1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: scanRecord for 3.14
To: "'Marty Kraimer'" <[email protected]>, [email protected]
Date: Fri, 5 Dec 2003 17:04:20 -0500
Yes, I use scanRecord in many places and love it.  I am currently running
R3.13.5.  The absence of scanRecord or an equivalent in R3.14 would be a
complete show-stopper for an upgrade.
I have never looked at sscanRecord before, but just reading the
documentation it looks like a superset of the scanRecord with  somewhat
clearer documentation.  Would an sscanRecord be a direct substitute for a
scanRecord (i.e. backwards compatible)?
I am puzzled, however, because the documentation explicitly states that it
uses recDynLink which is normally distributed as part of the package.  If
the purpose of the suggested changes is to escape from recDynLink, how would
we be better off using sscanRecord?
Cheers,
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
> -----Original Message-----
> From: Marty Kraimer [mailto:[email protected]]
> Sent: Friday, 2003 December 05 1:02 PM
> To: [email protected]
> Subject: scanRecord for 3.14
> The next 3.14 release will support put callbacks for database
> channel access
> links. This is being done so that synapps can remove it's
> dependence on recDynLink.
> 3.13 and early versions of 3.14 has support for scanRecord.
> This was removed
> from 3.14 because it required recDynLink. Now that put
> callback links will be
> supported the scanRecord could be easily modified so that it
> no longer requires
> recDynLink.
> The question I have is does anyone use scanRecord?
> Synapps provides sscanRecord which provides more
> functionality than scanRecord
> so is scanRecord still needed?
> Marty Kraimer
Re: scanRecord for 3.14 Tim Mooney
Re: scanRecord for 3.14 Marty Kraimer
Prev: scanRecord for 3.14 Marty Kraimer
Next: Re: scanRecord for 3.14 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: scanRecord for 3.14 John Maclean
Next: Re: scanRecord for 3.14 Tim Mooney
