Folks,
I'm having some problems building EPICS 3.14 stuff on solaris-sparc-gnu. I have built base 3.14.4 with no problems. I have also built the EPICS example application, including the snc example, and the soft IOC works OK.
The problems I'm having are:
- An error linking the mpf2-4 test programs. A C++ routine (Tcp::connect) which should definitely exist in the libmpf.so library is not being found at link time.
- I have built the 3.14 versions of the extensions ezca, EzcaScan and ezcaIDL with no problems. However, when I try to use the resulting ezcaIDL.so from IDL on Solaris to do channel access it gives a bus error and crashes.
The version of g++ on my Solaris system is 2.95.3. The MPF problem does not happen on Linux (g++ 3.2.2) or Mac Darwin (g++ 3.3). Do you think it is likely that these problems are gcc/g++ version related? What versions of gcc/g++ have others used for building on Solaris, and has anyone built MPF 2-4 with it?
Re: EPICS Gateway 2_0_0_0Beta1 Steven . Banks
Re: Problems with solaris-sparc-gnu Ben-chin K. Cha
<2003>
2025
<2003>
2025
