	     not use the most significant bit of result_type.  */
	  else if ((resultcode == EQ_EXPR || resultcode == NE_EXPR)
		   && ((op0_signed && TREE_CODE (orig_op1) == INTEGER_CST
			&& int_fits_type_p (orig_op1,
					    signed_type (result_type)))
			|| (op1_signed && TREE_CODE (orig_op0) == INTEGER_CST
			    && int_fits_type_p (orig_op0,
						signed_type (result_type)))))
	    /* OK */;
	  else
	    warning ("comparison between signed and unsigned");
	  /* Warn if two unsigned values are being compared in a size
	     larger than their original size, and one (and only one) is the
	     result of a `~' operator.  This comparison will always fail.
	     Also warn if one operand is a constant, and the constant does not
	     have all bits set that are set in the ~ operand when it is
	     extended.  */
	  if ((TREE_CODE (primop0) == BIT_NOT_EXPR)
	      ^ (TREE_CODE (primop1) == BIT_NOT_EXPR))
	      if (TREE_CODE (primop0) == BIT_NOT_EXPR)
		primop0 = get_narrower (TREE_OPERAND (op0, 0), &unsignedp0);
	      if (TREE_CODE (primop1) == BIT_NOT_EXPR)
		primop1 = get_narrower (TREE_OPERAND (op1, 0), &unsignedp1);
	      if (TREE_CODE (primop0) == INTEGER_CST
		  || TREE_CODE (primop1) == INTEGER_CST)
		  tree primop;
		  HOST_WIDE_INT constant, mask;
		  int unsignedp;
		  unsigned bits;
		  if (TREE_CODE (primop0) == INTEGER_CST)
		      primop = primop1;
		      unsignedp = unsignedp1;
		      constant = TREE_INT_CST_LOW (primop0);
		  else
		      primop = primop0;
		      unsignedp = unsignedp0;
		      constant = TREE_INT_CST_LOW (primop1);
		  bits = TYPE_PRECISION (TREE_TYPE (primop));
		  if (bits < TYPE_PRECISION (result_type)
		      && bits < HOST_BITS_PER_LONG && unsignedp)
		      mask = (~ (HOST_WIDE_INT) 0) << bits;
		      if ((mask & constant) != mask)
			warning ("comparison of promoted ~unsigned with constant");
	      else if (unsignedp0 && unsignedp1
		       && (TYPE_PRECISION (TREE_TYPE (primop0))
		       && (TYPE_PRECISION (TREE_TYPE (primop1))
			   < TYPE_PRECISION (result_type)))
		warning ("comparison of promoted ~unsigned with unsigned");
  /* At this point, RESULT_TYPE must be nonzero to avoid an error message.
     If CONVERTED is zero, both args will be converted to type RESULT_TYPE.
     Then the expression will be built.
     It will be given type FINAL_TYPE if that is nonzero;
     otherwise, it will be given type RESULT_TYPE.  */
  if (!result_type)
      cp_error ("invalid operands `%T' and `%T' to binary `%O'",
		TREE_TYPE (orig_op0), TREE_TYPE (orig_op1), error_code);
  /* Issue warnings about peculiar, but legal, uses of NULL.  */
  if (/* It's reasonable to use pointer values as operands of &&
	 and ||, so NULL is no exception.  */
      !(code == TRUTH_ANDIF_EXPR || code == TRUTH_ORIF_EXPR)
      && (/* If OP0 is NULL and OP1 is not a pointer, or vice versa.  */
	  (orig_op0 == null_node
	   && TREE_CODE (TREE_TYPE (op1)) != POINTER_TYPE)
	  /* Or vice versa.  */
	  || (orig_op1 == null_node
	      && TREE_CODE (TREE_TYPE (op0)) != POINTER_TYPE)
	  /* Or, both are NULL and the operation was not a comparison.  */
	  || (orig_op0 == null_node && orig_op1 == null_node
	      && code != EQ_EXPR && code != NE_EXPR)))
    /* Some sort of arithmetic operation involving NULL was
       performed.  Note that pointer-difference and pointer-addition
       have already been handled above, and so we don't end up here in
       that case.  */
    cp_warning ("NULL used in arithmetic");
  if (! converted)
      if (TREE_TYPE (op1) != result_type)
	op1 = cp_convert (result_type, op1);
      if (op0 == error_mark_node || op1 == error_mark_node)
  if (build_type == NULL_TREE)
    build_type = result_type;
    register tree result = build (resultcode, build_type, op0, op1);
    register tree folded;
    folded = fold (result);
    if (folded == result)
      TREE_CONSTANT (folded) = TREE_CONSTANT (op0) & TREE_CONSTANT (op1);
    if (final_type != 0)
      return cp_convert (final_type, folded);
    return folded;
/* Return a tree for the sum or difference (RESULTCODE says which)
   of pointer PTROP and integer INTOP.  */
static tree
pointer_int_sum (resultcode, ptrop, intop)
     enum tree_code resultcode;
     register tree ptrop, intop;
  tree size_exp;
  register tree result;
  register tree folded = fold (intop);
  /* The result is a pointer of the same type that is being added.  */
  register tree result_type = TREE_TYPE (ptrop);
  if (!complete_type_or_else (result_type, ptrop))
  if (TREE_CODE (TREE_TYPE (result_type)) == VOID_TYPE)
      if (pedantic || warn_pointer_arith)
	pedwarn ("ANSI C++ forbids using pointer of type `void *' in arithmetic");
      size_exp = integer_one_node;
  else if (TREE_CODE (TREE_TYPE (result_type)) == FUNCTION_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a function in arithmetic");
  else if (TREE_CODE (TREE_TYPE (result_type)) == METHOD_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a method in arithmetic");
  else if (TREE_CODE (TREE_TYPE (result_type)) == OFFSET_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a member in arithmetic");
  else
    size_exp = size_in_bytes (complete_type (TREE_TYPE (result_type)));
  /* Needed to make OOPS V2R3 work.  */
  intop = folded;
  if (TREE_CODE (intop) == INTEGER_CST
      && TREE_INT_CST_LOW (intop) == 0
      && TREE_INT_CST_HIGH (intop) == 0)
    return ptrop;
  /* If what we are about to multiply by the size of the elements
     contains a constant term, apply distributive law
     and multiply that constant term separately.
     This helps produce common subexpressions.  */
  if ((TREE_CODE (intop) == PLUS_EXPR || TREE_CODE (intop) == MINUS_EXPR)
      && ! TREE_CONSTANT (intop)
      && TREE_CONSTANT (TREE_OPERAND (intop, 1))
      && TREE_CONSTANT (size_exp))
      enum tree_code subcode = resultcode;
      if (TREE_CODE (intop) == MINUS_EXPR)
	subcode = (subcode == PLUS_EXPR ? MINUS_EXPR : PLUS_EXPR);
      ptrop = build_binary_op (subcode, ptrop, TREE_OPERAND (intop, 1));
      intop = TREE_OPERAND (intop, 0);
  /* Convert the integer argument to a type the same size as sizetype
     so the multiply won't overflow spuriously.  */
  if (TYPE_PRECISION (TREE_TYPE (intop)) != TYPE_PRECISION (sizetype))
    intop = cp_convert (type_for_size (TYPE_PRECISION (sizetype), 0), intop);
  /* Replace the integer argument with a suitable product by the object size.
     Do this multiplication as signed, then convert to the appropriate
     pointer type (actually unsigned integral).  */
  intop = cp_convert (result_type,
		      build_binary_op (MULT_EXPR, intop,
				       cp_convert (TREE_TYPE (intop),
						   size_exp)));
  /* Create the sum or difference.  */
  result = build (resultcode, result_type, ptrop, intop);
    TREE_CONSTANT (folded) = TREE_CONSTANT (ptrop) & TREE_CONSTANT (intop);
  return folded;
/* Return a tree for the difference of pointers OP0 and OP1.
   The resulting tree has type int.  */
static tree
pointer_diff (op0, op1, ptrtype)
     register tree op0, op1;
     register tree ptrtype;
  register tree result, folded;
  tree restype = ptrdiff_type_node;
  tree target_type = TREE_TYPE (ptrtype);
  if (!complete_type_or_else (target_type, NULL_TREE))
      if (TREE_CODE (target_type) == VOID_TYPE)
	pedwarn ("ANSI C++ forbids using pointer of type `void *' in subtraction");
      if (TREE_CODE (target_type) == FUNCTION_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a function in subtraction");
      if (TREE_CODE (target_type) == METHOD_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a method in subtraction");
      if (TREE_CODE (target_type) == OFFSET_TYPE)
	pedwarn ("ANSI C++ forbids using pointer to a member in subtraction");
  /* First do the subtraction as integers;
     then drop through to build the divide operator.  */
  op0 = build_binary_op (MINUS_EXPR, cp_convert (restype, op0),
			 cp_convert (restype, op1));
  /* This generates an error if op1 is a pointer to an incomplete type.  */
  if (TYPE_SIZE (TREE_TYPE (TREE_TYPE (op1))) == 0)
    error ("arithmetic on pointer to an incomplete type");
  op1 = ((TREE_CODE (target_type) == VOID_TYPE
	 ? integer_one_node
	 : size_in_bytes (target_type));
  /* Do the division.  */
  result = build (EXACT_DIV_EXPR, restype, op0, cp_convert (restype, op1));
  return folded;
/* Handle the case of taking the address of a COMPONENT_REF.
   Called by `build_unary_op'.
   ARG is the COMPONENT_REF whose address we want.
   ARGTYPE is the pointer type that this address should have. */
static tree
build_component_addr (arg, argtype)
     tree arg, argtype;
  tree field = TREE_OPERAND (arg, 1);
  tree basetype = decl_type_context (field);
  tree rval = build_unary_op (ADDR_EXPR, TREE_OPERAND (arg, 0), 0);
  my_friendly_assert (TREE_CODE (field) == FIELD_DECL, 981018);
  if (DECL_C_BIT_FIELD (field))
      cp_error ("attempt to take address of bit-field structure member `%D'",
                field);
  if (TREE_CODE (field) == FIELD_DECL
      /* Can't convert directly to ARGTYPE, since that
	 may have the same pointer type as one of our
	 baseclasses.  */
      rval = build1 (NOP_EXPR, argtype,
		     convert_pointer_to (basetype, rval));
      TREE_CONSTANT (rval) = TREE_CONSTANT (TREE_OPERAND (rval, 0));
  else
    /* This conversion is harmless.  */
    rval = convert_force (argtype, rval, 0);
  if (! integer_zerop (DECL_FIELD_BITPOS (field)))
      tree offset = size_binop (EASY_DIV_EXPR, DECL_FIELD_BITPOS (field),
      int flag = TREE_CONSTANT (rval);
      offset = convert (sizetype, offset);
      rval = fold (build (PLUS_EXPR, argtype,
			  rval, cp_convert (argtype, offset)));
      TREE_CONSTANT (rval) = flag;
  return rval;
/* Construct and perhaps optimize a tree representation
   for a unary operation.  CODE, a tree_code, specifies the operation
   and XARG is the operand.  */
tree
build_x_unary_op (code, xarg)
     enum tree_code code;
     tree xarg;
  if (processing_template_decl)
    return build_min_nt (code, xarg, NULL_TREE);
  /* & rec, on incomplete RECORD_TYPEs is the simple opr &, not an
     error message.  */
  if (code == ADDR_EXPR
      && TREE_CODE (xarg) != TEMPLATE_ID_EXPR
      && ((IS_AGGR_TYPE_CODE (TREE_CODE (TREE_TYPE (xarg)))
	   && TYPE_SIZE (TREE_TYPE (xarg)) == NULL_TREE)
	  || (TREE_CODE (xarg) == OFFSET_REF)))
    /* don't look for a function */;
  else
      tree rval;
      rval = build_new_op (code, LOOKUP_NORMAL, xarg,
			   NULL_TREE, NULL_TREE);
      if (rval || code != ADDR_EXPR)
	return rval;
  if (code == ADDR_EXPR)
      if (TREE_CODE (xarg) == TARGET_EXPR)
	warning ("taking address of temporary");
  return build_unary_op (code, xarg, 0);
/* Just like truthvalue_conversion, but we want a CLEANUP_POINT_EXPR.  */
tree
condition_conversion (expr)
     tree expr;
  tree t;
    return expr;
  t = cp_convert (boolean_type_node, expr);
  t = fold (build1 (CLEANUP_POINT_EXPR, boolean_type_node, t));
  return t;
/* C++: Must handle pointers to members.
   Perhaps type instantiation should be extended to handle conversion
   from aggregates to types we don't yet know we want?  (Or are those
   cases typically errors which should be reported?)
   NOCONVERT nonzero suppresses the default promotions
   (such as from short to int).  */
tree
build_unary_op (code, xarg, noconvert)
     tree xarg;
     int noconvert;
  /* No default_conversion here.  It causes trouble for ADDR_EXPR.  */
  register tree arg = xarg;
  register tree argtype = 0;
  const char *errstring = NULL;
  tree val;
  if (arg == error_mark_node)
  switch (code)
    case CONVERT_EXPR:
      /* This is used for unary plus, because a CONVERT_EXPR
	 is enough to prevent anybody from looking inside for
	 associativity, but won't generate any code.  */
      if (!(arg = build_expr_type_conversion
	    (WANT_ARITH | WANT_ENUM | WANT_POINTER, arg, 1)))
	errstring = "wrong type argument to unary plus";
      else
	  if (!noconvert)
	   arg = default_conversion (arg);
	  arg = build1 (NON_LVALUE_EXPR, TREE_TYPE (arg), arg);
	  TREE_CONSTANT (arg) = TREE_CONSTANT (TREE_OPERAND (arg, 0));
      break;
    case NEGATE_EXPR:
      if (!(arg = build_expr_type_conversion (WANT_ARITH | WANT_ENUM, arg, 1)))
	errstring = "wrong type argument to unary minus";
      else if (!noconvert)
      break;
    case BIT_NOT_EXPR:
      if (TREE_CODE (TREE_TYPE (arg)) == COMPLEX_TYPE)
	  code = CONJ_EXPR;
	  if (!noconvert)
      else if (!(arg = build_expr_type_conversion (WANT_INT | WANT_ENUM,
						   arg, 1)))
	errstring = "wrong type argument to bit-complement";
      break;
    case ABS_EXPR:
	errstring = "wrong type argument to abs";
      break;
    case CONJ_EXPR:
      /* Conjugating a real value is a no-op, but allow it anyway.  */
	errstring = "wrong type argument to conjugation";
      break;
    case TRUTH_NOT_EXPR:
      arg = cp_convert (boolean_type_node, arg);
      val = invert_truthvalue (arg);
      if (arg != error_mark_node)
	return val;
      errstring = "in argument to unary !";
      break;
    case NOP_EXPR:
      break;
    case REALPART_EXPR:
      if (TREE_CODE (arg) == COMPLEX_CST)
	return TREE_REALPART (arg);
      else if (TREE_CODE (TREE_TYPE (arg)) == COMPLEX_TYPE)
	return fold (build1 (REALPART_EXPR, TREE_TYPE (TREE_TYPE (arg)), arg));
      else
	return arg;
    case IMAGPART_EXPR:
	return TREE_IMAGPART (arg);
	return fold (build1 (IMAGPART_EXPR, TREE_TYPE (TREE_TYPE (arg)), arg));
      else
	return cp_convert (TREE_TYPE (arg), integer_zero_node);
    case PREINCREMENT_EXPR:
    case POSTINCREMENT_EXPR:
    case PREDECREMENT_EXPR:
    case POSTDECREMENT_EXPR:
      /* Handle complex lvalues (when permitted)
	 by reduction to simpler cases.  */
      val = unary_complex_lvalue (code, arg);
      if (val != 0)
	return val;
      /* Increment or decrement the real part of the value,
	 and don't change the imaginary part.  */
	  tree real, imag;
	  arg = stabilize_reference (arg);
	  real = build_unary_op (REALPART_EXPR, arg, 1);
	  imag = build_unary_op (IMAGPART_EXPR, arg, 1);
	  return build (COMPLEX_EXPR, TREE_TYPE (arg),
			build_unary_op (code, real, 1), imag);
      /* Report invalid types.  */
      if (!(arg = build_expr_type_conversion (WANT_ARITH | WANT_POINTER,
					      arg, 1)))
	  if (code == PREINCREMENT_EXPR)
	    errstring ="no pre-increment operator for type";
	  else if (code == POSTINCREMENT_EXPR)
	    errstring ="no post-increment operator for type";
	  else if (code == PREDECREMENT_EXPR)
	    errstring ="no pre-decrement operator for type";
	  else
	    errstring ="no post-decrement operator for type";
	  break;
      /* Report something read-only.  */
      if (CP_TYPE_CONST_P (TREE_TYPE (arg))
	  || TREE_READONLY (arg))
	readonly_error (arg, ((code == PREINCREMENT_EXPR
			      ? "increment" : "decrement"),
			0);
	register tree inc;
	tree result_type = TREE_TYPE (arg);
	arg = get_unwidened (arg, 0);
	argtype = TREE_TYPE (arg);
	/* ARM $5.2.5 last annotation says this should be forbidden.  */
	if (TREE_CODE (argtype) == ENUMERAL_TYPE)
	  pedwarn ("ANSI C++ forbids %sing an enum",
		   (code == PREINCREMENT_EXPR || code == POSTINCREMENT_EXPR)
		   ? "increment" : "decrement");
	/* Compute the increment.  */
	if (TREE_CODE (argtype) == POINTER_TYPE)
	    enum tree_code tmp = TREE_CODE (TREE_TYPE (argtype));
	    if (TYPE_SIZE (complete_type (TREE_TYPE (argtype))) == 0)
	      cp_error ("cannot %s a pointer to incomplete type `%T'",
			 ? "increment" : "decrement"), TREE_TYPE (argtype));
	    else if ((pedantic || warn_pointer_arith)
		     && (tmp == FUNCTION_TYPE || tmp == METHOD_TYPE
			 || tmp == VOID_TYPE || tmp == OFFSET_TYPE))
	      cp_pedwarn ("ANSI C++ forbids %sing a pointer of type `%T'",
			   ? "increment" : "decrement"), argtype);
	    inc = c_sizeof_nowarn (TREE_TYPE (argtype));
	else
	  inc = integer_one_node;
	inc = cp_convert (argtype, inc);
	/* Handle incrementing a cast-expression.  */
	switch (TREE_CODE (arg))
	  case NOP_EXPR:
	  case CONVERT_EXPR:
	  case FLOAT_EXPR:
	  case FIX_TRUNC_EXPR:
	  case FIX_FLOOR_EXPR:
	  case FIX_ROUND_EXPR:
	  case FIX_CEIL_EXPR:
	      tree incremented, modify, value, compound;
	      if (! lvalue_p (arg) && pedantic)
		pedwarn ("cast to non-reference type used as lvalue");
	      if (code == PREINCREMENT_EXPR || code == PREDECREMENT_EXPR)
		value = arg;
	      else
		value = save_expr (arg);
	      incremented = build (((code == PREINCREMENT_EXPR
				    ? PLUS_EXPR : MINUS_EXPR),
				   argtype, value, inc);
	      TREE_SIDE_EFFECTS (incremented) = 1;
	      modify = build_modify_expr (arg, NOP_EXPR, incremented);
	      compound = build (COMPOUND_EXPR, TREE_TYPE (arg), modify, value);
	      /* Eliminate warning about unused result of + or -.  */
	      TREE_NO_UNUSED_WARNING (compound) = 1;
	      return compound;
	  default:
	    break;
	/* Complain about anything else that is not a true lvalue.  */
	if (!lvalue_or_else (arg, ((code == PREINCREMENT_EXPR
				   ? "increment" : "decrement")))
	/* Forbid using -- on `bool'.  */
	if (TREE_TYPE (arg) == boolean_type_node)
	    if (code == POSTDECREMENT_EXPR || code == PREDECREMENT_EXPR)
		cp_error ("invalid use of `--' on bool variable `%D'", arg);
#if 0
	    /* This will only work if someone can convince Kenner to accept
	       my patch to expand_increment. (jason)  */
	    val = build (code, TREE_TYPE (arg), arg, inc);
#else
		val = build (MODIFY_EXPR, TREE_TYPE (arg), arg,
			     boolean_true_node);
		TREE_SIDE_EFFECTS (val) = 1;
		arg = save_expr (arg);
		val = build (COMPOUND_EXPR, TREE_TYPE (arg), val, arg);
		val = build (COMPOUND_EXPR, TREE_TYPE (arg), arg, val);
	    else
			   boolean_true_node);
#endif
	else
	return cp_convert (result_type, val);
    case ADDR_EXPR:
      /* Note that this operation never does default_conversion
	 regardless of NOCONVERT.  */
      argtype = lvalue_type (arg);
      if (TREE_CODE (argtype) == REFERENCE_TYPE)
	  arg = build1
	    (CONVERT_EXPR,
	     build_pointer_type (TREE_TYPE (argtype)), arg);
	  return arg;
      else if (pedantic && DECL_MAIN_P (arg))
	/* ARM $3.4 */
	pedwarn ("taking address of function `main'");
      /* Let &* cancel out to simplify resulting code.  */
      if (TREE_CODE (arg) == INDIRECT_REF)
	  /* We don't need to have `current_class_ptr' wrapped in a
	     NON_LVALUE_EXPR node.  */
	  if (arg == current_class_ref)
	    return current_class_ptr;
	  arg = TREE_OPERAND (arg, 0);
	  if (TREE_CODE (TREE_TYPE (arg)) == REFERENCE_TYPE)
	      arg = build1
		(CONVERT_EXPR,
		 build_pointer_type (TREE_TYPE (TREE_TYPE (arg))), arg);
	  else if (lvalue_p (arg))
	    /* Don't let this be an lvalue.  */
	    return non_lvalue (arg);
	  return arg;
      /* For &x[y], return x+y */
      if (TREE_CODE (arg) == ARRAY_REF)
	  if (mark_addressable (TREE_OPERAND (arg, 0)) == 0)
	  return build_binary_op (PLUS_EXPR, TREE_OPERAND (arg, 0),
				  TREE_OPERAND (arg, 1));
      /* Uninstantiated types are all functions.  Taking the
	 address of a function is a no-op, so just return the
	 argument.  */
      if (TREE_CODE (arg) == IDENTIFIER_NODE
	  && IDENTIFIER_OPNAME_P (arg))
	  my_friendly_abort (117);
	  /* We don't know the type yet, so just work around the problem.
	     We know that this will resolve to an lvalue.  */
	  return build1 (ADDR_EXPR, unknown_type_node, arg);
      if (TREE_CODE (arg) == COMPONENT_REF && type_unknown_p (arg)
	  && OVL_NEXT (TREE_OPERAND (arg, 1)) == NULL_TREE)
	  /* They're trying to take the address of a unique non-static
	     member function.  This is ill-formed, but let's try to DTRT.  */
	  tree base, name;
	      && TREE_OPERAND (arg, 0) == current_class_ref)
	    /* An expression like &memfn.  */
	    pedwarn ("taking the address of a non-static member function");
	  else
	    pedwarn ("taking the address of a bound member function");
	  base = TREE_TYPE (TREE_OPERAND (arg, 0));
	  name = DECL_NAME (OVL_CURRENT (TREE_OPERAND (arg, 1)));
	  cp_pedwarn ("  to form a pointer to member function, say `&%T::%D'",
		      base, name);
	  arg = build_offset_ref (base, name);
      if (type_unknown_p (arg))
      if (val != 0)
	return val;
	case NOP_EXPR:
	case CONVERT_EXPR:
	case FLOAT_EXPR:
	case FIX_CEIL_EXPR:
	    pedwarn ("taking the address of a cast to non-reference type");
	  break;
	default:
	  break;
      /* Allow the address of a constructor if all the elements
	 are constant.  */
      if (TREE_CODE (arg) == CONSTRUCTOR && TREE_HAS_CONSTRUCTOR (arg)
	  && TREE_CONSTANT (arg))
      /* Anything not already handled and not a true memory reference
	 is an error.  */
      else if (TREE_CODE (argtype) != FUNCTION_TYPE
	       && TREE_CODE (argtype) != METHOD_TYPE
	       && !lvalue_or_else (arg, "unary `&'"))
      if (argtype != error_mark_node)
	argtype = build_pointer_type (argtype);
      if (mark_addressable (arg) == 0)
	tree addr;
	if (TREE_CODE (arg) == COMPONENT_REF)
	  addr = build_component_addr (arg, argtype);
	else
	  addr = build1 (ADDR_EXPR, argtype, arg);
	/* Address of a static or external variable or
	   function counts as a constant */
	if (staticp (arg))
	  TREE_CONSTANT (addr) = 1;
	    && TREE_CODE (TREE_TYPE (argtype)) == METHOD_TYPE)
	    build_ptrmemfunc_type (argtype);
	    addr = build_ptrmemfunc (argtype, addr, 0);
	return addr;
    default:
      break;
  if (!errstring)
      if (argtype == 0)
      return fold (build1 (code, argtype, arg));
  error (errstring);
#if 0
/* If CONVERSIONS is a conversion expression or a nested sequence of such,
   convert ARG with the same conversions in the same order
   and return the result.  */
static tree
convert_sequence (conversions, arg)
     tree conversions;
     tree arg;
  switch (TREE_CODE (conversions))
    case NOP_EXPR:
    case CONVERT_EXPR:
    case FLOAT_EXPR:
    case FIX_CEIL_EXPR:
      return cp_convert (TREE_TYPE (conversions),
			 convert_sequence (TREE_OPERAND (conversions, 0),
					   arg));
    default:
      return arg;
#endif
/* Apply unary lvalue-demanding operator CODE to the expression ARG
   for certain kinds of expressions which are not really lvalues
   but which we can accept as lvalues.
   If ARG is not a kind of expression we can handle, return zero.  */
tree
     tree arg;
  /* Handle (a, b) used as an "lvalue".  */
  if (TREE_CODE (arg) == COMPOUND_EXPR)
      tree real_result = build_unary_op (code, TREE_OPERAND (arg, 1), 0);
      return build (COMPOUND_EXPR, TREE_TYPE (real_result),
		    TREE_OPERAND (arg, 0), real_result);
  /* Handle (a ? b : c) used as an "lvalue".  */
  if (TREE_CODE (arg) == COND_EXPR
      || TREE_CODE (arg) == MIN_EXPR || TREE_CODE (arg) == MAX_EXPR)
    return rationalize_conditional_expr (code, arg);
  if (TREE_CODE (arg) == MODIFY_EXPR
      || TREE_CODE (arg) == PREINCREMENT_EXPR
      || TREE_CODE (arg) == PREDECREMENT_EXPR)
    return unary_complex_lvalue
      (code, build (COMPOUND_EXPR, TREE_TYPE (TREE_OPERAND (arg, 0)),
		    arg, TREE_OPERAND (arg, 0)));
  if (code != ADDR_EXPR)
    return 0;
  /* Handle (a = b) used as an "lvalue" for `&'.  */
      || TREE_CODE (arg) == INIT_EXPR)
      tree real_result = build_unary_op (code, TREE_OPERAND (arg, 0), 0);
      arg = build (COMPOUND_EXPR, TREE_TYPE (real_result), arg, real_result);
      TREE_NO_UNUSED_WARNING (arg) = 1;
      return arg;
  if (TREE_CODE (TREE_TYPE (arg)) == FUNCTION_TYPE
      || TREE_CODE (TREE_TYPE (arg)) == METHOD_TYPE
      || TREE_CODE (TREE_TYPE (arg)) == OFFSET_TYPE)
      /* The representation of something of type OFFSET_TYPE
	 is really the representation of a pointer to it.
	 Here give the representation its true type.  */
      tree t;
      my_friendly_assert (TREE_CODE (arg) != SCOPE_REF, 313);
      if (TREE_CODE (arg) != OFFSET_REF)
	return 0;
      t = TREE_OPERAND (arg, 1);
      /* Check all this code for right semantics.  */
      if (TREE_CODE (t) == FUNCTION_DECL)
	  if (DECL_DESTRUCTOR_P (t))
	    cp_error ("taking address of destructor");
	  return build_unary_op (ADDR_EXPR, t, 0);
      if (TREE_CODE (t) == VAR_DECL)
      else
	  tree type;
	  if (TREE_OPERAND (arg, 0)
	      && ! is_dummy_object (TREE_OPERAND (arg, 0))
	      && TREE_CODE (t) != FIELD_DECL)
	      cp_error ("taking address of bound pointer-to-member expression");
	  type = build_offset_type (DECL_FIELD_CONTEXT (t), TREE_TYPE (t));
	  type = build_pointer_type (type);
	  t = make_ptrmem_cst (type, TREE_OPERAND (arg, 1));
	  return t;
  /* We permit compiler to make function calls returning
     objects of aggregate type look like lvalues.  */
    tree targ = arg;
    if (TREE_CODE (targ) == SAVE_EXPR)
      targ = TREE_OPERAND (targ, 0);
    if (TREE_CODE (targ) == CALL_EXPR && IS_AGGR_TYPE (TREE_TYPE (targ)))
	if (TREE_CODE (arg) == SAVE_EXPR)
	  targ = arg;
	else
	  targ = build_cplus_new (TREE_TYPE (arg), arg);
	return build1 (ADDR_EXPR, build_pointer_type (TREE_TYPE (arg)), targ);
    if (TREE_CODE (arg) == SAVE_EXPR && TREE_CODE (targ) == INDIRECT_REF)
      return build (SAVE_EXPR, build_pointer_type (TREE_TYPE (arg)),
		     TREE_OPERAND (targ, 0), current_function_decl, NULL);
  /* Don't let anything else be handled specially.  */
  return 0;
/* Mark EXP saying that we need to be able to take the
   address of it; it should not be allocated in a register.
   Value is 1 if successful.
   C++: we do not allow `current_class_ptr' to be addressable.  */
int
mark_addressable (exp)
     tree exp;
  register tree x = exp;
  if (TREE_ADDRESSABLE (x) == 1)
    return 1;
  while (1)
    switch (TREE_CODE (x))
      case ADDR_EXPR:
      case COMPONENT_REF:
      case ARRAY_REF:
      case REALPART_EXPR:
      case IMAGPART_EXPR:
	x = TREE_OPERAND (x, 0);
	break;
      case PARM_DECL:
	if (x == current_class_ptr)
	    if (! flag_this_is_variable)
	      error ("address of `this' not available");
	    TREE_ADDRESSABLE (x) = 1; /* so compiler doesn't die later */
	    put_var_into_stack (x);
	    return 1;
      case VAR_DECL:
	if (TREE_STATIC (x) && TREE_READONLY (x)
	    && DECL_RTL (x) != 0
	    && ! DECL_IN_MEMORY_P (x))
	    /* We thought this would make a good constant variable,
	       but we were wrong.  */
	    push_obstacks_nochange ();
	    end_temporary_allocation ();
	    TREE_ASM_WRITTEN (x) = 0;
	    DECL_RTL (x) = 0;
	    rest_of_decl_compilation (x, 0,
				      !DECL_FUNCTION_SCOPE_P (x),
				      0);
	    pop_obstacks ();
	    return 1;
	/* Caller should not be trying to mark initialized
	   constant fields addressable.  */
	my_friendly_assert (DECL_LANG_SPECIFIC (x) == 0
			    || DECL_IN_AGGR_P (x) == 0
			    || TREE_STATIC (x)
			    || DECL_EXTERNAL (x), 314);
      case CONST_DECL:
      case RESULT_DECL:
	if (DECL_REGISTER (x) && !TREE_ADDRESSABLE (x)
	    && !DECL_ARTIFICIAL (x) && extra_warnings)
	  cp_warning ("address requested for `%D', which is declared `register'",
		      x);
	return 1;
      case FUNCTION_DECL:
	if (DECL_LANG_SPECIFIC (x) != 0)
	    x = DECL_MAIN_VARIANT (x);
	    /* We have to test both conditions here.  The first may be
	       non-zero in the case of processing a default function.  The
	       second may be non-zero in the case of a template function.  */
	    if (DECL_TEMPLATE_INFO (x) && !DECL_TEMPLATE_SPECIALIZATION (x))
	      mark_used (x);
	TREE_USED (x) = 1;
	TREE_ADDRESSABLE (DECL_ASSEMBLER_NAME (x)) = 1;
	return 1;
      case CONSTRUCTOR:
	return 1;
      case TARGET_EXPR:
	mark_addressable (TREE_OPERAND (x, 0));
	return 1;
      default:
	return 1;
/* Build and return a conditional expression IFEXP ? OP1 : OP2.  */
tree
build_x_conditional_expr (ifexp, op1, op2)
     tree ifexp, op1, op2;
    return build_min_nt (COND_EXPR, ifexp, op1, op2);
  return build_new_op (COND_EXPR, LOOKUP_NORMAL, ifexp, op1, op2);
tree
build_conditional_expr (ifexp, op1, op2)
  register tree type1;
  register tree type2;
  register enum tree_code code1;
  register enum tree_code code2;
  register tree result_type = NULL_TREE;
  /* If second operand is omitted, it is the same as the first one;
     make sure it is calculated only once.  */
  if (op1 == 0)
      if (pedantic)
	pedwarn ("ANSI C++ forbids omitting the middle term of a ?: expression");
      ifexp = op1 = save_expr (ifexp);
  type2 = TREE_TYPE (op2);
  code2 = TREE_CODE (type2);
  if (op1 == error_mark_node || op2 == error_mark_node
      || type1 == error_mark_node || type2 == error_mark_node)
  ifexp = cp_convert (boolean_type_node, ifexp);
  if (TREE_CODE (ifexp) == ERROR_MARK)
  /* C++: REFERENCE_TYPES must be dereferenced.  */
  if (code1 == REFERENCE_TYPE)
      op1 = convert_from_reference (op1);
  if (code2 == REFERENCE_TYPE)
      op2 = convert_from_reference (op2);
  /* Don't promote the operands separately if they promote
     the same way.  Return the unpromoted type and let the combined
     value get promoted if necessary.  */
  if (TYPE_MAIN_VARIANT (type1) == TYPE_MAIN_VARIANT (type2)
      && code2 != ARRAY_TYPE
      && code2 != FUNCTION_TYPE
      && code2 != METHOD_TYPE)
      tree result;
      if (TREE_CONSTANT (ifexp)
	  && (TREE_CODE (ifexp) == INTEGER_CST
	      || TREE_CODE (ifexp) == ADDR_EXPR))
	return (integer_zerop (ifexp) ? op2 : op1);
      if (TREE_CODE (op1) == CONST_DECL)
	op1 = DECL_INITIAL (op1);
      else if (TREE_READONLY_DECL_P (op1))
	op1 = decl_constant_value (op1);
      if (TREE_CODE (op2) == CONST_DECL)
	op2 = DECL_INITIAL (op2);
      else if (TREE_READONLY_DECL_P (op2))
	op2 = decl_constant_value (op2);
      if (type1 != type2)
	type1 = cp_build_qualified_type
	  (type1, (CP_TYPE_QUALS (TREE_TYPE (op1))
		   | CP_TYPE_QUALS (TREE_TYPE (op2))));
      /* ??? This is a kludge to deal with the fact that
	 we don't sort out integers and enums properly, yet.  */
      result = fold (build (COND_EXPR, type1, ifexp, op1, op2));
      if (TREE_TYPE (result) != type1)
	result = build1 (NOP_EXPR, type1, result);
      /* Expand both sides into the same slot,
	 hopefully the target of the ?: expression.  */
      if (TREE_CODE (op1) == TARGET_EXPR && TREE_CODE (op2) == TARGET_EXPR)
	  tree slot = build (VAR_DECL, TREE_TYPE (result));
	  layout_decl (slot, 0);
	  result = build (TARGET_EXPR, TREE_TYPE (result),
			  slot, result, NULL_TREE, NULL_TREE);
      return result;
  /* They don't match; promote them both and then try to reconcile them.
     But don't permit mismatching enum types.  */
  if (code1 == ENUMERAL_TYPE)
      if (code2 == ENUMERAL_TYPE)
	  cp_error ("enumeral mismatch in conditional expression: `%T' vs `%T'",
		    type1, type2);
      else if (extra_warnings && ! IS_AGGR_TYPE_CODE (code2)
	       && type2 != type_promotes_to (type1))
	warning ("enumeral and non-enumeral type in conditional expression");
	   && code2 == ENUMERAL_TYPE && ! IS_AGGR_TYPE_CODE (code1)
	   && type1 != type_promotes_to (type2))
  if (code1 != VOID_TYPE)
      op1 = default_conversion (op1);
      if (TYPE_PTRMEMFUNC_P (type1))
	type1 = TYPE_PTRMEMFUNC_FN_TYPE (type1);
  if (code2 != VOID_TYPE)
      op2 = default_conversion (op2);
      if (TYPE_PTRMEMFUNC_P (type2))
	type2 = TYPE_PTRMEMFUNC_FN_TYPE (type2);
  if (code1 == RECORD_TYPE && code2 == RECORD_TYPE
      && real_lvalue_p (op1) && real_lvalue_p (op2)
      && comptypes (type1, type2, COMPARE_BASE | COMPARE_RELAXED))
      type1 = build_reference_type (type1);
      type2 = build_reference_type (type2);
      result_type = common_type (type1, type2);
      op1 = convert_to_reference (result_type, op1, CONV_IMPLICIT,
				  LOOKUP_NORMAL, NULL_TREE);
      op2 = convert_to_reference (result_type, op2, CONV_IMPLICIT,
  /* Quickly detect the usual case where op1 and op2 have the same type
     after promotion.  */
  else if (TYPE_MAIN_VARIANT (type1) == TYPE_MAIN_VARIANT (type2))
      if (type1 == type2)
      else
	result_type =
	  cp_build_qualified_type (type1,
				   | CP_TYPE_QUALS (TREE_TYPE (op2)));
  else if ((code1 == INTEGER_TYPE || code1 == REAL_TYPE)
           && (code2 == INTEGER_TYPE || code2 == REAL_TYPE))
  else if (code1 == VOID_TYPE || code2 == VOID_TYPE)
      if (pedantic && (code1 != VOID_TYPE || code2 != VOID_TYPE))
	pedwarn ("ANSI C++ forbids conditional expr with only one void side");
      result_type = void_type_node;
  else if (code1 == POINTER_TYPE && null_ptr_cst_p (op2))
    result_type = qualify_type (type1, type2);
  else if (code2 == POINTER_TYPE && null_ptr_cst_p (op1))
    result_type = qualify_type (type2, type1);
  else if (code1 == POINTER_TYPE && code2 == POINTER_TYPE)
      if (comp_target_types (type1, type2, 1))
      else if (TYPE_MAIN_VARIANT (TREE_TYPE (type1)) == void_type_node)
	  if (pedantic && TREE_CODE (type2) == FUNCTION_TYPE)
	    pedwarn ("ANSI C++ forbids conditional expr between `void *' and function pointer");
      else if (TYPE_MAIN_VARIANT (TREE_TYPE (type2)) == void_type_node)
	  if (pedantic && TREE_CODE (type1) == FUNCTION_TYPE)
      /* C++ */
      else if (same_or_base_type_p (type2, type1))
	result_type = type2;
      else if (IS_AGGR_TYPE (TREE_TYPE (type1))
	       && IS_AGGR_TYPE (TREE_TYPE (type2))
	       && (result_type = common_base_type (TREE_TYPE (type1),
						   TREE_TYPE (type2))))
	  if (result_type == error_mark_node)
	      cp_error ("common base type of types `%T' and `%T' is ambiguous",
			TREE_TYPE (type1), TREE_TYPE (type2));
	  else
	      if (pedantic
		  && result_type != TREE_TYPE (type1)
		  && result_type != TREE_TYPE (type2))
		cp_pedwarn ("`%T' and `%T' converted to `%T *' in conditional expression",
			    type1, type2, result_type);
	      result_type = build_pointer_type (result_type);
      else
	  pedwarn ("pointer type mismatch in conditional expression");
  else if (code1 == POINTER_TYPE && code2 == INTEGER_TYPE)
      pedwarn ("pointer/integer type mismatch in conditional expression");
  else if (code2 == POINTER_TYPE && code1 == INTEGER_TYPE)
  if (type2 == unknown_type_node)
  else if (type1 == unknown_type_node)
  if (!result_type)
      /* The match does not look good.  If either is
	 an aggregate value, try converting to a scalar type.  */
      if (code1 == RECORD_TYPE && code2 == RECORD_TYPE)
	  cp_error ("aggregate mismatch in conditional expression: `%T' vs `%T'",
		    type1, type2);
	  return error_mark_node;
      /* Warning: this code assumes that conversion between cv-variants of
         a type is done using NOP_EXPRs.  */
      if (code1 == RECORD_TYPE && TYPE_HAS_CONVERSION (type1))
	  /* There are other types besides pointers and records.  */
	  tree tmp;
	  if (code2 == POINTER_TYPE)
	      tmp = build_pointer_type
		(cp_build_qualified_type (TREE_TYPE (type2),
					  TYPE_QUAL_CONST
					  | TYPE_QUAL_VOLATILE
					  | TYPE_QUAL_RESTRICT));
	  else
	    tmp = type2;
	  tmp = build_type_conversion (tmp, op1, 0);
	  if (tmp == NULL_TREE)
	      cp_error ("incompatible types `%T' and `%T' in `?:'",
			type1, type2);
	  if (tmp == error_mark_node)
	    error ("ambiguous pointer conversion");
	  else
	    STRIP_NOPS (tmp);
	  result_type = common_type (type2, TREE_TYPE (tmp));
	  op1 = tmp;
      else if (code2 == RECORD_TYPE && TYPE_HAS_CONVERSION (type2))
	  tree tmp;
	  if (code1 == POINTER_TYPE)
	      (cp_build_qualified_type (TREE_TYPE (type1),
					TYPE_QUAL_CONST
					| TYPE_QUAL_VOLATILE
	  else
	    tmp = type1;
	  tmp = build_type_conversion (tmp, op2, 0);
			type1, type2);
	  else
	    STRIP_NOPS (tmp);
	  result_type = common_type (type1, TREE_TYPE (tmp));
	  op2 = tmp;
      else if (flag_cond_mismatch)
      else
	  error ("type mismatch in conditional expression");
  if (TREE_CODE (result_type) == POINTER_TYPE
      && TREE_CODE (TREE_TYPE (result_type)) == METHOD_TYPE)
    result_type = build_ptrmemfunc_type (result_type);
  if (result_type != TREE_TYPE (op1))
    op1 = convert_for_initialization
      (NULL_TREE, result_type, op1, LOOKUP_NORMAL, "converting", NULL_TREE, 0);
  if (result_type != TREE_TYPE (op2))
    op2 = convert_for_initialization
      (NULL_TREE, result_type, op2, LOOKUP_NORMAL, "converting", NULL_TREE, 0);
  if (TREE_CODE (ifexp) == INTEGER_CST)
    return integer_zerop (ifexp) ? op2 : op1;
    (fold (build (COND_EXPR, result_type, ifexp, op1, op2)));
/* Handle overloading of the ',' operator when needed.  Otherwise,
   this function just builds an expression list.  */
tree
build_x_compound_expr (list)
     tree list;
  tree rest = TREE_CHAIN (list);
  tree result;
    return build_min_nt (COMPOUND_EXPR, list, NULL_TREE);
  if (rest == NULL_TREE)
    return build_compound_expr (list);
  result = build_opfncall (COMPOUND_EXPR, LOOKUP_NORMAL,
			   TREE_VALUE (list), TREE_VALUE (rest), NULL_TREE);
  if (result)
    return build_x_compound_expr (expr_tree_cons (NULL_TREE, result,
						  TREE_CHAIN (rest)));
  if (! TREE_SIDE_EFFECTS (TREE_VALUE (list)))
      /* the left-hand operand of a comma expression is like an expression
         statement: we should warn if it doesn't have any side-effects,
         unless it was explicitly cast to (void).  */
      if ((extra_warnings || warn_unused)
           && !(TREE_CODE (TREE_VALUE(list)) == CONVERT_EXPR
                && TREE_TYPE (TREE_VALUE(list)) == void_type_node))
        warning("left-hand operand of comma expression has no effect");
#if 0 /* this requires a gcc backend patch to export warn_if_unused_value */
  else if (warn_unused)
    warn_if_unused_value (TREE_VALUE(list));
#endif
    (expr_tree_cons (NULL_TREE, TREE_VALUE (list),
		     build_expr_list (NULL_TREE,
				      build_x_compound_expr (rest))));
/* Given a list of expressions, return a compound expression
   that performs them all and returns the value of the last of them.  */
tree
     tree list;
  register tree rest;
  tree first;
  if (TREE_READONLY_DECL_P (TREE_VALUE (list)))
    TREE_VALUE (list) = decl_constant_value (TREE_VALUE (list));
  if (TREE_CHAIN (list) == 0)
      /* build_c_cast puts on a NOP_EXPR to make the result not an lvalue.
	 Strip such NOP_EXPRs, since LIST is used in non-lvalue context.  */
      if (TREE_CODE (list) == NOP_EXPR
	  && TREE_TYPE (list) == TREE_TYPE (TREE_OPERAND (list, 0)))
	list = TREE_OPERAND (list, 0);
      /* Convert arrays to pointers.  */
      if (TREE_CODE (TREE_TYPE (TREE_VALUE (list))) == ARRAY_TYPE)
	return default_conversion (TREE_VALUE (list));
      else
	return TREE_VALUE (list);
  first = TREE_VALUE (list);
  first = require_complete_type_in_void (first);
  if (first == error_mark_node)
  rest = build_compound_expr (TREE_CHAIN (list));
  if (rest == error_mark_node)
  /* When pedantic, a compound expression cannot be a constant expression.  */
  if (! TREE_SIDE_EFFECTS (first) && ! pedantic)
    return rest;
  return build (COMPOUND_EXPR, TREE_TYPE (rest),
		break_out_cleanups (first), rest);
tree
build_static_cast (type, expr)
   tree type, expr;
  tree intype, binfo;
  int ok;
  if (type == error_mark_node || expr == error_mark_node)
  if (TREE_CODE (expr) == OFFSET_REF)
    expr = resolve_offset_ref (expr);
      tree t = build_min (STATIC_CAST_EXPR, copy_to_permanent (type),
			  expr);
      return t;
     Strip such NOP_EXPRs if VALUE is being used in non-lvalue context.  */
  if (TREE_CODE (type) != REFERENCE_TYPE
      && TREE_CODE (expr) == NOP_EXPR
      && TREE_TYPE (expr) == TREE_TYPE (TREE_OPERAND (expr, 0)))
    expr = TREE_OPERAND (expr, 0);
  if (TREE_CODE (type) == VOID_TYPE)
    return build1 (CONVERT_EXPR, type, expr);
  if (TREE_CODE (type) == REFERENCE_TYPE)
    return (convert_from_reference
	    (convert_to_reference (type, expr, CONV_STATIC|CONV_IMPLICIT,
				   LOOKUP_COMPLAIN, NULL_TREE)));
  if (IS_AGGR_TYPE (type))
    return build_cplus_new
      (type, (build_method_call
	      (NULL_TREE, ctor_identifier, build_expr_list (NULL_TREE, expr),
	       TYPE_BINFO (type), LOOKUP_NORMAL)));
  expr = decay_conversion (expr);
  intype = TREE_TYPE (expr);
  /* FIXME handle casting to array type.  */
  ok = 0;
  if (can_convert_arg (type, intype, expr))
    ok = 1;
  else if (TYPE_PTROB_P (type) && TYPE_PTROB_P (intype))
      tree binfo;
      if (IS_AGGR_TYPE (TREE_TYPE (type)) && IS_AGGR_TYPE (TREE_TYPE (intype))
	  && at_least_as_qualified_p (TREE_TYPE (type),
				      TREE_TYPE (intype))
	  && (binfo = get_binfo (TREE_TYPE (intype), TREE_TYPE (type), 0))
	  && ! TREE_VIA_VIRTUAL (binfo))
	ok = 1;
  else if (TYPE_PTRMEM_P (type) && TYPE_PTRMEM_P (intype))
      if (same_type_p (TYPE_MAIN_VARIANT (TREE_TYPE (TREE_TYPE (type))),
		       TYPE_MAIN_VARIANT (TREE_TYPE (TREE_TYPE (intype))))
	  && at_least_as_qualified_p (TREE_TYPE (TREE_TYPE (type)),
	  && (binfo = get_binfo (TYPE_OFFSET_BASETYPE (TREE_TYPE (type)),
				 TYPE_OFFSET_BASETYPE (TREE_TYPE (intype)), 0))
	ok = 1;
  else if (TREE_CODE (intype) != BOOLEAN_TYPE
	   && TREE_CODE (type) != ARRAY_TYPE
	   && TREE_CODE (type) != FUNCTION_TYPE
	   && can_convert (intype, type))
    ok = 1;
  /* [expr.static.cast]
     The static_cast operator shall not be used to cast away
     constnes.  */
  if (ok && casts_away_constness (intype, type))
      cp_error ("static_cast from `%T' to `%T' casts away constness",
		intype, type);
  if (ok)
    return build_c_cast (type, expr);
  cp_error ("static_cast from `%T' to `%T'", intype, type);
tree
build_reinterpret_cast (type, expr)
   tree type, expr;
  tree intype;
      tree t = build_min (REINTERPRET_CAST_EXPR,
			  copy_to_permanent (type), expr);
      return t;
  if (TREE_CODE (type) != REFERENCE_TYPE)
      if (TREE_CODE (expr) == NOP_EXPR
      if (! real_lvalue_p (expr))
	  cp_error ("reinterpret_cast from `%T' rvalue to `%T'", intype, type);
      expr = build_unary_op (ADDR_EXPR, expr, 0);
      if (expr != error_mark_node)
	expr = build_reinterpret_cast
	  (build_pointer_type (TREE_TYPE (type)), expr);
	expr = build_indirect_ref (expr, 0);
      return expr;
  else if (same_type_p (TYPE_MAIN_VARIANT (intype),
			TYPE_MAIN_VARIANT (type)))
    return build_static_cast (type, expr);
  if (TYPE_PTR_P (type) && (TREE_CODE (intype) == INTEGER_TYPE
			    || TREE_CODE (intype) == ENUMERAL_TYPE))
    /* OK */;
  else if (TREE_CODE (type) == INTEGER_TYPE && TYPE_PTR_P (intype))
      if (TYPE_PRECISION (type) < TYPE_PRECISION (intype))
	cp_pedwarn ("reinterpret_cast from `%T' to `%T' loses precision",
		    intype, type);
  else if ((TYPE_PTRFN_P (type) && TYPE_PTRFN_P (intype))
	   || (TYPE_PTRMEMFUNC_P (type) && TYPE_PTRMEMFUNC_P (intype)))
      if (TREE_READONLY_DECL_P (expr))
	expr = decl_constant_value (expr);
      return fold (build1 (NOP_EXPR, type, expr));
  else if ((TYPE_PTRMEM_P (type) && TYPE_PTRMEM_P (intype))
	   || (TYPE_PTROBV_P (type) && TYPE_PTROBV_P (intype)))
      if (! comp_ptr_ttypes_reinterpret (TREE_TYPE (type), TREE_TYPE (intype)))
	cp_pedwarn ("reinterpret_cast from `%T' to `%T' casts away const (or volatile)",
		    intype, type);
  else if ((TYPE_PTRFN_P (type) && TYPE_PTROBV_P (intype))
	   || (TYPE_PTRFN_P (intype) && TYPE_PTROBV_P (type)))
      pedwarn ("ANSI C++ forbids casting between pointers to functions and objects");
  else
      cp_error ("reinterpret_cast from `%T' to `%T'", intype, type);
  return cp_convert (type, expr);
tree
build_const_cast (type, expr)
   tree type, expr;
  tree intype;
      tree t = build_min (CONST_CAST_EXPR, copy_to_permanent (type),
			  expr);
      return t;
  if (!POINTER_TYPE_P (type))
      cp_error ("`%T' is not a pointer, reference, or pointer-to-data-member type",
		type);
      cp_error ("as required by const_cast");
  else if (TREE_CODE (TREE_TYPE (type)) == FUNCTION_TYPE)
      cp_error ("`%T' is a pointer or reference to a function type",
		type);
      cp_error ("which is forbidden by const_cast");
  if (same_type_p (TYPE_MAIN_VARIANT (intype), TYPE_MAIN_VARIANT (type)))
  else if (TREE_CODE (type) == REFERENCE_TYPE)
	  cp_error ("const_cast from `%T' rvalue to `%T'", intype, type);
      if (comp_ptr_ttypes_const (TREE_TYPE (type), intype))
	  expr = build1 (NOP_EXPR, type, expr);
	  return convert_from_reference (expr);
  else if (TREE_CODE (type) == POINTER_TYPE
	   && TREE_CODE (intype) == POINTER_TYPE
	   && comp_ptr_ttypes_const (TREE_TYPE (type), TREE_TYPE (intype)))
  cp_error ("const_cast from `%T' to `%T'", intype, type);
/* Build an expression representing a cast to type TYPE of expression EXPR.
   ALLOW_NONCONVERTING is true if we should allow non-converting constructors
   when doing the cast.  */
tree
     tree type, expr;
  register tree value = expr;
  tree otype;
      && TREE_CODE (value) == NOP_EXPR
      && TREE_TYPE (value) == TREE_TYPE (TREE_OPERAND (value, 0)))
    value = TREE_OPERAND (value, 0);
  if (TREE_CODE (value) == OFFSET_REF)
    value = resolve_offset_ref (value);
  if (TREE_CODE (type) == ARRAY_TYPE)
      /* Allow casting from T1* to T2[] because Cfront allows it.
	 NIHCL uses it. It is not valid ANSI C however, and hence, not
	 valid ANSI C++.  */
      if (TREE_CODE (TREE_TYPE (expr)) == POINTER_TYPE)
	  if (pedantic)
	    pedwarn ("ANSI C++ forbids casting to an array type");
	  type = build_pointer_type (TREE_TYPE (type));
      else
	  error ("ANSI C++ forbids casting to an array type");
  if (TREE_CODE (type) == FUNCTION_TYPE
      || TREE_CODE (type) == METHOD_TYPE)
      cp_error ("casting to function type `%T'", type);
  if (IS_SIGNATURE (type))
      error ("cast specifies signature type");
      tree t = build_min (CAST_EXPR, type,
			  min_tree_cons (NULL_TREE, value, NULL_TREE));
      return t;
  /* Convert functions and arrays to pointers and
     convert references to their expanded types,
     but don't convert any other types.  If, however, we are
     casting to a class type, there's no reason to do this: the
     cast will only succeed if there is a converting constructor,
     and the default conversions will be done at that point.  In
     fact, doing the default conversion here is actually harmful
     in cases like this:
     typedef int A[2];
     struct S { S(const A&); };
     since we don't want the array-to-pointer conversion done.  */
  if (!IS_AGGR_TYPE (type))
      if (TREE_CODE (TREE_TYPE (value)) == FUNCTION_TYPE
	  || (TREE_CODE (TREE_TYPE (value)) == METHOD_TYPE
	      /* Don't do the default conversion on a ->* expression.  */
	      && ! (TREE_CODE (type) == POINTER_TYPE
		    && bound_pmf_p (value)))
	  || TREE_CODE (TREE_TYPE (value)) == ARRAY_TYPE
	  || TREE_CODE (TREE_TYPE (value)) == REFERENCE_TYPE)
	value = default_conversion (value);
  else if (TREE_CODE (TREE_TYPE (value)) == REFERENCE_TYPE)
    /* However, even for class types, we still need to strip away
       the reference type, since the call to convert_force below
       does not expect the input expression to be of reference
       type.  */
    value = convert_from_reference (value);
  otype = TREE_TYPE (value);
  /* Optionally warn about potentially worrisome casts.  */
  if (warn_cast_qual
      && TREE_CODE (type) == POINTER_TYPE
      && TREE_CODE (otype) == POINTER_TYPE
      && !at_least_as_qualified_p (TREE_TYPE (type),
				   TREE_TYPE (otype)))
    cp_warning ("cast discards qualifiers from pointer target type");
  /* Warn about possible alignment problems.  */
  if (STRICT_ALIGNMENT && warn_cast_align
      && TREE_CODE (TREE_TYPE (otype)) != VOID_TYPE
      && TREE_CODE (TREE_TYPE (otype)) != FUNCTION_TYPE
      && TYPE_ALIGN (TREE_TYPE (type)) > TYPE_ALIGN (TREE_TYPE (otype)))
    warning ("cast increases required alignment of target type");
#if 0
  /* We should see about re-enabling these, they seem useful to
     me.  */
      && TYPE_PRECISION (type) != TYPE_PRECISION (otype))
    warning ("cast from pointer to integer of different size");
      && TREE_CODE (otype) == INTEGER_TYPE
      /* Don't warn about converting 0 to pointer,
	 provided the 0 was explicit--not cast or made by folding.  */
      && !(TREE_CODE (value) == INTEGER_CST && integer_zerop (value)))
    warning ("cast to pointer from integer of different size");
#endif
      value = require_complete_type_in_void (value);
      if (value != error_mark_node)
        value = build1 (CONVERT_EXPR, void_type_node, value);
    value = (convert_from_reference
	     (convert_to_reference (type, value, CONV_C_CAST,
  else
      tree ovalue;
      if (TREE_READONLY_DECL_P (value))
	value = decl_constant_value (value);
      ovalue = value;
      value = convert_force (type, value, CONV_C_CAST);
      /* Ignore any integer overflow caused by the cast.  */
      if (TREE_CODE (value) == INTEGER_CST)
	  TREE_OVERFLOW (value) = TREE_OVERFLOW (ovalue);
	  TREE_CONSTANT_OVERFLOW (value) = TREE_CONSTANT_OVERFLOW (ovalue);
    /* Always produce some operator for an explicit cast,
       so we can tell (for -pedantic) that the cast is no lvalue.  */
  if (TREE_CODE (type) != REFERENCE_TYPE && value == expr
      && real_lvalue_p (value))
    value = non_lvalue (value);
  return value;
/* Build an assignment expression of lvalue LHS from value RHS.
   MODIFYCODE is the code for a binary operator that we use
   to combine the old value of LHS with RHS to get the new value.
   Or else MODIFYCODE is NOP_EXPR meaning do a simple assignment.
   C++: If MODIFYCODE is INIT_EXPR, then leave references unbashed.  */
tree
build_modify_expr (lhs, modifycode, rhs)
     tree lhs;
     enum tree_code modifycode;
     tree rhs;
  tree newrhs = rhs;
  tree lhstype = TREE_TYPE (lhs);
  tree olhstype = lhstype;
  tree olhs = lhs;
  /* Avoid duplicate error messages from operands that had errors.  */
  if (lhs == error_mark_node || rhs == error_mark_node)
  /* Types that aren't fully specified cannot be used in assignments.  */
  lhs = require_complete_type (lhs);
  newrhs = rhs;
  /* Handle assignment to signature pointers/refs.  */
  if (TYPE_LANG_SPECIFIC (lhstype)
      && (IS_SIGNATURE_POINTER (lhstype) || IS_SIGNATURE_REFERENCE (lhstype)))
      return build_signature_pointer_constructor (lhs, rhs);
  /* Handle control structure constructs used as "lvalues".  */
  switch (TREE_CODE (lhs))
      /* Handle --foo = 5; as these are valid constructs in C++ */
      if (TREE_SIDE_EFFECTS (TREE_OPERAND (lhs, 0)))
	lhs = build (TREE_CODE (lhs), TREE_TYPE (lhs),
		     stabilize_reference (TREE_OPERAND (lhs, 0)),
		     TREE_OPERAND (lhs, 1));
      return build (COMPOUND_EXPR, lhstype,
		    lhs,
		    build_modify_expr (TREE_OPERAND (lhs, 0),
				       modifycode, rhs));
    case COMPOUND_EXPR:
      newrhs = build_modify_expr (TREE_OPERAND (lhs, 1),
				  modifycode, rhs);
      if (newrhs == error_mark_node)
		    TREE_OPERAND (lhs, 0), newrhs);
    case MODIFY_EXPR:
      newrhs = build_modify_expr (TREE_OPERAND (lhs, 0), modifycode, rhs);
      return build (COMPOUND_EXPR, lhstype, lhs, newrhs);
    case COND_EXPR:
      rhs = save_expr (rhs);
	/* Produce (a ? (b = rhs) : (c = rhs))
	   except that the RHS goes through a save-expr
	   so the code to compute it is only emitted once.  */
	tree cond
	  = build_conditional_expr (TREE_OPERAND (lhs, 0),
				    build_modify_expr (cp_convert (TREE_TYPE (lhs), TREE_OPERAND (lhs, 1)),
						       modifycode, rhs),
				    build_modify_expr (cp_convert (TREE_TYPE (lhs), TREE_OPERAND (lhs, 2)),
						       modifycode, rhs));
	if (cond == error_mark_node)
	  return cond;
	/* Make sure the code to compute the rhs comes out
	   before the split.  */
	return build (COMPOUND_EXPR, TREE_TYPE (lhs),
		      /* Case to void to suppress warning
			 from warn_if_unused_value.  */
		      cp_convert (void_type_node, rhs), cond);
    default:
      break;
  if (TREE_CODE (lhs) == OFFSET_REF)
      if (TREE_OPERAND (lhs, 0) == NULL_TREE)
	  /* Static class member?  */
	  tree member = TREE_OPERAND (lhs, 1);
	  if (TREE_CODE (member) == VAR_DECL)
	    lhs = member;
	  else
	      compiler_error ("invalid static class member");
      else
	lhs = resolve_offset_ref (lhs);
      olhstype = lhstype = TREE_TYPE (lhs);
  if (lhs == error_mark_node)
    return lhs;
  if (TREE_CODE (lhstype) == REFERENCE_TYPE
      && modifycode != INIT_EXPR)
      lhs = convert_from_reference (lhs);
  /* If a binary op has been requested, combine the old LHS value with the RHS
     producing the value we should actually store into the LHS.  */
  if (modifycode == INIT_EXPR)
      if (! IS_AGGR_TYPE (lhstype))
	/* Do the default thing */;
      else
	  result = build_method_call (lhs, ctor_identifier,
				      build_expr_list (NULL_TREE, rhs),
				      TYPE_BINFO (lhstype), LOOKUP_NORMAL);
	  if (result == NULL_TREE)
	  return result;
  else if (modifycode == NOP_EXPR)
      /* `operator=' is not an inheritable operator.  */
      else
	  result = build_opfncall (MODIFY_EXPR, LOOKUP_NORMAL,
				   lhs, rhs, make_node (NOP_EXPR));
	  return result;
      lhstype = olhstype;
  else if (PROMOTES_TO_AGGR_TYPE (lhstype, REFERENCE_TYPE))
      my_friendly_abort (978652);
  else
      lhs = stabilize_reference (lhs);
      newrhs = build_binary_op (modifycode, lhs, rhs);
	  cp_error ("  in evaluation of `%Q(%#T, %#T)'", modifycode,
		    TREE_TYPE (lhs), TREE_TYPE (rhs));
  /* Handle a cast used as an "lvalue".
     We have already performed any binary operator using the value as cast.
     Now convert the result to the cast type of the lhs,
     and then true type of the lhs and store it there;
     then convert result back to the cast type to be the value
     of the assignment.  */
    case NOP_EXPR:
    case CONVERT_EXPR:
    case FLOAT_EXPR:
    case FIX_CEIL_EXPR:
      if (TREE_CODE (TREE_TYPE (newrhs)) == ARRAY_TYPE
	  || TREE_CODE (TREE_TYPE (newrhs)) == FUNCTION_TYPE
	  || TREE_CODE (TREE_TYPE (newrhs)) == METHOD_TYPE
	  || TREE_CODE (TREE_TYPE (newrhs)) == OFFSET_TYPE)
	newrhs = default_conversion (newrhs);
	tree inner_lhs = TREE_OPERAND (lhs, 0);
	tree result;
	/* WP 5.4.1:  The result is an lvalue if T is a reference type,
	   otherwise the result is an rvalue.   */
	if (! lvalue_p (lhs))
	  pedwarn ("ANSI C++ forbids cast to non-reference type used as lvalue");
	result = build_modify_expr (inner_lhs, NOP_EXPR,
				    cp_convert (TREE_TYPE (inner_lhs),
						cp_convert (lhstype, newrhs)));
	if (result == error_mark_node)
	  return result;
	return cp_convert (TREE_TYPE (lhs), result);
    default:
      break;
  /* Now we have handled acceptable kinds of LHS that are not truly lvalues.
     Reject anything strange now.  */
  if (!lvalue_or_else (lhs, "assignment"))
  GNU_xref_assign (lhs);
  /* Warn about storing in something that is `const'.  */
  /* For C++, don't warn if this is initialization.  */
  if (modifycode != INIT_EXPR
      /* For assignment to `const' signature pointer/reference fields,
	 don't warn either, we already printed a better message before.  */
      && ! (TREE_CODE (lhs) == COMPONENT_REF
	    && (IS_SIGNATURE_POINTER (TREE_TYPE (TREE_OPERAND (lhs, 0)))
		|| IS_SIGNATURE_REFERENCE (TREE_TYPE (TREE_OPERAND (lhs, 0)))))
      && (TREE_READONLY (lhs) || CP_TYPE_CONST_P (lhstype)
	  /* Functions are not modifiable, even though they are
	     lvalues.  */
	  || TREE_CODE (TREE_TYPE (lhs)) == FUNCTION_TYPE
	  || (IS_AGGR_TYPE_CODE (TREE_CODE (lhstype))
	      && C_TYPE_FIELDS_READONLY (lhstype))
	      && CP_TYPE_CONST_P (TREE_TYPE (lhstype)))))
    readonly_error (lhs, "assignment", 0);
  /* If storing into a structure or union member,
     it has probably been given type `int'.
     Compute the type that would go with
     the actual amount of storage the member occupies.  */
  if (TREE_CODE (lhs) == COMPONENT_REF
      && (TREE_CODE (lhstype) == INTEGER_TYPE
	  || TREE_CODE (lhstype) == REAL_TYPE
	  || TREE_CODE (lhstype) == ENUMERAL_TYPE))
      lhstype = TREE_TYPE (get_unwidened (lhs, 0));
      /* If storing in a field that is in actuality a short or narrower
	 than one, we must store in the field in its actual type.  */
      if (lhstype != TREE_TYPE (lhs))
	  lhs = copy_node (lhs);
	  TREE_TYPE (lhs) = lhstype;
  /* check to see if there is an assignment to `this' */
  if (lhs == current_class_ptr)
      if (flag_this_is_variable > 0
	  && DECL_NAME (current_function_decl) != NULL_TREE
	  && (DECL_NAME (current_function_decl)
	      != constructor_name (current_class_type)))
	warning ("assignment to `this' not in constructor or destructor");
      current_function_just_assigned_this = 1;
  if (modifycode != INIT_EXPR)
      /* Make modifycode now either a NOP_EXPR or an INIT_EXPR.  */
      modifycode = NOP_EXPR;
      /* Reference-bashing */
      if (TREE_CODE (lhstype) == REFERENCE_TYPE)
	  tree tmp = convert_from_reference (lhs);
	  lhstype = TREE_TYPE (tmp);
	  if (TYPE_SIZE (lhstype) == 0)
	      incomplete_type_error (lhs, lhstype);
	  lhs = tmp;
	  olhstype = lhstype;
      if (TREE_CODE (TREE_TYPE (newrhs)) == REFERENCE_TYPE)
	  tree tmp = convert_from_reference (newrhs);
	  if (TYPE_SIZE (TREE_TYPE (tmp)) == 0)
	      incomplete_type_error (newrhs, TREE_TYPE (tmp));
	  newrhs = tmp;
  if (TREE_SIDE_EFFECTS (lhs))
  if (TREE_SIDE_EFFECTS (newrhs))
    newrhs = stabilize_reference (newrhs);
  /* Convert new value to destination type.  */
  if (TREE_CODE (lhstype) == ARRAY_TYPE)
      int from_array;
      if (!same_or_base_type_p (lhstype, TREE_TYPE (rhs)))
	  cp_error ("incompatible types in assignment of `%T' to `%T'",
		    TREE_TYPE (rhs), lhstype);
      /* Allow array assignment in compiler-generated code.  */
      if (pedantic && ! DECL_ARTIFICIAL (current_function_decl))
	pedwarn ("ANSI C++ forbids assignment of arrays");
      /* Have to wrap this in RTL_EXPR for two cases:
	 in base or member initialization and if we
	 are a branch of a ?: operator.  Since we
	 can't easily know the latter, just do it always.  */
      result = make_node (RTL_EXPR);
      TREE_TYPE (result) = void_type_node;
      do_pending_stack_adjust ();
      start_sequence_for_rtl_expr (result);
      /* As a matter of principle, `start_sequence' should do this.  */
      emit_note (0, -1);
      from_array = TREE_CODE (TREE_TYPE (newrhs)) == ARRAY_TYPE
	           ? 1 + (modifycode != INIT_EXPR): 0;
      expand_vec_init (lhs, lhs, array_type_nelts (lhstype), newrhs,
		       from_array);
      TREE_SIDE_EFFECTS (result) = 1;
      RTL_EXPR_SEQUENCE (result) = get_insns ();
      RTL_EXPR_RTL (result) = const0_rtx;
      end_sequence ();
      return result;
      newrhs = convert_for_initialization (lhs, lhstype, newrhs, LOOKUP_NORMAL,
					   "assignment", NULL_TREE, 0);
      if (lhs == DECL_RESULT (current_function_decl))
	  if (DECL_INITIAL (lhs))
	    warning ("return value from function receives multiple initializations");
	  DECL_INITIAL (lhs) = newrhs;
  else
      /* Avoid warnings on enum bit fields.  */
      if (TREE_CODE (olhstype) == ENUMERAL_TYPE
	  && TREE_CODE (lhstype) == INTEGER_TYPE)
	  newrhs = convert_for_assignment (olhstype, newrhs, "assignment",
					   NULL_TREE, 0);
	  newrhs = convert_force (lhstype, newrhs, 0);
      else
	newrhs = convert_for_assignment (lhstype, newrhs, "assignment",
					 NULL_TREE, 0);
      if (TREE_CODE (newrhs) == CALL_EXPR
	  && TYPE_NEEDS_CONSTRUCTING (lhstype))
	newrhs = build_cplus_new (lhstype, newrhs);
      /* Can't initialize directly from a TARGET_EXPR, since that would
	 cause the lhs to be constructed twice, and possibly result in
	 accidental self-initialization.  So we force the TARGET_EXPR to be
	 expanded without a target.  */
      if (TREE_CODE (newrhs) == TARGET_EXPR)
	newrhs = build (COMPOUND_EXPR, TREE_TYPE (newrhs), newrhs,
			TREE_OPERAND (newrhs, 0));
  if (TREE_CODE (newrhs) == COND_EXPR)
      tree lhs1;
      tree cond = TREE_OPERAND (newrhs, 0);
	cond = build_compound_expr (tree_cons
				    (NULL_TREE, lhs,
				     build_expr_list (NULL_TREE, cond)));
      /* Cannot have two identical lhs on this one tree (result) as preexpand
	 calls will rip them out and fill in RTL for them, but when the
	 rtl is generated, the calls will only be in the first side of the
	 condition, not on both, or before the conditional jump! (mrs) */
      lhs1 = break_out_calls (lhs);
      if (lhs == lhs1)
	/* If there's no change, the COND_EXPR behaves like any other rhs.  */
	result = build (modifycode == NOP_EXPR ? MODIFY_EXPR : INIT_EXPR,
      else
	  tree result_type = TREE_TYPE (newrhs);
	  /* We have to convert each arm to the proper type because the
	     types may have been munged by constant folding.  */
	  result
	    = build (COND_EXPR, result_type, cond,
						    TREE_OPERAND (newrhs, 1))),
		     build_modify_expr (lhs1, modifycode,
						    TREE_OPERAND (newrhs, 2))));
  else
  /* If we got the LHS in a different type for storing in,
     convert the result back to the nominal type of LHS
     so that the value we return always has the same type
     as the LHS argument.  */
  if (olhstype == TREE_TYPE (result))
    return result;
  /* Avoid warnings converting integral types back into enums
     for enum bit fields.  */
  if (TREE_CODE (TREE_TYPE (result)) == INTEGER_TYPE
      && TREE_CODE (olhstype) == ENUMERAL_TYPE)
      result = build (COMPOUND_EXPR, olhstype, result, olhs);
      TREE_NO_UNUSED_WARNING (result) = 1;
      return result;
  return convert_for_assignment (olhstype, result, "assignment",
				 NULL_TREE, 0);
tree
build_x_modify_expr (lhs, modifycode, rhs)
     tree lhs;
     tree rhs;
    return build_min_nt (MODOP_EXPR, lhs,
			 build_min_nt (modifycode, NULL_TREE, NULL_TREE), rhs);
  if (modifycode != NOP_EXPR)
      tree rval = build_opfncall (MODIFY_EXPR, LOOKUP_NORMAL, lhs, rhs,
				  make_node (modifycode));
      if (rval)
	return rval;
  return build_modify_expr (lhs, modifycode, rhs);
/* Get difference in deltas for different pointer to member function
   types.  Return integer_zero_node, if FROM cannot be converted to a
   TO type.  If FORCE is true, then allow reverse conversions as well.  */
static tree
get_delta_difference (from, to, force)
     tree from, to;
     int force;
  tree delta = integer_zero_node;
  tree binfo;
  if (to == from)
    return delta;
  /* Should get_base_distance here, so we can check if any thing along the
     path is virtual, and we need to make sure we stay
     inside the real binfos when going through virtual bases.
     Maybe we should replace virtual bases with
     binfo_member (...CLASSTYPE_VBASECLASSES...)...  (mrs) */
  binfo = get_binfo (from, to, 1);
  if (binfo == error_mark_node)
      error ("   in pointer to member function conversion");
      return delta;
  if (binfo == 0)
      if (!force)
	  error_not_base_type (from, to);
	  error ("   in pointer to member conversion");
	  return delta;
      binfo = get_binfo (to, from, 1);
      if (binfo == 0 || binfo == error_mark_node)
	return delta;
      if (TREE_VIA_VIRTUAL (binfo))
	  binfo = binfo_member (BINFO_TYPE (binfo),
				CLASSTYPE_VBASECLASSES (from));
	  cp_warning ("pointer to member cast to virtual base `%T'",
		      BINFO_TYPE (binfo));
	  warning ("  will only work if you are very careful");
      delta = BINFO_OFFSET (binfo);
      delta = cp_convert (ptrdiff_type_node, delta);
      return build_binary_op (MINUS_EXPR,
			      integer_zero_node,
			      delta);
      if (force)
	  cp_warning ("pointer to member cast from virtual base `%T'",
      else
	cp_error ("pointer to member conversion from virtual base `%T'",
  return BINFO_OFFSET (binfo);
tree
build_ptrmemfunc1 (type, delta, idx, pfn, delta2)
     tree type, delta, idx, pfn, delta2;
  tree u;
#if 0
  /* This is the old way we did it.  We want to avoid calling
     digest_init, so that it can give an error if we use { } when
     initializing a pointer to member function.  */
  if (pfn)
      u = build_nt (CONSTRUCTOR, NULL_TREE,
		    expr_tree_cons (pfn_identifier, pfn, NULL_TREE));
  else
		    expr_tree_cons (delta2_identifier, delta2, NULL_TREE));
		expr_tree_cons (NULL_TREE, delta,
			   expr_tree_cons (NULL_TREE, idx,
				      expr_tree_cons (NULL_TREE, u, NULL_TREE))));
  return digest_init (type, u, (tree*)0);
#else
  tree delta_field, idx_field, pfn_or_delta2_field, pfn_field, delta2_field;
  tree subtype;
  int allconstant, allsimple;
  delta_field = TYPE_FIELDS (type);
  idx_field = TREE_CHAIN (delta_field);
  pfn_or_delta2_field = TREE_CHAIN (idx_field);
  subtype = TREE_TYPE (pfn_or_delta2_field);
  pfn_field = TYPE_FIELDS (subtype);
  delta2_field = TREE_CHAIN (pfn_field);
  if (pfn)
      allconstant = TREE_CONSTANT (pfn);
      allsimple = !! initializer_constant_valid_p (pfn, TREE_TYPE (pfn));
      u = expr_tree_cons (pfn_field, pfn, NULL_TREE);
  else
      delta2 = convert_and_check (delta_type_node, delta2);
      allconstant = TREE_CONSTANT (delta2);
      allsimple = !! initializer_constant_valid_p (delta2, TREE_TYPE (delta2));
      u = expr_tree_cons (delta2_field, delta2, NULL_TREE);
  delta = convert_and_check (delta_type_node, delta);
  idx = convert_and_check (delta_type_node, idx);
  allconstant = allconstant && TREE_CONSTANT (delta) && TREE_CONSTANT (idx);
  allsimple = allsimple
    && initializer_constant_valid_p (delta, TREE_TYPE (delta))
      && initializer_constant_valid_p (idx, TREE_TYPE (idx));
  u = build (CONSTRUCTOR, subtype, NULL_TREE, u);
  u = expr_tree_cons (delta_field, delta,
		 expr_tree_cons (idx_field, idx,
			    expr_tree_cons (pfn_or_delta2_field, u, NULL_TREE)));
  u = build (CONSTRUCTOR, type, NULL_TREE, u);
  TREE_CONSTANT (u) = allconstant;
  TREE_STATIC (u) = allconstant && allsimple;
  return u;
#endif
/* Build a constructor for a pointer to member function.  It can be
   used to initialize global variables, local variable, or used
   as a value in expressions.  TYPE is the POINTER to METHOD_TYPE we
   want to be.
   If FORCE is non-zero, then force this conversion, even if
   we would rather not do it.  Usually set when using an explicit
   cast.
   Return error_mark_node, if something goes wrong.  */
tree
build_ptrmemfunc (type, pfn, force)
     tree type, pfn;
     int force;
  tree fn;
  tree pfn_type = TREE_TYPE (pfn);
  tree to_type = build_ptrmemfunc_type (type);
  /* Handle multiple conversions of pointer to member functions.  */
  if (TYPE_PTRMEMFUNC_P (TREE_TYPE (pfn)))
      tree idx = integer_zero_node;
      tree delta2 = integer_zero_node;
      tree npfn = NULL_TREE;
      tree ndelta, ndelta2;
      tree e1, e2, e3, n;
      if (!force
	  && !can_convert_arg (to_type, TREE_TYPE (pfn), pfn))
	cp_error ("conversion to `%T' from `%T'",
		  to_type, pfn_type);
      if (TREE_CODE (pfn) == PTRMEM_CST)
	  /* We could just build the resulting CONSTRUCTOR now, but we
	     don't, relying on the general machinery below, together
	     with constant-folding, to do the right thing.  We don't
	     want to return a PTRMEM_CST here, since a
	     pointer-to-member constant is no longer a valid template
	     argument once it is cast to any type, including its
	     original type.  */
	  expand_ptrmemfunc_cst (pfn, &ndelta, &idx, &npfn, &ndelta2);
	  if (npfn)
	    /* This constant points to a non-virtual function.
	       NDELTA2 will be NULL, but it's value doesn't really
	       matter since we won't use it anyhow.  */
	    ndelta2 = integer_zero_node;
      else if (same_type_p (to_type, pfn_type))
	/* We don't have to do any conversion.  Note that we do this
	   after checking for a PTRMEM_CST so that a PTRMEM_CST, cast
	   to its own type, will not be considered a legal non-type
	   template argument.  */
	return pfn;
      else
	  ndelta = cp_convert (ptrdiff_type_node,
			       build_component_ref (pfn,
						    delta_identifier,
						    NULL_TREE, 0));
	  ndelta2 = cp_convert (ptrdiff_type_node,
				DELTA2_FROM_PTRMEMFUNC (pfn));
	  idx = build_component_ref (pfn, index_identifier, NULL_TREE, 0);
      n = get_delta_difference (TYPE_PTRMEMFUNC_OBJECT_TYPE (pfn_type),
				TYPE_PTRMEMFUNC_OBJECT_TYPE (to_type),
				force);
      delta = build_binary_op (PLUS_EXPR, ndelta, n);
      delta2 = build_binary_op (PLUS_EXPR, ndelta2, n);
      e1 = fold (build (GT_EXPR, boolean_type_node, idx, integer_zero_node));
      /* If it's a virtual function, this is what we want.  */
      e2 = build_ptrmemfunc1 (to_type, delta, idx,
			      NULL_TREE, delta2);
      pfn = PFN_FROM_PTRMEMFUNC (pfn);
      npfn = build1 (NOP_EXPR, type, pfn);
      TREE_CONSTANT (npfn) = TREE_CONSTANT (pfn);
      /* But if it's a non-virtual function, or NULL, we use this
	 instead.  */
      e3 = build_ptrmemfunc1 (to_type, delta,
			      idx, npfn, NULL_TREE);
      return build_conditional_expr (e1, e2, e3);
  /* Handle null pointer to member function conversions.  */
  if (integer_zerop (pfn))
      pfn = build_c_cast (type, integer_zero_node);
      return build_ptrmemfunc1 (to_type,
				integer_zero_node, integer_zero_node,
				pfn, NULL_TREE);
  if (type_unknown_p (pfn))
    return instantiate_type (type, pfn, 1);
  fn = TREE_OPERAND (pfn, 0);
  my_friendly_assert (TREE_CODE (fn) == FUNCTION_DECL, 0);
  return make_ptrmem_cst (to_type, fn);
/* Return the DELTA, IDX, PFN, and DELTA2 values for the PTRMEM_CST
   given by CST.  */
void
expand_ptrmemfunc_cst (cst, delta, idx, pfn, delta2)
     tree cst;
     tree *delta;
     tree *idx;
     tree *pfn;
     tree *delta2;
  tree type = TREE_TYPE (cst);
  tree fn = PTRMEM_CST_MEMBER (cst);
  *delta
    = get_delta_difference (TYPE_METHOD_BASETYPE (TREE_TYPE (fn)),
			    TYPE_PTRMEMFUNC_OBJECT_TYPE (type),
			    /*force=*/0);
  if (!DECL_VIRTUAL_P (fn))
      *idx = size_binop (MINUS_EXPR, integer_zero_node,
			 integer_one_node);
      *pfn = build_addr_func (fn);
      if (!same_type_p (TYPE_METHOD_BASETYPE (TREE_TYPE (fn)),
			TYPE_PTRMEMFUNC_OBJECT_TYPE (type)))
	*pfn = build1 (NOP_EXPR, TYPE_PTRMEMFUNC_FN_TYPE (type),
		       *pfn);
      *delta2 = NULL_TREE;
  else
      *idx = size_binop (PLUS_EXPR, DECL_VINDEX (fn),
			 integer_one_node);
      *pfn = NULL_TREE;
      *delta2 = get_binfo (DECL_CONTEXT (fn),
			  DECL_CLASS_CONTEXT (fn),
			  0);
      *delta2 = get_vfield_offset (*delta2);
      *delta2 = size_binop (PLUS_EXPR, *delta2,
					    *delta,
/* Return an expression for DELTA2 from the pointer-to-member function
   given by T.  */
tree
delta2_from_ptrmemfunc (t)
     tree t;
  if (TREE_CODE (t) == PTRMEM_CST)
      tree delta;
      tree idx;
      tree pfn;
      tree delta2;
      expand_ptrmemfunc_cst (t, &delta, &idx, &pfn, &delta2);
      if (delta2)
	return delta2;
  return (build_component_ref
	  (build_component_ref (t,
				pfn_or_delta2_identifier, NULL_TREE,
				0),
	   delta2_identifier, NULL_TREE, 0));
/* Return an expression for PFN from the pointer-to-member function
   given by T.  */
tree
pfn_from_ptrmemfunc (t)
     tree t;
      tree delta;
      tree idx;
      tree pfn;
      tree delta2;
      if (pfn)
	return pfn;
				0),
	   pfn_identifier, NULL_TREE, 0));
/* Convert value RHS to type TYPE as preparation for an assignment
   to an lvalue of type TYPE.
   The real work of conversion is done by `convert'.
   The purpose of this function is to generate error messages
   for assignments that are not allowed in C.
   ERRTYPE is a string to use in error messages:
   "assignment", "return", etc.
   C++: attempts to allow `convert' to find conversions involving
   implicit type conversion between aggregate and scalar types
   as per 8.5.6 of C++ manual.  Does not randomly dereference
   pointers to aggregates!  */
static tree
convert_for_assignment (type, rhs, errtype, fndecl, parmnum)
     tree type, rhs;
     const char *errtype;
     tree fndecl;
     int parmnum;
  register enum tree_code codel = TREE_CODE (type);
  register tree rhstype;
  register enum tree_code coder;
  if (codel == OFFSET_TYPE)
    my_friendly_abort (990505);
  if (TREE_CODE (rhs) == OFFSET_REF)
    rhs = resolve_offset_ref (rhs);
  /* Strip NON_LVALUE_EXPRs since we aren't using as an lvalue.  */
  if (TREE_CODE (rhs) == NON_LVALUE_EXPR)
    rhs = TREE_OPERAND (rhs, 0);
  if (rhs == error_mark_node || TREE_TYPE (rhs) == error_mark_node)
  if (TREE_CODE (rhs) == TREE_LIST && TREE_VALUE (rhs) == error_mark_node)
  if (TREE_CODE (TREE_TYPE (rhs)) == ARRAY_TYPE
      || is_overloaded_fn (rhs))
    rhs = default_conversion (rhs);
  else if (TREE_CODE (TREE_TYPE (rhs)) == REFERENCE_TYPE)
    rhs = convert_from_reference (rhs);
  /* If rhs is some sort of overloaded function, ocp_convert will either
     do the right thing or complain; we don't need to check anything else.
     So just hand off.  */
  if (type_unknown_p (rhs))
    return ocp_convert (type, rhs, CONV_IMPLICIT, LOOKUP_NORMAL);
  rhstype = TREE_TYPE (rhs);
  coder = TREE_CODE (rhstype);
  /* Issue warnings about peculiar, but legal, uses of NULL.  */
  if (ARITHMETIC_TYPE_P (type) && rhs == null_node)
    cp_warning ("converting NULL to non-pointer type");
  /* This should no longer change types on us.  */
  if (TREE_CODE (rhs) == CONST_DECL)
    rhs = DECL_INITIAL (rhs);
  else if (TREE_READONLY_DECL_P (rhs))
    rhs = decl_constant_value (rhs);
  if (same_type_p (type, rhstype))
      overflow_warning (rhs);
      return rhs;
  if (coder == VOID_TYPE)
      error ("void value not ignored as it ought to be");
  /* Arithmetic types all interconvert.  */
  if ((codel == INTEGER_TYPE || codel == REAL_TYPE || codel == BOOLEAN_TYPE
       || codel == COMPLEX_TYPE)
       && (coder == INTEGER_TYPE || coder == REAL_TYPE || coder == BOOLEAN_TYPE
	   || coder == COMPLEX_TYPE))
      /* But we should warn if assigning REAL_TYPE to INTEGER_TYPE.  */
      if (coder == REAL_TYPE && codel == INTEGER_TYPE)
	  if (fndecl)
	    cp_warning ("`%T' used for argument %P of `%D'",
			rhstype, parmnum, fndecl);
	  else
	    cp_warning ("%s to `%T' from `%T'", errtype, type, rhstype);
      /* And we should warn if assigning a negative value to
	 an unsigned variable.  */
      else if (TREE_UNSIGNED (type) && codel != BOOLEAN_TYPE)
	  if (TREE_CODE (rhs) == INTEGER_CST
	      && TREE_NEGATED_INT (rhs))
	      if (fndecl)
		cp_warning ("negative value `%E' passed as argument %P of `%D'",
			    rhs, parmnum, fndecl);
	      else
		cp_warning ("%s of negative value `%E' to `%T'",
			    errtype, rhs, type);
	  if (TREE_CONSTANT (rhs))
	    rhs = fold (rhs);
      return convert_and_check (type, rhs);
  /* Conversions involving enums.  */
  else if ((codel == ENUMERAL_TYPE
	    && (INTEGRAL_CODE_P (coder) || coder == REAL_TYPE))
	   || (coder == ENUMERAL_TYPE
	       && (INTEGRAL_CODE_P (codel) || codel == REAL_TYPE)))
  /* Conversions among pointers */
  else if (codel == POINTER_TYPE
	   && (coder == POINTER_TYPE
	       || (coder == RECORD_TYPE
		   && (IS_SIGNATURE_POINTER (rhstype)
		       || IS_SIGNATURE_REFERENCE (rhstype)))))
      register tree ttl = TREE_TYPE (type);
      register tree ttr;
      int ctt = 0;
      if (coder == RECORD_TYPE)
	  rhs = build_optr_ref (rhs);
      ttr = TREE_TYPE (rhstype);
      /* If both pointers are of aggregate type, then we
	 can give better error messages, and save some work
	 as well.  */
      if (TREE_CODE (ttl) == RECORD_TYPE && TREE_CODE (ttr) == RECORD_TYPE)
	  tree binfo;
	  if (TYPE_MAIN_VARIANT (ttl) == TYPE_MAIN_VARIANT (ttr)
	      || type == class_star_type_node
	      || rhstype == class_star_type_node)
	    binfo = TYPE_BINFO (ttl);
	  else
	    binfo = get_binfo (ttl, ttr, 1);
	  if (binfo == 0)
	    return error_not_base_type (ttl, ttr);
	  if (!at_least_as_qualified_p (ttl, ttr))
	      if (fndecl)
		cp_pedwarn ("passing `%T' as argument %P of `%D' discards qualifiers",
	      else
		cp_pedwarn ("%s to `%T' from `%T' discards qualifiers",
      /* Any non-function converts to a [const][volatile] void *
	 and vice versa; otherwise, targets must be the same.
	 Meanwhile, the lhs target must have all the qualifiers of the rhs.  */
      else if (TYPE_MAIN_VARIANT (ttl) == void_type_node
	       || TYPE_MAIN_VARIANT (ttr) == void_type_node
	       || (ctt = comp_target_types (type, rhstype, 1))
	       || (unsigned_type (TYPE_MAIN_VARIANT (ttl))
		   == unsigned_type (TYPE_MAIN_VARIANT (ttr))))
	  /* ARM $4.8, commentary on p39.  */
	      && TREE_CODE (ttr) == OFFSET_TYPE)
	      cp_error ("no standard conversion from `%T' to `void *'", ttr);
	  if (ctt < 0 && TYPE_MAIN_VARIANT (ttl) != TYPE_MAIN_VARIANT (ttr))
	    cp_pedwarn ("converting `%T' to `%T' is a contravariance violation",
			rhstype, type);
	  if (TYPE_MAIN_VARIANT (ttl) != void_type_node
	      && TYPE_MAIN_VARIANT (ttr) == void_type_node
	      && ! null_ptr_cst_p (rhs))
		cp_pedwarn ("implicit conversion of signature pointer to type `%T'",
			    type);
	      else
		pedwarn ("ANSI C++ forbids implicit conversion from `void *' in %s",
			 errtype);
	  /* Const and volatile mean something different for function types,
	     so the usual warnings are not appropriate.  */
	  else if ((TREE_CODE (ttr) != FUNCTION_TYPE && TREE_CODE (ttr) != METHOD_TYPE)
		   || (TREE_CODE (ttl) != FUNCTION_TYPE && TREE_CODE (ttl) != METHOD_TYPE))
	      if (TREE_CODE (ttl) == OFFSET_TYPE
		  && binfo_member (TYPE_OFFSET_BASETYPE (ttr),
				   CLASSTYPE_VBASECLASSES (TYPE_OFFSET_BASETYPE (ttl))))
		  error ("%s between pointer to members converting across virtual baseclasses", errtype);
	      else if (!at_least_as_qualified_p (ttl, ttr))
		  if (string_conv_p (type, rhs, 1))
		    /* converting from string constant to char *, OK.  */;
		  else if (fndecl)
		      /* Some builtin functions allow const and volatile and do not
			 discard their meaning.  */
		      if (!(TREE_CODE (fndecl) == FUNCTION_DECL
			    && DECL_TARGET_INTRINSIC_P (fndecl)))
		  else
	      else if (TREE_CODE (ttl) == TREE_CODE (ttr)
		       && ! comp_target_types (type, rhstype, 1))
		  if (fndecl)
		    cp_pedwarn ("passing `%T' as argument %P of `%D' changes signedness",
		  else
		    cp_pedwarn ("%s to `%T' from `%T' changes signedness",
      else
	  int add_quals = 0;
	  int drops_quals = 0;
	  int left_const = 1;
	  int unsigned_parity;
	  int nptrs = 0;
	  /* This code is basically a duplicate of comp_ptr_ttypes_real.  */
	  for (; ; ttl = TREE_TYPE (ttl), ttr = TREE_TYPE (ttr))
	      nptrs -= 1;
	      drops_quals |= !at_least_as_qualified_p (ttl, ttr);
	      if (! left_const
		  && !at_least_as_qualified_p (ttr, ttl))
		add_quals = 1;
	      left_const &= TYPE_READONLY (ttl);
	      if (TREE_CODE (ttl) != POINTER_TYPE
		  || TREE_CODE (ttr) != POINTER_TYPE)
		break;
	  unsigned_parity = TREE_UNSIGNED (ttl) - TREE_UNSIGNED (ttr);
	  if (unsigned_parity)
	      if (TREE_UNSIGNED (ttl))
		ttr = unsigned_type (ttr);
	      else
		ttl = unsigned_type (ttl);
	  if (comp_target_types (ttl, ttr, nptrs) > 0)
	      if (add_quals)
		  if (fndecl)
		    cp_pedwarn ("passing `%T' as argument %P of `%D' adds cv-quals without intervening `const'",
		  else
		    cp_pedwarn ("%s to `%T' from `%T' adds cv-quals without intervening `const'",
	      if (drops_quals)
		  if (fndecl)
		  else
	      if (unsigned_parity > 0)
		  if (fndecl)
		    cp_pedwarn ("passing `%T' as argument %P of `%D' changes signed to unsigned",
		  else
		    cp_pedwarn ("%s to `%T' from `%T' changes signed to unsigned",
	      else if (unsigned_parity < 0)
		  if (fndecl)
		    cp_pedwarn ("passing `%T' as argument %P of `%D' changes unsigned to signed",
		  else
		    cp_pedwarn ("%s to `%T' from `%T' changes unsigned to signed",
	      /* C++ is not so friendly about converting function and
		 member function pointers as C.  Emit warnings here.  */
	      if (TREE_CODE (ttl) == FUNCTION_TYPE
		  || TREE_CODE (ttl) == METHOD_TYPE)
		if (!same_or_base_type_p (ttl, ttr))
		    warning ("conflicting function types in %s:", errtype);
		    cp_warning ("\t`%T' != `%T'", type, rhstype);
	  else
	      if (fndecl)
		cp_error ("passing `%T' as argument %P of `%D'",
	      else
		cp_error ("%s to `%T' from `%T'", errtype, type, rhstype);
      return cp_convert (type, rhs);
	       || coder == BOOLEAN_TYPE))
      /* An explicit constant 0 can convert to a pointer,
         but not a 0 that results from casting or folding.  */
      if (! (TREE_CODE (rhs) == INTEGER_CST && integer_zerop (rhs)))
	  if (fndecl)
	    cp_pedwarn ("passing `%T' to argument %P of `%D' lacks a cast",
	  else
	    cp_pedwarn ("%s to `%T' from `%T' lacks a cast",
  else if (codel == INTEGER_TYPE
		       || TYPE_PTRMEMFUNC_FLAG (rhstype)
      if (fndecl)
      else
  else if (codel == BOOLEAN_TYPE
  /* C++ */
  else if (((coder == POINTER_TYPE
	     && TREE_CODE (TREE_TYPE (rhstype)) == METHOD_TYPE)
	    || integer_zerop (rhs)
	    || TYPE_PTRMEMFUNC_P (rhstype))
	   && TYPE_PTRMEMFUNC_P (type))
      tree ttl = TYPE_PTRMEMFUNC_FN_TYPE (type);
      tree ttr = (TYPE_PTRMEMFUNC_P (rhstype)
		  ? TYPE_PTRMEMFUNC_FN_TYPE (rhstype)
		  : rhstype);
      int ctt = (TREE_CODE (rhstype) == INTEGER_TYPE ? 1
		 : comp_target_types (ttl, ttr, 1));
      if (ctt < 0)
		    ttr, ttl);
      else if (ctt == 0)
	cp_error ("%s to `%T' from `%T'", errtype, ttl, ttr);
      /* compatible pointer to member functions.  */
      return build_ptrmemfunc (ttl, rhs, 0);
  else if (codel == ERROR_MARK || coder == ERROR_MARK)
  /* This should no longer happen.  References are initialized via
     `convert_for_initialization'.  They should otherwise be
     bashed before coming here.  */
  else if (codel == REFERENCE_TYPE)
    my_friendly_abort (317);
  else if (TYPE_MAIN_VARIANT (type) == TYPE_MAIN_VARIANT (TREE_TYPE (rhs)))
      tree nrhs = build1 (NOP_EXPR, type, rhs);
      TREE_CONSTANT (nrhs) = TREE_CONSTANT (rhs);
      return nrhs;
  else if (TYPE_HAS_CONSTRUCTOR (type) || IS_AGGR_TYPE (TREE_TYPE (rhs)))
  /* Handle anachronistic conversions from (::*)() to cv void* or (*)().  */
	   && (TREE_CODE (TREE_TYPE (type)) == FUNCTION_TYPE
	       || TYPE_MAIN_VARIANT (TREE_TYPE (type)) == void_type_node)
	   && TREE_TYPE (rhs)
	   && TYPE_PTRMEMFUNC_P (TREE_TYPE (rhs)))
/* Convert RHS to be of type TYPE.
   If EXP is non-zero, it is the target of the initialization.
   ERRTYPE is a string to use in error messages.
   Two major differences between the behavior of
   `convert_for_assignment' and `convert_for_initialization'
   are that references are bashed in the former, while
   copied in the latter, and aggregates are assigned in
   the former (operator=) while initialized in the
   latter (X(X&)).
   If using constructor make sure no conversion operator exists, if one does
   exist, an ambiguity exists.
   If flags doesn't include LOOKUP_COMPLAIN, don't complain about anything.  */
tree
convert_for_initialization (exp, type, rhs, flags, errtype, fndecl, parmnum)
     tree exp, type, rhs;
     int flags;
     tree fndecl;
     int parmnum;
     Strip such NOP_EXPRs, since RHS is used in non-lvalue context.  */
  if (TREE_CODE (rhs) == NOP_EXPR
      && TREE_TYPE (rhs) == TREE_TYPE (TREE_OPERAND (rhs, 0))
      && codel != REFERENCE_TYPE)
      || (TREE_CODE (rhs) == TREE_LIST && TREE_VALUE (rhs) == error_mark_node))
      if (rhs == error_mark_node)
  if ((TREE_CODE (TREE_TYPE (rhs)) == ARRAY_TYPE
       && (TREE_CODE (type) != REFERENCE_TYPE
	   || TREE_CODE (TREE_TYPE (type)) != ARRAY_TYPE))
      || (TREE_CODE (TREE_TYPE (rhs)) == FUNCTION_TYPE
	      || TREE_CODE (TREE_TYPE (type)) != FUNCTION_TYPE))
      || TREE_CODE (TREE_TYPE (rhs)) == METHOD_TYPE)
  if (coder == ERROR_MARK)
  /* We accept references to incomplete types, so we can
     return here before checking if RHS is of complete type.  */
      /* This should eventually happen in convert_arguments.  */
      extern int warningcount, errorcount;
      int savew = 0, savee = 0;
      if (fndecl)
	savew = warningcount, savee = errorcount;
      rhs = convert_to_reference (type, rhs, CONV_IMPLICIT, flags,
				  exp ? exp : error_mark_node);
      if (fndecl)
	  if (warningcount > savew)
	    cp_warning_at ("in passing argument %P of `%+D'", parmnum, fndecl);
	  else if (errorcount > savee)
	    cp_error_at ("in passing argument %P of `%+D'", parmnum, fndecl);
      return rhs;
  if (exp != 0)
    exp = require_complete_type (exp);
  if (exp == error_mark_node)
  if (TREE_CODE (rhstype) == REFERENCE_TYPE)
    rhstype = TREE_TYPE (rhstype);
  type = complete_type (type);
  if (TYPE_LANG_SPECIFIC (type)
      && (IS_SIGNATURE_POINTER (type) || IS_SIGNATURE_REFERENCE (type)))
    return build_signature_pointer_constructor (type, rhs);
    return ocp_convert (type, rhs, CONV_IMPLICIT|CONV_FORCE_TEMP, flags);
  if (type == TREE_TYPE (rhs))
      /* Issue warnings about peculiar, but legal, uses of NULL.  We
	 do this *before* the call to decl_constant_value so as to
	 avoid duplicate warnings on code like `const int I = NULL;
	 f(I);'.  */
      return rhs;
  return convert_for_assignment (type, rhs, errtype, fndecl, parmnum);
/* Expand an ASM statement with operands, handling output operands
   that are not variables or INDIRECT_REFS by transforming such
   cases into cases that expand_asm_operands can handle.
   Arguments are same as for expand_asm_operands.
   We don't do default conversions on all inputs, because it can screw
   up operands that are expected to be in memory.  */
void
c_expand_asm_operands (string, outputs, inputs, clobbers, vol, filename, line)
     tree string, outputs, inputs, clobbers;
     int vol;
     char *filename;
     int line;
  int noutputs = list_length (outputs);
  register int i;
  /* o[I] is the place that output number I should be written.  */
  register tree *o = (tree *) alloca (noutputs * sizeof (tree));
  register tree tail;
  /* Record the contents of OUTPUTS before it is modified.  */
  for (i = 0, tail = outputs; tail; tail = TREE_CHAIN (tail), i++)
    o[i] = TREE_VALUE (tail);
  /* Generate the ASM_OPERANDS insn;
     store into the TREE_VALUEs of OUTPUTS some trees for
     where the values were actually stored.  */
  expand_asm_operands (string, outputs, inputs, clobbers, vol, filename, line);
  /* Copy all the intermediate outputs into the specified outputs.  */
      if (o[i] != TREE_VALUE (tail))
	  expand_expr (build_modify_expr (o[i], NOP_EXPR, TREE_VALUE (tail)),
		       const0_rtx, VOIDmode, EXPAND_NORMAL);
	  free_temp_slots ();
      /* Detect modification of read-only values.
	 (Otherwise done by build_modify_expr.)  */
      else
	  tree type = TREE_TYPE (o[i]);
	  if (CP_TYPE_CONST_P (type)
	      || (IS_AGGR_TYPE_CODE (TREE_CODE (type))
		  && C_TYPE_FIELDS_READONLY (type)))
	    readonly_error (o[i], "modification by `asm'", 1);
  /* Those MODIFY_EXPRs could do autoincrements.  */
  emit_queue ();
/* Expand a C `return' statement.
   RETVAL is the expression for what to return,
   or a null pointer for `return;' with no value.
   C++: upon seeing a `return', we must call destructors on all
   variables in scope which had constructors called on them.
   This means that if in a destructor, the base class destructors
   must be called before returning.
   The RETURN statement in C++ has initialization semantics.  */
void
c_expand_return (retval)
     tree retval;
  extern struct nesting *cond_stack, *loop_stack, *case_stack;
  extern tree dtor_label, ctor_label;
  tree result = DECL_RESULT (current_function_decl);
  tree valtype = TREE_TYPE (result);
  if (TREE_THIS_VOLATILE (current_function_decl))
    warning ("function declared `noreturn' has a `return' statement");
  if (retval == error_mark_node)
      current_function_returns_null = 1;
      return;
  if (processing_template_decl)
      add_tree (build_min_nt (RETURN_STMT, retval));
      return;
  if (dtor_label)
      if (retval)
	error ("returning a value from a destructor");
      /* Can't just return from a destructor.  */
      expand_goto (dtor_label);
      return;
  /* Only operator new(...) throw(), can return NULL [expr.new/13].  */
  if ((DECL_NAME (current_function_decl) == ansi_opname[(int) NEW_EXPR]
       || DECL_NAME (current_function_decl) == ansi_opname[(int) VEC_NEW_EXPR])
      && !TYPE_NOTHROW_P (TREE_TYPE (current_function_decl))
      && null_ptr_cst_p (retval))
    cp_pedwarn ("operator new should throw an exception, not return NULL");
  if (retval == NULL_TREE)
      /* A non-named return value does not count.  */
      if (DECL_CONSTRUCTOR_P (current_function_decl))
	retval = current_class_ptr;
      else if (DECL_NAME (result) != NULL_TREE
	       && TREE_CODE (valtype) != VOID_TYPE)
	retval = result;
      else
	  if (valtype != NULL_TREE && TREE_CODE (valtype) != VOID_TYPE)
	      if (DECL_NAME (DECL_RESULT (current_function_decl)) == NULL_TREE)
		  pedwarn ("`return' with no value, in function returning non-void");
		  /* Clear this, so finish_function won't say that we
		     reach the end of a non-void function (which we don't,
		     we gave a return!).  */
		  current_function_returns_null = 0;
	  expand_null_return ();
	  return;
  else if (DECL_CONSTRUCTOR_P (current_function_decl))
      if (flag_this_is_variable)
	error ("return from a constructor: use `this = ...' instead");
      else
	error ("returning a value from a constructor");
  /* Effective C++ rule 15.  See also start_function.  */
  if (warn_ecpp
      && DECL_NAME (current_function_decl) == ansi_opname[(int) MODIFY_EXPR]
      && retval != current_class_ref)
    cp_warning ("`operator=' should return a reference to `*this'");
  if (valtype == NULL_TREE || TREE_CODE (valtype) == VOID_TYPE)
      if (TREE_CODE (TREE_TYPE (retval)) != VOID_TYPE)
	pedwarn ("`return' with a value, in function returning void");
      expand_return (retval);
      return;
  /* Now deal with possible C++ hair:
     (1) Compute the return value.
     (2) If there are aggregate values with destructors which
     must be cleaned up, clean them (taking care
     not to clobber the return value).
     (3) If an X(X&) constructor is defined, the return
     value must be returned via that.  */
  if (retval == result
    /* It's already done for us.  */;
  else if (TREE_CODE (TREE_TYPE (retval)) == VOID_TYPE)
      pedwarn ("return of void value in function returning non-void");
      expand_expr_stmt (retval);
      retval = 0;
  else
      tree functype = TREE_TYPE (TREE_TYPE (current_function_decl));
      /* First convert the value to the function's return type, then
	 to the type of return value's location to handle the
         case that functype is thiner than the valtype. */
      retval = convert_for_initialization
	(NULL_TREE, functype, retval, LOOKUP_NORMAL|LOOKUP_ONLYCONVERTING,
	 "return", NULL_TREE, 0);
      retval = convert (valtype, retval);
	  /* Avoid warning about control reaching end of function.  */
	  return;
      /* We can't initialize a register from a AGGR_INIT_EXPR.  */
      else if (! current_function_returns_struct
	       && TREE_CODE (retval) == TARGET_EXPR
	       && TREE_CODE (TREE_OPERAND (retval, 1)) == AGGR_INIT_EXPR)
	retval = build (COMPOUND_EXPR, TREE_TYPE (retval), retval,
			TREE_OPERAND (retval, 0));
      /* Add some useful error checking for C++.  */
      else if (TREE_CODE (valtype) == REFERENCE_TYPE)
	  tree whats_returned;
	  /* Sort through common things to see what it is
	     we are returning.  */
	  whats_returned = retval;
	  if (TREE_CODE (whats_returned) == COMPOUND_EXPR)
	      whats_returned = TREE_OPERAND (whats_returned, 1);
	      if (TREE_CODE (whats_returned) == ADDR_EXPR)
		whats_returned = TREE_OPERAND (whats_returned, 0);
	  while (TREE_CODE (whats_returned) == CONVERT_EXPR
		 || TREE_CODE (whats_returned) == NOP_EXPR)
	      while (TREE_CODE (whats_returned) == AGGR_INIT_EXPR
		     || TREE_CODE (whats_returned) == TARGET_EXPR)
		  /* Get the target.  */
		  warning ("returning reference to temporary");
	  if (TREE_CODE (whats_returned) == VAR_DECL && DECL_NAME (whats_returned))
	      if (TEMP_NAME_P (DECL_NAME (whats_returned)))
		warning ("reference to non-lvalue returned");
	      else if (TREE_CODE (TREE_TYPE (whats_returned)) != REFERENCE_TYPE
		       && DECL_FUNCTION_SCOPE_P (whats_returned)
		       && !(TREE_STATIC (whats_returned)
			    || TREE_PUBLIC (whats_returned)))
		cp_warning_at ("reference to local variable `%D' returned", whats_returned);
      else if (TREE_CODE (retval) == ADDR_EXPR)
	  tree whats_returned = TREE_OPERAND (retval, 0);
	    cp_warning_at ("address of local variable `%D' returned", whats_returned);
  if (retval != NULL_TREE
      && TREE_CODE_CLASS (TREE_CODE (retval)) == 'd'
      && cond_stack == 0 && loop_stack == 0 && case_stack == 0)
    current_function_return_value = retval;
  if (ctor_label && TREE_CODE (ctor_label) != ERROR_MARK)
      /* Here RETVAL is CURRENT_CLASS_PTR, so there's nothing to do.  */
      expand_goto (ctor_label);
  if (retval && retval != result)
      result = build (INIT_EXPR, TREE_TYPE (result), result, retval);
  expand_start_target_temps ();
  expand_return (result);
  expand_end_target_temps ();
  current_function_returns_value = 1;
/* Start a C switch statement, testing expression EXP.
   Return EXP if it is valid, an error node otherwise.  */
tree
c_expand_start_case (exp)
     tree exp;
  tree type, idx;
  exp = build_expr_type_conversion (WANT_INT | WANT_ENUM, exp, 1);
  if (exp == NULL_TREE)
      error ("switch quantity not an integer");
      exp = error_mark_node;
  exp = default_conversion (exp);
  type = TREE_TYPE (exp);
  idx = get_unwidened (exp, 0);
  /* We can't strip a conversion from a signed type to an unsigned,
     because if we did, int_fits_type_p would do the wrong thing
     when checking case values for being in range,
     and it's too hard to do the right thing.  */
  if (TREE_UNSIGNED (TREE_TYPE (exp)) == TREE_UNSIGNED (TREE_TYPE (idx)))
    exp = idx;
  expand_start_case
    (1, fold (build1 (CLEANUP_POINT_EXPR, TREE_TYPE (exp), exp)),
     type, "switch statement");
  return exp;
/* Returns non-zero if the pointer-type FROM can be converted to the
   pointer-type TO via a qualification conversion.  If CONSTP is -1,
   then we return non-zero if the pointers are similar, and the
   cv-qualification signature of FROM is a proper subset of that of TO.
   If CONSTP is positive, then all outer pointers have been
   const-qualified.  */
static int
comp_ptr_ttypes_real (to, from, constp)
     tree to, from;
     int constp;
  int to_more_cv_qualified = 0;
  for (; ; to = TREE_TYPE (to), from = TREE_TYPE (from))
      if (TREE_CODE (to) != TREE_CODE (from))
	return 0;
      if (TREE_CODE (from) == OFFSET_TYPE
	  && same_type_p (TYPE_OFFSET_BASETYPE (from),
			  TYPE_OFFSET_BASETYPE (to)))
	  continue;
	 so the usual checks are not appropriate.  */
      if (TREE_CODE (to) != FUNCTION_TYPE && TREE_CODE (to) != METHOD_TYPE)
	  if (!at_least_as_qualified_p (to, from))
	    return 0;
	  if (!at_least_as_qualified_p (from, to))
	      if (constp == 0)
		return 0;
	      else
		++to_more_cv_qualified;
	  if (constp > 0)
	    constp &= TYPE_READONLY (to);
      if (TREE_CODE (to) != POINTER_TYPE)
	return
	  same_type_p (TYPE_MAIN_VARIANT (to), TYPE_MAIN_VARIANT (from))
	  && (constp >= 0 || to_more_cv_qualified);
/* When comparing, say, char ** to char const **, this function takes the
   'char *' and 'char const *'.  Do not pass non-pointer types to this
   function.  */
int
comp_ptr_ttypes (to, from)
     tree to, from;
  return comp_ptr_ttypes_real (to, from, 1);
/* Returns 1 if to and from are (possibly multi-level) pointers to the same
   type or inheritance-related types, regardless of cv-quals.  */
int
ptr_reasonably_similar (to, from)
     tree to, from;
	return 0;
	  && comptypes (TYPE_OFFSET_BASETYPE (to),
	continue;
	return comptypes
	  (TYPE_MAIN_VARIANT (to), TYPE_MAIN_VARIANT (from),
	   COMPARE_BASE | COMPARE_RELAXED);
/* Like comp_ptr_ttypes, for const_cast.  */
static int
comp_ptr_ttypes_const (to, from)
     tree to, from;
	return 0;
	  continue;
	return same_type_p (TYPE_MAIN_VARIANT (to),
			    TYPE_MAIN_VARIANT (from));
/* Like comp_ptr_ttypes, for reinterpret_cast.  */
static int
comp_ptr_ttypes_reinterpret (to, from)
     tree to, from;
  int constp = 1;
      if (TREE_CODE (from) == OFFSET_TYPE)
	from = TREE_TYPE (from);
      if (TREE_CODE (to) == OFFSET_TYPE)
	to = TREE_TYPE (to);
      if (TREE_CODE (from) != FUNCTION_TYPE && TREE_CODE (from) != METHOD_TYPE
	  && TREE_CODE (to) != FUNCTION_TYPE && TREE_CODE (to) != METHOD_TYPE)
	    return 0;
	  if (! constp
	      && !at_least_as_qualified_p (from, to))
	    return 0;
      if (TREE_CODE (from) != POINTER_TYPE
	return 1;
/* Returns the type-qualifier set corresponding to TYPE.  */
int
cp_type_quals (type)
     tree type;
  while (TREE_CODE (type) == ARRAY_TYPE)
    type = TREE_TYPE (type);
  return TYPE_QUALS (type);
/* Returns non-zero if the TYPE contains a mutable member */
int
cp_has_mutable_p (type)
     tree type;
  return CLASS_TYPE_P (type) && CLASSTYPE_HAS_MUTABLE (type);
/* Subroutine of casts_away_constness.  Make T1 and T2 point at
   exemplar types such that casting T1 to T2 is casting away castness
   if and only if there is no implicit conversion from T1 to T2.  */
static void
casts_away_constness_r (t1, t2)
     tree *t1;
     tree *t2;
  int quals1;
  int quals2;
  /* [expr.const.cast]
     For multi-level pointer to members and multi-level mixed pointers
     and pointers to members (conv.qual), the "member" aspect of a
     pointer to member level is ignored when determining if a const
     cv-qualifier has been cast away.  */
  if (TYPE_PTRMEM_P (*t1))
    *t1 = build_pointer_type (TREE_TYPE (TREE_TYPE (*t1)));
  if (TYPE_PTRMEM_P (*t2))
    *t2 = build_pointer_type (TREE_TYPE (TREE_TYPE (*t2)));
     For  two  pointer types:
            X1 is T1cv1,1 * ... cv1,N *   where T1 is not a pointer type
            X2 is T2cv2,1 * ... cv2,M *   where T2 is not a pointer type
            K is min(N,M)
     casting from X1 to X2 casts away constness if, for a non-pointer
     type T there does not exist an implicit conversion (clause
     _conv_) from:
            Tcv1,(N-K+1) * cv1,(N-K+2) * ... cv1,N *
     to
            Tcv2,(M-K+1) * cv2,(M-K+2) * ... cv2,M *.  */
  if (TREE_CODE (*t1) != POINTER_TYPE
      || TREE_CODE (*t2) != POINTER_TYPE)
      *t1 = cp_build_qualified_type (void_type_node,
				     CP_TYPE_QUALS (*t1));
      *t2 = cp_build_qualified_type (void_type_node,
				     CP_TYPE_QUALS (*t2));
      return;
  quals1 = CP_TYPE_QUALS (*t1);
  quals2 = CP_TYPE_QUALS (*t2);
  *t1 = TREE_TYPE (*t1);
  *t2 = TREE_TYPE (*t2);
  casts_away_constness_r (t1, t2);
  *t1 = build_pointer_type (*t1);
  *t2 = build_pointer_type (*t2);
  *t1 = cp_build_qualified_type (*t1, quals1);
  *t2 = cp_build_qualified_type (*t2, quals2);
/* Returns non-zero if casting from TYPE1 to TYPE2 casts away
   constness.  */
static int
casts_away_constness (t1, t2)
     tree t1;
     tree t2;
  if (TREE_CODE (t2) == REFERENCE_TYPE)
	 Casting from an lvalue of type T1 to an lvalue of type T2
	 using a reference cast casts away constness if a cast from an
	 rvalue of type "pointer to T1" to the type "pointer to T2"
	 casts away constness.  */
      t1 = (TREE_CODE (t1) == REFERENCE_TYPE
	    ? TREE_TYPE (t1) : t1);
      return casts_away_constness (build_pointer_type (t1),
				   build_pointer_type (TREE_TYPE (t2)));
  if (TYPE_PTRMEM_P (t1) && TYPE_PTRMEM_P (t2))
       Casting from an rvalue of type "pointer to data member of X
       of type T1" to the type "pointer to data member of Y of type
       T2" casts away constness if a cast from an rvalue of type
       "poitner to T1" to the type "pointer to T2" casts away
       constness.  */
      (build_pointer_type (TREE_TYPE (TREE_TYPE (t1))),
       build_pointer_type (TREE_TYPE (TREE_TYPE (t2))));
  /* Casting away constness is only something that makes sense for
     pointer or reference types.  */
  if (TREE_CODE (t1) != POINTER_TYPE
      || TREE_CODE (t2) != POINTER_TYPE)
    return 0;
  /* Top-level qualifiers don't matter.  */
  t1 = TYPE_MAIN_VARIANT (t1);
  t2 = TYPE_MAIN_VARIANT (t2);
  casts_away_constness_r (&t1, &t2);
  if (!can_convert (t2, t1))
    return 1;
  return 0;
Re: Linux -> PPC cross-compile of the Motor Record Ronald L. Sluiter
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS Bob Dalesio
Next: Re: EPICS to WAGO PLC using Ethernet MODBUS Elder Matias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linux -> PPC cross-compile of the Motor Record Ronald L. Sluiter
Next: fiber media converters john sinclair
